Question about the quaife lsd.
Old Oct 4, 2004 | 11:48 AM
underpressure02's Avatar
Default Question about the quaife lsd.
Are there different part numbers for an ls tranny vs a gsr tranny?
Does anyone have the part number for the ls hydro tranny?
Thanks
Old Oct 4, 2004 | 12:29 PM
AutotechRD's Avatar
Default Re: Question about the quaife lsd. (underpressure02)
The LS tranny uses Quaife part # QDF-1U1, the same diff. used in the B16 transmissions. These differentials have a smaller bolt pattern for the ring gear, and the VSS ring is in a slightly different spot compared to a B18C style diff (Quaife part # QDF-6U1). Quaife America's part number for the QDF-1U1 differential is 60.309.160, and the QDF-6U1 is 60.309.180.
Hope that helps,
Brian
Old Oct 4, 2004 | 01:03 PM
Default Re: Question about the quaife lsd. (AutotechRD)
cool thanks for the info. So if I bought a 60.309.180 that would not work in an ls tranny?
Old Oct 5, 2004 | 07:29 AM
AutotechRD's Avatar
That would only work in an LS if you ran the correct Ring gear (B18C), and VSS arrangement.
Brian
sahwan
Transmission & Drivetrain
Oct 3, 2012 01:48 PM
eride89
Apr 14, 2011 03:34 AM
ramco
Oct 15, 2009 08:59 PM
Maxcapacity
Mar 16, 2008 03:58 PM
votoms888
May 14, 2007 05:15 PM
