Nov FS thread
Parting my all motor setup
b series tranny case and everthing
1st 3.09
2-5 oem b16 gears
4.7 final
Mfactory lsd
asking 1750 obo + shipping
B16b long block (271 whp)
14:1 arias pistons
gsr length eagle rods
acl bearing
cc cylinder cnc ported (flows over 300cfm)
1mm intake/.5 exhaust valves
supertech retainers,dual springs, and guilds
skunk2 stg3 pro series cams
will include 4 Bosch 660 injectors
asking 3500 obo local pick up only
BMC 4.5L gsr intake manifold w/ 75mm accufab TB
asking 700 with tb
650 w/out tb
the skunk2 manifold is not fs
1st 3.09
2-5 oem b16 gears
4.7 final
Mfactory lsd
14:1 arias pistons
acl bearing
asking 700 with tb
650 w/out tb
FS: (prices plus shipping/paypal)
- Weld Magnum 2 piece skinnies, with upgraded ARP hardware ($100 upgrade). SOLD I will throw in lug nuts
- Chipped P28 SOLD
- Chipped P28 SOLD
Back up again, I was waiting on a buddy to come through but it fell through.
H & H fab ff turbo manifold
Brand new never ran
T4 twin scroll
Twin 44mm flanged
Brand new ceramic coating
Very nice piece, very thick, very heavy, high quality
I had this manifold mocked up on my old car I parted, it fit with little trimming to my oem eg core support and no modifying whatsoever to the structure of the car. Fits very well
Price is $550
plus shipping and pp
Trades interested in only really interested
Twin blue Tial 44mm gates
Precision 5858 or similar t3
Name brand 600hp intercooler or bigger
Pm or text 208-521-9397
Brand new never ran
T4 twin scroll
Twin 44mm flanged
Price is $550
1. Precision 1000cc P&H injectors. in great shape just need something bigger. $220 + shipping
2. 1988-1991 Civic/CRX turbo kit
-tig welded top mount manifold. Honda B series head flange, T3 turbo flange with a 44mm wastegate flange
-Tial 44mm black wastegate(like new)
-tig welded Wastegate dump tube
-3" tig welded downpipe
-2.5" black powder coated charge pipes with black silicone couplers and t-bolt clamps(all bead rolled)
-Tial 50mm black blow off valve
-Precision turbo 600hp bar and plate intercooler and mounting brackets.
The kit DOES NOT include a turbo or down pipe flange.
$1200 for the kit + shipping
can supply other pics, info etc.. if needed.
M&W pro14 4 channel cdi box. Purchased this past spring in 2013, never used it. Will include a harness that I made, a new female plug end with pins and grommets, 4gsxr coils, 4 cbr coils, and cdi box. It is basically new. I switched to smart coils
74.7mm inducer 100.2mm exducer extended tip compressor wheel
1.25ar, divided T4 housing, 83mm turbine wheel
$1679.50 (new)
We cut the flange off the compressor housing and were going to weld a wiggins flange on it so it needs a flange welded on to the compressor housing. Either a v-band, wiggins, elbow, etc.
Comes with oil return gasket, and divided T4 metal gasket
$900 shipped firm
Brand new, never ran.
$1679.50 (new)
$900 shipped firm
Last edited by boostedh22a; Nov 12, 2013 at 05:45 AM. Reason: Forgot to add that it was never used
Contact: Tony(at)facetuned.com
Paypal: Same as above^^^^^^
253-238-070zero
I have for sale a used hondata s300 in a obd1 vtec ecu
Does not have the BBG components but for a small fee i can add those to the board.
I'm asking $550 + shipping firm
SF 4 Bar map sensor included
B-SERIES
GE fuel rail with -10an welded to it with -6an return
1600cc FIC injectors
FJO injector driver box (not pictured)
AEM regulator
b&m gauge
Fittings welded on
asking $500 obo + shipping
IF YOU HAVE ANY QUESTIONS PLEASE CALL OR MESSAGE ME
Regards,
Tony
253-238-070zero
B-SERIES
AEM regulator
b&m gauge
Fittings welded on
Regards,
Tony
cleaning the garage again... everything came off of my 99 Honda Civic Si
i have pretty much and entire fuel system that supported over 900hp on GAS on my old set up.
Dual Bosch 044's w/ 3 filter and necessary fuel lines
$650.00
Old Stanley black housing headlights. good condition just not perfect.
$150.00
Spoon mirror (just mirror unfortunatly, what you see is what you get)
$25.00
ATI street dapener (has small chip, works fine)
$150.00
Blox 70mm Throttle body
$130.00
civic SI spoiller
$125.00
Jumper harness (works fine, been tapped into)
$50.00
text me for quick response...
(253) 376-9083
names Cole
all prices are w/o shipping, i'll ship parts out twice a week. Wednesdays & Saturdays.
Thanks for looking.
$650.00
$150.00
$25.00
$150.00
$130.00
civic SI spoiller
$125.00
$50.00
(253) 376-9083
names Cole
Thanks for looking.
4 piston racing outlaw GSR head with ferrea valve train never used still in box. Paid 3000 for the head with a ported victor x, but I don't have that manifold.
Ported for all motor use on a 85x95 setup
$2200 plus shipping
Also new in box skunk 2 ultra race manifold without the plenum spacer
All hardware included never installed
$750 shipped
$2200 plus shipping
$750 shipped
Spinwerks slicks and skinnies $1600 OBO!
Fronts 13X10 with 5 inch backspace
M&H tubes
Moroso screws (8 per side)
M&H 25/8.7/13 (at least 50% tread left)
Skinnies 15X4 (not sure on the backspace but sit flush)
M&H 24/3.6/15 (2 season on these but lots of tread)
No dry cracks in skinnies always kept inside
Call/text/pm
Nate
6127O32OO1
M&H tubes
Call/text/pm
Nate
6127O32OO1
Supertech K-series 86.5mm pistons 9.0:1cr (K20). Brand New! Comes with rings.
SOLD
Wilson 80mm TB. Mustang flanged. Brand New! Also have SpeedFactory throttle cable adapter which is included.
SOLD
SOLD
SOLD
Up for sale is my GE intake, GE fuel rail, Blox 67mm throttle body, Vibrent Vanjen clamp, ID injector top hats, and the charge pipe. Asking price is $650.00 FIRM plus shipping. As most of you guys know this is a steal. Selling because I went a different route. This setup came out of my 97 Honda Civic with a H-series. I will not split this sale up I want to sell as a package. The throttle body and charge pipe is brand new. Has seen nothing but being placed on the build. The intake I used for two events last season along with the rail. All the fab work was preformed by KS-Tuned in Washington. The BOV flange on the charge pipe is for a Tial BOV. Comes with everything shown BESIDES the fittings on each side on the fuel rail. PM me or text 262-914-4698
On the car
On the car
Hondata s300 with boost by gear $475
M&w pro10 with t1 harness,distributor,and crane ps92 coil $525
2 Bosch 044 pumps with t1 hanger and 2 aeromotive 100 micron filters $500
Liberty b series dog box Comes complete with oem case,quaiffe dif,speed factory selector,brand new revised 3rd and 4th gear sets, perfect working condition
$4300
$4300
I have a couple things for sale..
LoveFab Mini me manifold for b series, can fit a t3 or t4 turbo, wastegate flanged for 44mm.
$500.00
Tial 38mm WG used $165.00
Tial 44mm WG used $185.00
These prices does not included paypal fees or shipping.
$500.00
FS: Precision 7175 Ball Bearing. Turbo is 2 years old and works great only took it off the car to upgrade. It has cosmetic chips in the compressor wheel its been like that after the first time i ever ran it.
Ive been 9.0@167 on this turbo
It has a Open T4 .96 housing
has the H cover 4in inlet 3in outlet
Retail is $2500 im looking for 2000 OBO
Located in MD
Located in MD
(BRINGING BACK A OLD THREAD STILL HAVE THIS BEEN IN STORAGE ON A LIFT .TAKING OFFERS DONT WANT ANY HONDAS UNLESS ITS A SUV)
1996 midori green hatch cleanest original car you will find, jim justice built h22 turbo ,built h tranny ,dds axels,mw pro14 ,5 lug,aem sereis 2 ems,rywire milspec harnes,,t1 c.o.p setup with harness ,peterson external oil pump ,ferrea roller cams, blah blah blah almost all brand new nothing wrong with anything lost interest and dont want to finish it need to put the t1 c.o.p and harness in and be on your way i took the old aem c.o.p and ems out and bought new $12,000 or will seperate but i have to sell the drivetrain or shell first !!! could also sell everything i have for hondas( trannys,harnesses,rims/tires slicks/bogarts extra h22 roller cams etc) and a 2010 open car trailer with box and 9000 pd super winch for $15,000
__________________
__________________
