Q16 fuel question
Old Mar 2, 2013 | 09:48 PM
spoon93's Avatar
Default Q16 fuel question
So I just had my car tuned, on q16. There's about 4 gallons still in my tank, my question is now that the car will sit for a while ( I dnt daily it, it's my weekend warrior ..)
What should I do? Jus leave it and start it every other day? Or do I have to drain it? What are my options here? Thanks in advance...
Old Mar 3, 2013 | 02:12 AM
rs250nut's Avatar
Default Re: Q16 fuel question
I would drain it and flush it with some pump gas
Old Mar 3, 2013 | 06:37 AM
spoon93's Avatar
Ya, how would I go about tht though? Since its tuned for that octane. I doubt I can jus run 91 now
Old Mar 3, 2013 | 07:58 AM
LocoJoe's Avatar
I doubt it affects too much. Im on Q and I pickle the fuel system with 87 oct for about 5-10 minutes. Idle aint too bad with the fuel change.
If u leave Q16 sitting for a long time, it will eat parts away. Pickle the system and u will be golden.
Old Mar 3, 2013 | 08:04 AM
spoon93's Avatar
Ok I will do that. Thanks man
Old Mar 3, 2013 | 08:21 AM
locash's Avatar
I drain the Q16, add 2-3 gallons of pump gas, run the car for a few minutes, and then let it sit until the next event. Then repeat process with Q16.
Old Mar 3, 2013 | 10:10 AM
spoon93's Avatar
Ok. It will just be a pain draing this **** lol I have over a half tank haha and only had tht one tune
Old Mar 3, 2013 | 01:35 PM
turbo-2nr's Avatar
go drive the car around lol
Old Mar 3, 2013 | 02:02 PM
sleepinonacreeper's Avatar
takes about a minute to get it out. I made a hose with an AN fitting that I swap with my feed line and run it to a gas can.
Old Mar 3, 2013 | 03:15 PM
PhilStubbs's Avatar
I just put the return line into a gas can, turn the pump on with a battery charger hooked up
Old Mar 3, 2013 | 04:04 PM
spoon93's Avatar
Can I do the rerun line and start the car to have the pump going?
Old Mar 3, 2013 | 04:46 PM
famous_atticus's Avatar
I have run Q16 for a couple years now. The longest I ever let is sit was 2 weeks and I add some octane boost and fuel stabilizer and I had no problems.
Old Mar 3, 2013 | 06:17 PM
PhilStubbs's Avatar
You could idle the car with the return line in a gas can.
Old Mar 3, 2013 | 06:39 PM
spoon93's Avatar
Thanks guys..
Old Mar 3, 2013 | 07:52 PM
SPOOLINmatt's Avatar
i take the line off the rail and add an extension into a can or bucket when draining. Kick that pump on and it drains it fast! (aeromotive pro)
Old Mar 4, 2013 | 11:29 AM
RRev Tim's Avatar
I have been running Q16 for just about 4 years now in my race car, I have never drained it. It sits all winter with it in the tank, I have not had any problems... BUT, It is safest to switch if you know the car will be down for a few months, as for a couple week, NO WAY I would switch, its a waste of time.
Old Mar 4, 2013 | 04:19 PM
blackeg's Avatar
isnt there a 17mm drain plug on the bottom of the tank? thats how i drain my gas just make sure you have the fill cap off so it will flow out of the tank and not just dribble down the bottom of the tank
Old Mar 4, 2013 | 04:48 PM
PhilStubbs's Avatar
There is a drain but every time I pull one, it drips when it goes back in. Takes a few attempts to get it to stop
Old Mar 4, 2013 | 05:50 PM
Disco's Avatar
That damn plug can be a real A-hole.
JDMEMone
Oct 28, 2011 11:20 PM
TegraGSXR
Jan 30, 2010 08:29 AM
NumberB
Dec 13, 2003 10:52 PM
meanteg
Oct 22, 2003 01:56 PM
