Proper launch method
Old Jul 6, 2004 | 09:03 AM
Tippyman's Avatar
Default Proper launch method
Hey yall, i am new to drag racing. i need to know how to launch. i have like no idea. i gotta a 5 spd. 1998 civic hatchback.
Old Jul 6, 2004 | 10:57 AM
drinksoy's Avatar
Default Re: Proper launch method (Tippyman98)
lol ditto.
2 no0bs hurr.
Old Jul 6, 2004 | 11:22 AM
naturalvx's Avatar
Rev to just below redline, drop the clutch, shift until the tires quit spinning then keep the car straight.
Old Jul 6, 2004 | 12:23 PM
megotvtec's Avatar
Default Re: (naturalvx)
go somewhere and practice launching. try launching from 3000rpm's if you dont peel out then launch higher.
Old Jul 6, 2004 | 04:04 PM
Tippyman's Avatar
Default Re: (megotvtec)
ya, i would if i knew how to launch.
Old Jul 6, 2004 | 04:17 PM
BoostedCivicSedan's Avatar
Default Re: (Tippyman98)
I usually slip the clutch out around 5400 and 6k rpms off the 2 step at about 80% throttle then as soon as the clutch is fully engaged and i feel traction i mash it to the floor and go....
But if your tires are sticky enough and you trust your axles to hold up, just like megotvtec said, start just dumping the clutch at 3k rpms, and work off of that in 500 rpm increments until you find that sweet spot....
Old Jul 6, 2004 | 07:37 PM
megotvtec's Avatar
Default Re: (BoostedCivicSedan)
thats true. if you got some 13"stock rims w/pos tires then good luck dropping the clutch. when i had my 13"s i had to launch at exactly 3500rpm's.
If i launched at 3800 id just burn out. and if i launched at 3300 id bog.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 &raquo;</TD></TR><TR><TD CLASS="quote">ya, i would if i knew how to launch.</TD></TR></TABLE>
just hold clutch to floor, put it in 1st gear, slowly rev up and hold it steady at the rpm you want to launch at then let go of the clutch and stomp on the gas at the same time.
newb questions dont get much simpilar than this! lol. oh well got to start somewhere.
Old Jul 6, 2004 | 07:42 PM
red cx's Avatar
leave as hard as your motor and tranny will let you
Old Jul 7, 2004 | 05:54 AM
RedRocketCRX's Avatar
i always launch my car at 3 or 3.5. it does a little burnout, as soon as i hear the tire stop spinning i floor the gas. it took me a while to get the timing down right but it works i always kill everyboby off the line.
GetawayInMoscow
Apr 9, 2007 11:37 AM
m0nk
Oct 15, 2004 09:48 PM
CheeseKT
Jan 12, 2004 01:38 PM
CarbonfiberR
Aug 15, 2002 11:17 AM
LuderCriS
Feb 5, 2002 12:35 PM
