Plug options with C.O.P?
Old Mar 24, 2010 | 05:52 PM
85mmek9's Avatar
Default Plug options with C.O.P?
Im running the aem v2 twin fire, last year I was running ngk iridium plugs. The plugs I want to use I cant because there a non resistor plug. So my question is what are you other big hp guys using besides the expensive iriduim plugs? #9,10 plugs.
thanks
Old Mar 24, 2010 | 06:00 PM
redboost10's Avatar
Default Re: Plug options with C.O.P?
denso iridiums is what i run. ik27's
Old Mar 25, 2010 | 04:28 AM
85mmek9's Avatar
anyone else?
Old Mar 25, 2010 | 05:01 AM
tepid1's Avatar
IK27's here too. Expensive for a plug, but they work pretty good.
Old Mar 25, 2010 | 05:20 AM
xsi-t's Avatar
does ngk make one that compare to the ik27??
Old Mar 25, 2010 | 06:22 AM
tepid1's Avatar
I believe they do.... NGK IFR9H-11
It's the "laser iridium" plug
Looks like it should work. It's used on the 2002-2006 Honda RVT1000R RC51. Badass bike btw, but they still can't hang with my Ducati 1098S. lol
It's also a bit more expensive than the IK27
Old Mar 25, 2010 | 07:07 AM
B18c1turboedEK's Avatar
IK27s here also. I couldnt find anything cheaper,that would work!
Old Mar 25, 2010 | 07:47 AM
1992Si's Avatar
Why doesn't someone call NGK on their toll free 800 # and ask for Tech Support and talk with the experts, instead of some guy on a Ducati.
There must be a $2.00 plug out there that will work. After all, it's only going to be there for a 1/4 mile.
Old Mar 25, 2010 | 08:58 AM
tepid1's Avatar
Damn, Byron. All over my *** today. haha
I got that NGK number after only 2 min of reasearch. I'm sure there are others out there that will work fine. Just takes time to research.
Old Mar 25, 2010 | 09:04 AM
Rtype16's Avatar
You can try these plugs
BKR8EIX - Heat Range 8
BKR9EIX - Heat Range 9
Old Mar 25, 2010 | 09:08 AM
redboost10's Avatar
you can turn down an ngk tip on a lathe to make it work...
also i believe the aem coils accept the cheaper ngk plugs as well, if i remember correctly reading some of bisi's posts, but overall, just not as good as a coil as the cbr ones
Old Mar 25, 2010 | 09:25 AM
1992Si's Avatar
For those of us that replace them after every run and not getting new ones for free. Cheap and works for one pass is a better option.
Old Mar 25, 2010 | 09:38 AM
rota92
Guest
Posts: n/a
The AEM coil can run a push on type plug, but I still haven't looked into what to use. No more replacing every pass hopefully, that was just because the car didn't like old plugs.
Old Mar 25, 2010 | 09:53 AM
85mmek9's Avatar
Aem told me I had to use a resistor plug, a non resistor plug would cause to much interference. So ya looking for a resistor plug that would work that is not 6-8 each. I will try to call ngk asap, just thought I would see what everyone elso was using for with a cdi or other ignition that requires a resistor plug.
Old Mar 25, 2010 | 03:39 PM
h22 civic's Avatar
subscribed
Old Mar 25, 2010 | 06:50 PM
boosted hybrid's Avatar
RSX coils with kenne bell boost a spark. You can run R5671a-9 or 10 plugs that are cheap.
Old Mar 25, 2010 | 07:05 PM
85mmek9's Avatar
That is a non resistor plug, need a resistor plug
Old Mar 25, 2010 | 11:54 PM
1992Si's Avatar
I'm sure one quick call to Devin and you'll have the answer. Thinking about it, miller would know too.
Hint to you guy's that haven't figured it out yet. Weld a 5/8 spark plug socket to a 6" extension.
Old Mar 26, 2010 | 09:11 AM
Rtype16's Avatar
This is just going off a website that sells a ton of sparkplugs.... haha
These are all resistor plugs
NGK BKR8EIX - Heat Range 8 - $8.48
NGK BKR9EIX - Heat Range 9 - $8.48
Denso K24PR-U11 - Heat Range 8 - $2.89
Denso K24PR-ZU - Heat Range 8 - $5.72
Denso Q27PR-ZU - Heat Range 9 - $5.72
I don't have my other books to look up other manufacturers. I have never used those particular denso plugs I always just run the iridiums, but you wanted cheap so here it is.
Old Mar 26, 2010 | 10:49 AM
kcevo's Avatar
You will not find a copper/cheaper alternative in a 9 or 10 range that is a resistor type, been down this road many years ago.
This was a minor issue when running the AEM CDI boxes back in the day for us, other than them just burning up. LOL
When we switched to the M&W stuff no issues at all running the R5671A-X plugs, these are the plugs you will find most racers use if they can use a non-resistor plug. If they have to run a resistor type plug or a plug that has to have a removable "terminal" you will see most run the Denso IK27 or colder plug.
Old Mar 30, 2010 | 12:02 PM
h22 civic's Avatar
i ran the ngk r5671a-9 before my change to c.o.p & these are what was recomended to me now that im using A.E.M c.o.p and need a resistor plug
IFR9H-11 .044" (1.1mm) $12.30
NGK Racing plug 7885 R6601-9 $21.06
NGK IX iridium 2669 BKR9EIX .032" (0.8mm) $8.48
NGK Racing plug 4899 R7436-9 .027" (0.7mm) $41.52
NGK Racing plug 4658 R7434-9 .027" (0.7mm) $41.52
NGK Racing plug 4660 R7433-9 .027" (0.7mm) $41.52
NGK Racing plug 4896 R7435-9 .027" (0.7mm) $41.52
NGK Laser Iridium Long Life 4709 FR9BI-11 .044" (1.1mm) $7.98
NGK Racing plug 4753 R7282-
Old Mar 30, 2010 | 01:35 PM
tony1's Avatar
Put a good ignition system on and you don't have to replace them every run. I can get 3-4 events on a set of Denso IK27's easily.
Old Mar 30, 2010 | 04:05 PM
1992Si's Avatar
The boss has said above...that hopefully, won't be an issue this time. I'm sure he'll be in touch with you as the time gets nearer.
Old Mar 30, 2010 | 07:18 PM
ALL IMPORT's Avatar
damn if your having to replacing plugs every run u have bigger issues, lol
Old Mar 30, 2010 | 09:01 PM
mike93eh2's Avatar
BKR8EIX
