power to pump?
Old Mar 12, 2006 | 07:16 AM
A2gt35r's Avatar
Default power to pump?
I have an 02 ep that I ripped out the tank to and put a 8gal cell in with the biggest inline bosch pump that wont fry my ecu from endyn, and was wondering what was the best 12amp power source?
Could I use the stock pick-up that went to the stock pump, or do I just cut those wires & go from the ignition???
Old Mar 12, 2006 | 01:17 PM
A2gt35r's Avatar
I know some people use the altenator. Someone in here has to have some good advice???
Old Mar 12, 2006 | 02:35 PM
SpeedDreamz.com's Avatar
Default Re: (A2gt35r)
Use the ecu wire to trigger a bosch relay feeding current from the battery. That way you will never have an issue.
Old Mar 12, 2006 | 03:02 PM
A2gt35r's Avatar
I hope I got this right, you take the stock sending pump wire from the ecu & hook up a bosch relay & then into the pump?
Thanks for the help speeddreams!
Old Mar 12, 2006 | 03:08 PM
dbang003's Avatar
yea...run a 10 or 12 gauge wire...i used 10 on mine...from the battery to the pump, but use a relay that is controlled by the stock pump power wire to power the relay...and put a 30 amp inline fuse on the wire from the pump to the battery...good luck...
-drew
Old Mar 12, 2006 | 06:07 PM
A2gt35r's Avatar
Thanks alot, that was very informative.
Old Mar 13, 2006 | 04:06 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (SpeedDreamz.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">Use the ecu wire to trigger a bosch relay feeding current from the battery. That way you will never have an issue.</TD></TR></TABLE>
best way.
or like posted above, us the stock fuel pump power to trigger a relay.
Modified by boostedcivicsir at 10:03 PM 3/13/2006
Old Mar 13, 2006 | 01:02 PM
vaporboy12's Avatar
Default Re: (boostedcivicsir)
thanks for the good info guys will put this to good use becasue im about to order the pump
Old Mar 14, 2006 | 08:21 AM
dbang003's Avatar
Default Re: (vaporboy12)
if you haven't ordered the pump yet make sure u get the high pressure 255lph walbro...if that's the pump u are looking to use...the make 2 different 255's...but both are the same price i believe...i can't remember the part no. offhand...just wanted to share that...
-drew
Old Mar 14, 2006 | 04:21 PM
turbolshatch's Avatar
Default Re: (dbang003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbang003 &raquo;</TD></TR><TR><TD CLASS="quote">if you haven't ordered the pump yet make sure u get the high pressure 255lph walbro...if that's the pump u are looking to use...the make 2 different 255's...but both are the same price i believe...i can't remember the part no. offhand...just wanted to share that...
-drew</TD></TR></TABLE>
i think they are talking about inline pumps
Old Mar 14, 2006 | 05:47 PM
Kataku2K3's Avatar
Default Re: (turbolshatch)
Here's my diagram for 1000 years ago...
That was if you didn't have a factory trigger wire (from an OE ECU) to activate the pump. I normally tell people who are using their factory ECU's now to control the pump to wire the 12V+ side (85 in this diagram) to a constant, then use the FLR (ground) output from the ECU to activate the circuit (86 terminal).
pleej
Apr 8, 2011 11:06 AM
RACEPAK
Feb 10, 2008 10:58 AM
lemongreenhatch
Aug 7, 2006 06:12 AM
*Boostwerks*
Mar 3, 2005 10:06 PM
platinum00
Feb 4, 2004 01:54 PM
