Nov FS Thread
Upgraded to a S400 67mm and I have no need for this one now. Comes with a .91 and 1.10 housing. Both are split and both are ceramic coated. The 1.10 is brand new. The turbo has less then 1k miles on it and spooled great on my SRT-4.
Sorry the name in my picture doesn't match, that's my name on SRTforums.com. I'm a vendor over there.
Here are pics:
Please message or e-mail me with any questions:
nigel@trudynosports.com
Asking $950 shipped for both housing, turbo, and 3.5" downpipe with v-band. Won't be a direct fit for your Honda, but will give you something build off of.
Thanks
Here are pics:
Thanks
contact me by pm or text 704-202-7943
BNIB Precision 750hp IC
just took it out of the box to measure up but ended up going with a different setup
475obo shipped! i only accept paypal and add 3%
thanks for looking
used sc61 turbo 70a/r intake and 82a/r exhaust good to 600hp. have very little shaft play, spins freely 400$ shipped
eldebrock fuel rail with liquid filled gauge will come with both fittings 130$ shipped
thanks for looking
these are obx itbs almost new, 2 track passes zero street miles. come with new pte 580 injectors,6an lines, earls fuel filter, billet regulator and b@m press gauge,custom vacum canister, lines and honda map sensor. these are a nice itb setup.
asking 600 obo for complete setup.
txt anytime 5757493103
rywire mil spec harness for b or h or d series. has plugs for obd1 injectors and obd2a or obd2b distributor and obd1 pcm. its for crx or ef chassis. i can be used in any chasis with a lil mods.
300 shipped im paypal certified
Golden Eagle sleeved GSR block, refreshed w/ no runs
84mm 14.1 comp Wiseco w/ new rings
Ls crank
Line honed
Acl coated bearings
Arp main/head studs
Eagle rods w new bolts
5.5qt pan
New oil pump
Squirter plugs
Vibrant belt tensioner
Golden eagle resurface
Assembled and ready to ship $2200. SOLD. Still have pistons rods tensioner and pan.
Ported GSR head, refreshed w/ no runs
Supertech flat coated valves
S2 pro series valve springs and retainers
New valve seals
Everything included except came
$850obo
New edelbrock 70mm TB w Honda/Acura adt plate $300obo
New CC iron man clutch kit $400
Golden eagle can gears $85 obo. SOLD
New b&m fpr $50
00 SI transmission w/ liberty cuff and type r lsd $850 obo
Virgin GSR ibare head - caps, lma included $475 obo
Liberty bseries long 1st gear
Pics coming soon... or contact me @ 239-877-0742
Ls crank
Line honed
Acl coated bearings
Arp main/head studs
5.5qt pan
New oil pump
Squirter plugs
New valve seals
$850obo
New b&m fpr $50
FS:
Avid solid mounts for b-series into ek chassis (NEW)-SOLD
RC Garage b-series timing belt tensioner (NEW)-$120 shipped
JG Sheetmetal intake manifold for gsr head-badass (NEW)-$220 shipped.
Pm me if interested, thanks.
Means of contact: PM please
Price: varies on part
Description: Just trashed my engine yesterday so im parting out everything.
Turbo kit: $2000 or sell separate for prices listed
Forward facing T4/ dual 38mm EMUSA vband gated schedule 10 stainless manifold, black ceramic coated, will come with wastegates and vacuum hoses and fittings also have 3" vband downpipe that routes under oilpan and also a side exit downpipe, will also come with both dumptubes: $800
Precision Billet 6262 T4 .68 ex housing w 3" vband, SP .70 compressor housing, has about 3 hours of run time on it, 2 dyno sessions and 2 burnouts:$750
Precision750 FMIC, one side has a 3" pipe welded over top of the original 2.75 because i was using 3" chargepipes: $275
Single aluminum chargepipe one piece from intercooler to 70mm tb on edelbrock manifold with Tial 50mm BOV: $250
#4 feed and #10 return lines with fittings: $60
EMUSA 38mm vband wastegates: $50 each
Head parts:
RLZ valvesprings/ Ti retainers: $250
Skunk2 Pro1 cams with proseries cam gears: $500
Edelbrock VictorX intake manifold, opened up for 70mm throttle body: $250
OMNI power 70mm throttle body: $80
Hondata 4bar map sensor: $80
both together: $150
Fuel parts:
Injector Dynamics ID2000, 2000cc injectors with quick clips for obd0 or obd1 plugs-$750
Weldon 2040-120 Fuel pressure regulator with #10 inlet and #6 outlet fittings, used for 2 dyno sessions and 2 burnouts: $200
Bosch 044 inline pump with #8 inlet/outlet: $120
ebay fuel rail: $50
Aeromotive inline filter with #8 inlet and #10 outlet fittings, 10 micron filter: $80
Other parts:
Hondata S300 in a P28 ecu, with boost control hardware installed and working properly: $550
OEM B16 Obd2 distributor with almost new NGK wires and Blaster SS coil: $200
Gsr transmission with LS final drive and B16 5th gear, Mfactory LSD, all carbon coated synchros, all new bearings, new 1-2 and 3-4 sliders: $1200
Powermaster Bseries manual starter: $150
B&R catchcam with all lines, fittings, black box plug, return fitting and #10 threaded welds for valve cover: $200
Head parts:
both together: $150
Fuel parts:
ebay fuel rail: $50
Other parts:
Means of contact: 804-920-2285-text or pm
Looking to get $350 OBO buyer pays for shipping.
Description: i have a barely used set of Id 1000's for sale as i have no use for them, please text me on the cell number above or pm me for any questions or info
Practically brand new Supertech dual valve springs and titanium retainers. I used them in my last build for 3 days and they have well under 500 miles on them. I will send them in the original box and I will also throw in the keepers/locks if you would like. Asking $250 shipped. Buyer will have to pay paypal fees. Thanks!
B18c/b16 applications
Part # SPRK-H100DR (85LB)
complete qsd 92-95 and 88-91 ef civic h2b kit "can fit other chasis with different post bracket"
innovative h22 sohc alternator adapter
cable to hydro conversion
custom mount to fit ef 88-91 chassis
evolution pvc adapter
all bolts and nuts!!!!
THE adapter plate has been shaved for easy acces to ballance shaft seal. everything is in great working condition.
410 shipped firm
shipped ups with tracking
im paypal certified
410 shipped firm
im paypal certified
act heavy duty pressure plate like new 11 passes $$130.00
act 4 puck bseries hydro disc has a small chip in disc $$40.00
act light flywheel $$120.00
all prices are shipped!!
i am paypal certified
new aem twinfire v2
new msd hvc blue coil
custom aluminum bracket
used msd cap
used magnecor wires
twinfire and hvc were installed but never used
360 shipped for it all. i will only part out if prices are right. no lowball offers.
5757493103 txt anytime
paypal certified
used msd cap
used magnecor wires
paypal certified
Most of these parts are brand new with only 10 dyno pulls on them, I might have more stuff but this is the most of it off the top of my head, ill get pics up asap... More to come
Web cams fcs spec,-$650 Pm me for info
Aem cam gears- $120
Comp Clutch twin disc with flywheel-$800
GE block, oringed, steped decked, needs to be bored out to 84.5, clearanced for aluminm rods comes with arp main studs-$1000
Gsr crank, nice one-$150
M&W pro14 T1 kit with 5 cbr coils-$1000
Aeromotive fuel rail-$75
T6 turbo blanket-$100
CP upgraded wrist pins-$50 pending
GSR virgin stock head-$300
Aem cam gears- $120
Whats up guys and gals so im getting out of the game so im selling my Dart b20 fully built! Runs like a champ and it has 4011 miles on the motor. I barley ran it and dont have time any more so im selling it! you can go turbo with just a piston swap!!!! Here whats for sale
IT WAS BUILT AT RACE ENGINEERING IN FL. I HAVE RECEIPTS
Dart b18 Bored and honed to 84mm
92mm Crower Crank
+.137 Eagle Rods with 2000 bolts
XTP/CP 84mm /.990 CH /+2cc / 12:0.1cp
CTR N1 Pully
ITR Oil Pump
Oil squirter bolts
All race bearings
Cometic head gasket .030
Enos Oil changes on time 3 changes sense i broke it in!
b16a head Pro Series BUILT BY JG
5 angle PnP job 298 CFM FLOW
1+mm Ferrea Valves 5000 series
Ferrea Titanium Retainers
Ferrea Springs
Jun Type 3 cams Exhaust / Intake Both
BWR Pro Comp Cam Gears / Purple
JG Victor X intake manifold
Aem fuel rail with Aem FPR
BWR 68mm Throttle body
ARP Head studs
I have Gsr Injectors on now. I sold the Rc injector to a freind who really needed them!! sorry
Small 3in round ram intake with new filter
Fluidyne Duel core radiator shorty with nice cooling fan
Jasma Race 4-2-1 header
Hondata S300 on p28 with all options! its tuned by Force Fed MotorSports In Las Vegas,NV/ 255hp 171lbs
Can include Tranny if needed but will charge for it $700!! Rebuilt LS case with GSR gears except 5th ls and light weight fodanza fly wheel and Comp Clutch 6 puck. Done by Vegas Speed In Las Vegas,NV
Im askin $6000 I have $10,000K invested in just the motor receipts for most of it PM me Thanks guys and gals Im probably forgetting stuff!!
92mm Crower Crank
CTR N1 Pully
ITR Oil Pump
Oil squirter bolts
All race bearings
Ferrea Springs
ARP Head studs
FCS 5 GALLON FUEL CELL/TANK WITH SENDING UNIT
-10 FEED -6 RETURN
Applications:
88-91 civic/crx
91-93 int
92-00 civic
94-00 Integra
MSPR IS 600 PLUS SHIPPING I WANT 400 FIRM PLUS SHIPPING AND PAYPAL FEE CALL ME FOR DETAILS 714-767-2650 JR
PS. USED TO MOCK UP IN MY CRX BUT GOING WITH A DIFFERENT ROUTE NOW
-10 FEED -6 RETURN
Applications:
88-91 civic/crx
91-93 int
92-00 civic
94-00 Integra
Guest
Posts: n/a
40' Trailer - 7500 w/16k hitch
I no longer have a race car and need this off my property for obvious reasons, to build a garage finally!
It's a 1997 Wells Cargo 40' fifth wheel.
New brakes/tires 400 miles ago
If you need a hitch, I've got a draw-tite 16k we can work into the deal. Trailer is a 16.5k GVW with upgraded axles so it only has 2.
I bought it in 2007 and it's been great to me.
I have plenty of pictures ready to email
The good:
Diamond plate floor
Winch in floor with under floor storage
Comes with a fluid/oil holder on the wall
8 D-rings (Towed 2 cars multiple times)
New tires/brakes
8' E-track
2-stair fold up unit at side door
Ramps to get really wide cars over the fenders
The bad:
Some damage on left side above fender from previous owner. I intended to fix it but it never gave me problems so it stayed. The panels are still available from wells cargo.
Shows its age here or there, but it's extremely stout and tows like a dream.
I've got a buddy that should be able to help me deliver it, I sold my truck so I can't tow it any more. I'm located in CT. It's here to look at any time.
B-series starter (GSR) 45 shipped
Water tube with fitting on the end - 25 shipped
Auto-power roll cage mount for cameras - 100 shipped
LED Autometer shift light - 45 shipped
Electronics panel - 50 shipped
Electric cutoff and relays - Forgot what I paid, but if you want them I'll look it up and cut the deal
Moroso overflow tank - 50 shipped (trimmed in a few areas, still easily mountable)
PPG B-series Trans - 4.4 FD or 4.6 FD
5500 Shipped
STUFF - LMK, I cut deal
The good:
Diamond plate floor
New tires/brakes
8' E-track
The bad:
5500 Shipped
Selling some things off my car in order to pay for upgrades. They are in exceptional shape and have been very well taken care of. Call/text 501-908-2973 for the fastest response to questions/offers.
Full-Race T3 top mount with 44mm v-band-$800
Tial MVR 44mm wastegate and dump tube-$300
Precision 750hp Intercooler with custom back door setup 3'' in 3'' out-$450
3'' Aluminum intercooler piping with tial 50mm bov flange. Fits ek/eg/dc chasis with back door intercooler and VICTOR X intake manifold. -$200
SOLD TO RICKYTAN
SOLD TO RICKYTAN
