o2 question
Old Jun 11, 2003 | 09:14 PM
bottlefedb18c1's Avatar
Default o2 question
i hooked up my A/F gauge my idiol went up and down and the car almost stalled and like half of the scectrom was lit up and then when it went lean it started acting up but soon as i disconected the sigle wire thecar went back to running fine
i have a 95 DX hatch with a b18c1 but it have a 96 gsr harness in it but i am useing a obd2-obd1 convertion harness and useing a obd1 P-72 ecu
i used the convertion harness becouse i was getting a cell from a secondary o2 being missing but now there is no cell with the obd1 ecu
the o2 came fom my turbo teg and i am useing the same A/F gauge and signal wire also and i also tried a diff A/F gauge and it does the same
Old Jun 12, 2003 | 05:37 AM
anyone have any idieas?
Old Jun 12, 2003 | 01:54 PM
Default Re: (bottlefedb18c1)
i was thinking about a bad o2 but it worked fine before i took it out of my teg
Old Jun 12, 2003 | 02:06 PM
Rocket's Avatar
Your gauge may be taking to much current from the O2 sensor and thus screws up the reading. You'll need some sort of of current buffer if you want to draw the signal from the 02 sensor the ecu is using otherwise run an O2 sensor dedicated to the gage.
Old Jun 12, 2003 | 02:26 PM
Default Re: (Rocket)
but the thing is that the same sensor working in my teg and it is the same gauge would it be a bad ground on the o2 wires?
Old Jun 12, 2003 | 03:15 PM
Rocket's Avatar
yeah, maybe check the ground strap on your head.
Old Jun 12, 2003 | 06:05 PM
the ground strap to the head on top of the valve cover in front of the motor is there but i will take it off and clean it what wire on the o2 is ground maybe i and runa jumper wire from that wire to ground
would something like that work?
Old Jun 12, 2003 | 06:09 PM
Rocket's Avatar
Is this a single wire o2?
Old Jun 12, 2003 | 07:33 PM
it is a 4 wire o2 from my 95 integra gsr
Old Jun 13, 2003 | 01:43 PM
Rocket's Avatar
Hmm. Not sure what to say but check it with another O2 sensor if you have one available.
Old Jun 13, 2003 | 01:45 PM
i might just pick up a new o2 that is the only thing left thanks for your help though
Old Jun 16, 2003 | 06:55 PM
Default Re: o2 question (bottlefedb18c1)
does anyone one else have anything to add?
civic-one
Jan 16, 2010 10:38 AM
eg6civic1538
Feb 9, 2008 09:39 AM
Qwik_XR
Jul 3, 2006 06:06 AM
X2BOARD
Jul 14, 2003 09:21 PM
nortel
Feb 27, 2003 07:20 AM
