OCT FS Thread
Mr. Badwrench
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 1-1-2010, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
4) NO WTB ADS!
DSS PRO series axles for a b series in civic/integra with quaiffe...$3000 obo
WEB pro series cams with rockers and spacers $2200 obo
Tilton Carbon/Carbon. Everything but the flywheel. Flywheel bolts cam loose and got messed up along with the crank. Can be purchased directly from tilton. $2500 obo
Guest
Posts: n/a
Trying to move some of the bigger items I have laying around.
PPG Gearset 4.4 or 4.6 FD available - 5500
TAG Weather station, works like new. Logs for reference. Great for Density Altitude. 200 Shipped
Franks Fiberglass 1-piece front end with tree installed - 600
Kinsler K-140 FPR - 350
JAZ 3 gallon fuel cell - 100
And of course, my HR Roller. - 12000 for rolling chassis on stock front suspension/steelies. (Entertaining a part out)
All new parts.
B-series VTEC Block off plate has been shaved down blank and polished - 40 shipped
Vacuum Manifold - 35 shipped (If you want brass barb fittings I should be able to send ya a good amount of new ones with it)
Oil return flange with fitting (And gasket if I can find it) 15 shipped
The entire lot of parts here for 75 shipped.
Buyer responsible for paypal fees.
Bought this to have on tap, not using it. Needs to GO! It is used by the previous owner.
200 shipped. If you have to ask you don't need it lol
It doesn't have the small springs that usually comes with it, but we don't use them when they're in the car anyway.
All new parts.
H22 Turbo Manifold - $700
Built by Innovative Turbo Sysytems back in 2003. Was fully polished, bead blasted now. T4 single scroll and two bolt 38mm wg flange. Thick wall stainless steel TIG welded construction. Very durable, been used on a street car for years. I'll include an adapter to run a 44mm v-band wg. Including downpipe too.
Precision Turbo 1000cc Injectors - $200
Used, but in excellent condition.
M&H 23x7.5x15 Slicks - $150
Bought new from Exospeed last year. Less than 10 passes on them.
99-00 Carbon Fiber Hood with Custom Scoop for Full Race K24 manifold - $200
Tilton H22 Cerametallic Twin Disk Clutch - $1000
Less than 10 passes. Excellent condition. Had my machinist clean up the flywheel bolt mounting surface, it got a bit worn.
H22 CNC Ported Cylinder Head. Ported by R&D Dyno Service. - $600
Includes cam caps, rocker assemblies, shafts, LMAs, dual springs and Ti retainers. Intake #3 has full valve guides, all other ports are cut back to the port wall. I'd recommend getting new springs and retainers.
Sparco Steering Wheel with EK hub - $75
About six years old, leather pulling back a bit. Includes horn button.
Aeromotive ELIMINATOR 11104 Fuel Pumps (2 Avail) - $250 each
One has a slightly bent mounting ear. Will include fittings with that one. Other one is freshly rebuilt from Aeromotive.
full race 4" downpipe for b series pro am top mounts. Fits s372,400sx,42r sized turbos. comes with turn down.
300.
QSD balance shaft delete cover plate. 40 shipped no actual pics but is brand new. does not come with spacer
300.
Go Autoworks GT2 front mount intercooler 22x8x3.5 core, total dimensions 35x8x3.5
Used for 6 months, good for 600 horsepower(bigger than a pte 600hp)
$280 shipped in 48 states
Mini ram b series manifold
38mm 2 bolt wg flange
t3 housing flanged
VERY well made, sch10 pipe it looks like
$275 shipped, or $425 shipped with a 3" downpipe
t3 housing flanged
IF INTERESTED CALL 973)390-2982
i have a B-series shift linkages with a B16 shifter $100 each
Precision injectors 1200cc - $280 shipped in the U.S
4" aluminum exhuast $700 or best offer (prefer local pick up from north jersey area) fits a eg perfectly but u can modify to fit wat ever u want comes w/ 1 vband clamp
custom catch can sits next to the battery $250
the bracket is welded onto the battery tray*
comes with
battery tray w/ bracket welded to it
all 4 lines and fittings minus the 2 fittins on the actual block
wrinkle blue valve cover $50
comes with
Richmond Spool. Part number 836-80-1006-1. Does not come with speedo gear. Good condition.
Fits:
Integra LS/GS 1994-1999,
Civic SI 1999 - 2000
Price=$200 shipped in the states
Fits:
All parts have 1k Miles. All in perfect Working Condition
Turbonetics Ceramic Ball Bearing T-Series Turbo HP66 F1-65 A/R .68
1k milkes on Turbo. Has warantee till 02-07-2012
In perfect Condition.
561 753-7676 Land line. No text
Part # 10984BB
Will come in original box.
$800 Shipped
Crower Turbo Stg 2 Cams 63401T $350
Blox Intake manifold $160 shipped
LoveFab T3/T4Ramhorn Non AC/PS $500 shipped
Tial 38mm Waste gate red $180 shipped
CC Flywheel & stg 4 Clutch kit $390 shipped
CTR Trans LSD in perfect condition $1100 Shipped
P28 W/Neptune Chip $160 Shipped
OBD2B-OBD1 Jumper $50 shipped
B16A2 Engine harness uncut $200 Shipped
Blox 70mm TB $190 Shipped
Aluminum rad with with slim fan $120 Shipped
Samco red hoses $60 shipped
FullRace Back Door IC w/ Tial Q flange $450 shipped
Part # 10984BB
$800 Shipped
Got for sale brand new in the box parts. Prices are best offer and buyer pays shipping.
Percy's racing lexan window kit for 96-00 honda civic hatch. borders around the windows. this is a pnp kit no cutting needed, comes with all hardware and gasket for install $1000 obo shipped
Rci Fuel Cell, Drag Race Cell; Size 6 x 6 x 12; 1 Gallon $70
Waterman racing in-line fuel filters got 9 of them 5 -8 filters and 4 -6 filters $65 each
gm 3bar map $40
Skat 92mm crank New New New $450
Cp 81.5 mm 12.5:1 $275
Skat Ls Rods $200
Used Parts
Skunk2 pro gsr intake $150
Eagle LS Rod with CP 9.0:1 81.5 used but in good condi $300
Vibrant 4" muffler $80
Skunk2 Front camber 94-00 integ and 92-95 civic $100
thermal 3" catback exhaust for 94-00 integ $300
Beak Rear Tie Bar for Integ $125
kyb Agx with nuspeed sport drop $160
type r front and rear lower sway bar (rear 23mm and front 25mm) $200
open to trades.
pm me for pics but plz no window shoppers.
gm 3bar map $40
Skat Ls Rods $200
Used Parts
open to trades.
Sls 4"dp 300 shipped.
s372 standard cover bnib 50 shipped.
set of Id 1000cc injectors with top hat for b series asking $450
will get pic of asap.
jdm gsr viscious lsd all the gears are there just one gear needs reassemble. Missing a washer/shim that goes in there. all gears are good etc. asking $300
diest b series tranny blanket good condition $175 shipped.
brand new intercooler only mounted painted black. $100
Used Moroso H22a 5.5qt oil pan. Model 20912 with the kicked out sump and trap door, and the matching pickup. Tiny tiny rounded dent on the bottom from down pipe hitting it, No leaks. 300 shipped
AEM em4 96'' harness brand new in box. 200shipped.
http://www.aemelectronics.com/ems-4-...lay-panel-1221
there is the link to the harness.
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Precision 6768 Turbo HP Series i bought this turbo 3-4 weeks bolted it on the car to test fitment now i want to get a different turbo.. exhaust housing is a t4 .96 v band exit.. i will include the flange and v band clamp..i tacked the flange to my down pipe but i will take it off for you. i still have the bog it came in $1225 shipped obo best way to contact me is call or text 240-217-0647
Well time has come to part out my car...I built it last year hoping for 11s ran 10s then i refreshed the motor this year to try and run 9s but money got tight and i no longer have time to race...so got to sell it..Parting out entire car...at this time not parting out package deals...
Rolling Shell...$2000
1993 Honda Civic Hatch
Full 10pt Cage done by Fast Forward Race Cars
Momo Hub and Steering Wheel
5pt Hci Harness
10k PIC front coilovers
18k Blox Drag rear coilovers
Blox front upper camber arms
Blox rear lower control arms
Steel braided brake lines all around
Gsr rear disk
Front comes with just cx spindles no front brakes, had Gsr's with Dss 5.9 axles but sold
Trunk Mounted battery box with cables for battery
full front interior, dash has only Autometer tach with custom shift light and gauge bezle
-Clean title no rust some dings and dents but nothing major could use paint, currently flat black, no seats and no hood will come with wheels to roll on..Cage is ready to be certified for 8.50s
ENGINE...$3800
Benson Sleeved 81mm Gsr
Manley Turbo Tuff rods
Acl Race Bearings
CP 9:1 comp pistons with upgraded wrist pins
Cometic 81mm head gasket
New Oem Water pump
New Oem Oil pump
New Oem Belt
ITR stock port head
New Oem Valve guides
Supertech Springs
Supertech Valves
Supertech Retainers
Skunk2 Pro 1 cams with BDL cam gears
Blox oil sandwich adapter
Arp Head studs
MOTOR MADE 670whp @ 30psi
-ran motor for one year and blew the head gasket, then in the winter i refreshed it with all new bearings and rings and $1200 in machine work Motor was built by Armando at ILL Garage, always ran Brad Pen Oil changed every event...WILL NOT PART MOTOR OUT
Turbo Kit...$3000
Custom Bottom mount T4 manifold made by James at BMC
Bullseye S366xl turbo
Precision 46mm wastegate
Precision 800hp intercooler
Tial Bov
Stainless Steel Powder coated black 3inch piping
Vibrant couplers and vbands
OIL feed line
OIL return line
4inch down pipe with turn down
Aem 3.5 bar map sensor
Aem boost solenoid
-Everything has about 200 miles on it and all the manifold and turbo parts have been JetHOT coated and all Pneumatic lines and push quick fittings will be included
Fuel System..SOLD
Golden Eagle black fuel rail...$100
AEM EMS V2...$800
K-tuned Traction bar...SOLD
CR racing Radiator ...SOLD
Innovative motor mounts...SOLD
Blox 68mm throttle body...$100
Custom Ill Garage Catch can with lines and Powder coated Gold Valve cover...$400
Competition Twin disk used for 2 seasons....$700
White 13ich V2 drag wheels with 24.5x9x13 M/T slicks used half a season...$600
Halman manual boost controler...$100
Diest scatter shield blanket...$100
Shipping NOT included and would rather sell Local BUT will ship and i take Paypal
Im located in CHICAGO SUBURBS....
PICS and a Quick Vid..
http://www.youtube.com/watch?v=aLhbJsls_WU
5pt Hci Harness
Gsr rear disk
ENGINE...$3800
Acl Race Bearings
New Oem Water pump
New Oem Oil pump
New Oem Belt
ITR stock port head
Supertech Springs
Supertech Valves
Supertech Retainers
Arp Head studs
Turbo Kit...$3000
Tial Bov
OIL feed line
OIL return line
Aem boost solenoid
Fuel System..SOLD
AEM EMS V2...$800
FOR SALE: does not include shipping and paypal fees...
*2x- 5inch autometer tachs/ without shift lights-$50 each
*1x- str intake manifold (gsr) -$200
*1x- brand new air/air intercooler-$200
*1x- used nos bottle -$100
*1x- used pr3-3 head without cams -$300
*1x- bnib supertech valves (hevn-200f & hivn-200f) -$200
*1x- used gt4294 turbo with 128 ex. housing -$850
*1x- brand new quaife diff (gsr) its been installed into gsr tranny, never used. -$700
F/S Injector Dynamics ID1000s- I bought these new from Xenocron and used them for less than 500 miles. I ran out of fuel on the dyno and had to upgrade to ID2000s. Comes with Blue B-series hats and Obd1 plug and play clips. Asking $415 + shipping. Thanks!
