Oil Pump Help!!!!!!!
Old Jan 30, 2006 | 03:05 PM
Cubanlinx3's Avatar
Default Oil Pump Help!!!!!!!
This weekend I shattered my oil pump and I am looking to replace . I saw a thred on this topic before but could not find what I was looking for under a search. For one I am running a fully built ls/vtec that's boosted with a gt35r putting down 550hp. I do drive the car on the street on weekends and take take it to the track both. For starters what is the best oil pump to run, ( Aftermarket or OEM ). I would like peoples inputs that are currently running the pumps or have broken different ones. I have heard alot of different inputs, some saying OEM ones are the best and aftermarket ones are overrated and oposite. If OEM one is the best which one should I run? Thanks for the all the help. I will try to post some pics of this destoried pump.
Old Jan 30, 2006 | 03:14 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Oil Pump Help!!!!!!! (Cubanlinx3)
what weight oil are you running, and what dampner are you running for a crank pully?
Old Jan 30, 2006 | 03:20 PM
Cubanlinx3's Avatar
Default Re: Oil Pump Help!!!!!!! (PURPLETERROR aka BIGMATT)
I run a stock damper because I heard it was easier on your stock pump. This is a new set-up so I just ran 10w-30. Is this the wrong thing to do? .
Old Jan 30, 2006 | 04:24 PM
TURBO-TEG's Avatar
heres wat i did...been running strong for 2 years now...... after i blew a stock oil pump gear and a prodrive gear!!!! best money i ever spent!!!
Modified by TURBO-TEG at 1:48 AM 1/31/2006
Old Jan 30, 2006 | 04:30 PM
Turbo-charged's Avatar
Default Re: Oil Pump Help!!!!!!! (TURBO-TEG)
where does one go about purchasing a red X
Old Jan 30, 2006 | 04:48 PM
TURBO-TEG's Avatar
Default Re: Oil Pump Help!!!!!!! (Turbo-charged)
how bout now?
Old Jan 30, 2006 | 04:49 PM
thats better. not legal for the street class's though if you plan to race competitivley. i cant spell
Old Jan 30, 2006 | 04:52 PM
TURBO-TEG's Avatar
its legal up here in the street class!!!
Old Jan 30, 2006 | 05:59 PM
ReDemoN's Avatar
DixielandImports Please
Get a toga oil pump from this site
http://www.importperformanceparts.net
It is supposed to be better than stock.
I'm gonna give in a shot.
Old Jan 30, 2006 | 06:43 PM
OaksRacing's Avatar
Default Re: Oil Pump Help!!!!!!! (ReDemoN)
We removed our dry sump system to be able to race NHRA SFWD. We went with circuit worx instead of stock. We will give it a good test this season.
Old Jan 30, 2006 | 06:58 PM
AR Fab's Avatar
Default Re: Oil Pump Help!!!!!!! (OaksRacing)
the pump failure had nothing to do with it being stock/toda/prodrive/circuit worx.....
Its more like....the line-bore to pump plane differences...
bent crank..out of balance crank...dampner
Howard
Old Jan 31, 2006 | 08:05 AM
Cubanlinx3's Avatar
Default Re: Oil Pump Help!!!!!!! (AR Fab)
Thanks for the help guys
ltwolf2
Sep 7, 2014 03:33 PM
AllShowNoGo727
Apr 25, 2014 05:00 PM
92Snatch
Nov 30, 2012 03:12 PM
tunedek
Dec 5, 2006 06:46 PM
