Palmdale
Old Nov 24, 2002 | 04:33 PM
b19coupe's Avatar
Default Palmdale
Ran 14.2's and 14.3's at Palmdale this weekend and I did not win the all motor class. Guess I need slicks or something. Maybe a lighter car, more horsepower, and a better driver too. What do you think?
Old Nov 24, 2002 | 06:59 PM
redcxhatch's Avatar
Default Re: Palmdale (b19coupe)
haha, or a bigger horse shoe?
Old Nov 24, 2002 | 08:39 PM
b19coupe's Avatar
Default Re: Palmdale (redcxhatch)
Horse shoe ? Sorry, that went right over my head (not hard to do).
Old Nov 24, 2002 | 09:17 PM
civura R's Avatar
i was there i ran a 14.5 had a problem with slicks
what car was urs?
Old Nov 24, 2002 | 09:26 PM
b19coupe's Avatar
Default Re: Palmdale (civura R)
Green 95 coupe with #297 in backwards. (I love my wife!).
Old Nov 24, 2002 | 10:25 PM
gsrvx's Avatar
New User
What's ur setup? That's a great time especially at palmdale.
-Rod
Old Nov 24, 2002 | 10:29 PM
b19coupe's Avatar
Default Re: Palmdale (RK)
GSR block 84mm sleeves, JE 12:1 pistons, Skunk2 Stage 2 cams, DC JDM 4-1 header with ITR B-pipe and muffler. Chipped P28 ecu. Shitty 16" wheels and Nitto NT450 205/40/16's. Working on a new motor that will get me into the 12's (I hope).
Old Nov 24, 2002 | 10:43 PM
civura R's Avatar
gsr in a eg chipped ecu 14.5 allright i guess
Old Nov 25, 2002 | 05:51 AM
GreenR's Avatar
Not, get that thing dyno tuned and you can hit 12's.
Old Nov 25, 2002 | 01:47 PM
SergEK's Avatar
Default Re: Palmdale (GreenR)
Well I think Palmdale is 2500/2700 ft above sea level?
Here in Idaho (2700/3000 ft) I run 14.0's should see a 13.70 soon with P73 ecu....pretty much a stock (I/H) C5 motor with BFG drag radials.
I would compete in an all motor class yet.......I would want to be at least in the high 12's before I felt like I had something competitive.....even then most serious guys are in the 10's/11's
Old Nov 25, 2002 | 10:52 PM
FR-MOB: ThE bEe GuY's Avatar
I wouldnt trust the times at palmdale (Since the elevation sucks, and if you look at the track straight on it seems as though its going uphill...)
Old Nov 25, 2002 | 11:19 PM
gsrvx's Avatar
New User
Default Re: Palmdale (hondaspeed85)
I usually go to Palmdale. Over summertime...I went to Sears Point and the elevation correction formula is quite accurate. So don't forget to correct ur times. My last uncorrected time at palmdale was 14.23
Old Nov 26, 2002 | 08:29 AM
lucky's Avatar
what fantasy world are you living in? given the altitude and limited mods...that is a repectable time.
Old Nov 26, 2002 | 02:28 PM
earl's Avatar
Track is level, shutoff is uphill, just like many tracks.
Old Nov 26, 2002 | 02:37 PM
Boostfed's Avatar
New User
Altitude Correction chart here for FYI!
http://www.clubsi.com/altitude.shtml
Old Nov 26, 2002 | 06:10 PM
EVOCELICA's Avatar
New User
Default Re: Palmdale (Boostfed)
LACR sucks ***, around 2700 feet elevation nasty launch pad and dirt and debree blowing across the track, but they are open every wednesday and friday night so it's my home town track. I went 14.3 at 101 stock b16 with 4 psi of boost.
Old Nov 26, 2002 | 06:48 PM
b19coupe's Avatar
Default Re: Palmdale (EVOCELICA)
I am building a new motor that should put between 215-230 hp to the ground. I am hoping that with slicks and some driver improvement (my reaction times are between .850-1.00) I will be able to hit low to mid 13's at Palmdale. Better times at Pomona. Current motor putting 200hp to the ground. Goal for this car is high 12's when it is done. Then I think I will build a hatch.
Old Nov 26, 2002 | 07:15 PM
EVOCELICA's Avatar
New User
are you running 14.2 with a sleeved high compression block?
b19coupe's Avatar
Yep.
Old Nov 26, 2002 | 08:40 PM
EVOCELICA's Avatar
New User
who built your motor?
Old Nov 26, 2002 | 09:04 PM
b19coupe's Avatar
Aside from machine shop work, moi.
Old Nov 26, 2002 | 10:02 PM
EVOCELICA's Avatar
New User
200whp in a coupe you should be pulling better times than 14.2 what was your 60ft.
Old Nov 26, 2002 | 10:12 PM
b19coupe's Avatar
2.35 to 2.4's. Car does not hook up so well in first. I also had a half tank of gas and about 100lbs of extra stuff in the car, including a child's car seat. Took the whole family up for the races. Next time we will be taking two vehicles.
Old Nov 27, 2002 | 06:06 AM
mitsuman's Avatar
well just FYI reaction times dont mean a thing. doesnt have an affect on your ET's. when you trip the beam then it starts the clock. so dont worry that much on reaction times.
Old Nov 27, 2002 | 06:07 AM
mitsuman's Avatar
o and he was saying like you need more luck. a horse shoe is a good luck charm.
