Push button for starter, fuel pump? and such?
Old Mar 13, 2014 | 06:33 AM
J_24's Avatar
Default Push button for starter, fuel pump? and such?
I'm in the middle of building my first track car. I come across many build's and videos but have not gotten an ideal answer. In this video the guy presses the closest switch to the push button start, then presses the second over and the pump whines? Then he goes to the actual push button ignition.
Is this a easy set-up? worth doing or just something for simplicity? I can not find a write-up or even part's for that matter. I'd like to incorporate this in my build.
See vid: about 40 second's in.
Old Mar 13, 2014 | 06:54 AM
J_24's Avatar
Default Re: Push button for starter, fuel pump? and such?
I guess this is what I am looking for?
But what is hooked to the switches? Fan, pump and kill? or can the push button for fuel pump also be the kill?
Old Mar 13, 2014 | 07:48 AM
Twenty47's Avatar
the first switch is his electronics (ecu, wide band, cluster, sensors ect). 2nd button is fuel pump and the last two are most likely water pump and fan. Signal for the starter is wired to the push button
Old Mar 13, 2014 | 07:56 AM
Turbo-LS's Avatar
What's wrong with turning the key?
Old Mar 13, 2014 | 09:59 AM
V-SPEC 1's Avatar
Lol.
Old Mar 13, 2014 | 10:23 AM
Twenty47's Avatar
its nice not to have your fuel pump going every time you want to get into the ecu
Old Mar 13, 2014 | 12:23 PM
sicklude97's Avatar
because racecar
Old Mar 13, 2014 | 12:27 PM
A L I A S's Avatar
also makes for very simple circuits. therefore if one thing goes out not everything does, its a good way to keep problems isolated. and to add on to previously stated reasons, you can do other things like keep your electric water pump and fans running when you shut the car down, or turn on the fuel pumps to empty the tank. to answer the op's question, your gonna have to look at wiring diagrams and decide how you want to build the electrical system.
Old Mar 13, 2014 | 01:45 PM
Turbo-LS's Avatar
I understand the purpose of the panel and wiring everything on its own circuit. I was joking with the OP. I havent got that far with my car yet. Everything works for now as it is. Eventually I will switch to have the option to play with the ecu and not have everything else running.
Old Mar 15, 2014 | 05:34 AM
J_24's Avatar
Thanks everyone.. It was mainly curiosity. I just know some folk's like to kill the car after the run but allow the fan to keep running and etc. I've got a lot to learn due to this being my first actual car for the track.
Old Mar 17, 2014 | 06:30 AM
JDogg's Avatar
There is really no reason to have all those switches. The ecu can control everything once its turned on. You really just need 2 switches, ign power and starter. Ecu does the fuel pump, water pump, fan, etc. Set it all up in the ecu correctly and nothing else will be running when you want to play w/the ecu.
Old Mar 17, 2014 | 03:41 PM
ekcoupeh22's Avatar
Look into the arc panels as well very nice and easy setpi
GPC91
Aug 17, 2012 05:23 PM
WildChild
Audio / Security / Video
Sep 7, 2005 08:29 AM
Mgsr
Jun 24, 2005 10:51 AM
speedracer33
Jul 25, 2002 12:55 PM
