Preloading question
Old Jul 15, 2009 | 04:19 PM
hello1320's Avatar
Default Preloading question
I put light pressure in the brake bring up the revs. Then drag the car into the beam,when the stage light comes on i push in clutch and pull the brake at the same time. But when i do that car bounces when it stops.
Sometimes i have to b on the 2 step while iam prestaged then roll in
Is the trans unloaded when the clutch is pushed in to stop the car
Just wanna know how the big dogs do it
Old Jul 15, 2009 | 05:14 PM
Blown90hatcH's Avatar
Default Re: Preloading question
Big dogs don't preload cause their transmissions can take it.
I ride the e-brake just before 2nd stage light. 2nd light, WOT pulling e-brake hard.
Old Jul 15, 2009 | 09:53 PM
base-op.1320's Avatar
I stage completely then pull the e-brake, wot at first yellow let clutch out slightly on 2nd yellow and launch on last yellow.
Old Jul 16, 2009 | 12:50 AM
1992Si's Avatar
If you run the slicks at a lower pressure, they become a shock absorber for the hit. It's something you'll want to walk into, don't just jump to lower pressure. You'll find out why in the top end. 4-4.5psi.
Old Jul 16, 2009 | 03:43 PM
B16Civic93's Avatar
4 4.5 lbs in slicks is pretty dam low lol... lowest i've ever taken mine is like 5 3/4 and i could notice a hell of a difference at the top end at 140+
Old Jul 16, 2009 | 04:09 PM
1992Si's Avatar
Is your chassis aligned. We had our's set up to OEM spec's and my eye ball for rear camber, straight up.
itr1244
Mar 12, 2015 03:45 AM
no_rice_please
May 19, 2009 06:06 PM
StolenTeg
Apr 24, 2005 07:11 AM
madman604
Jul 9, 2003 06:10 PM
