Nov FS Thread
Old Nov 1, 2011 | 01:17 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Nov FS Thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for
RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 1-1-2010, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Nov 1, 2011 | 02:23 PM
JamaicanDave's Avatar
Default Re: Nov FS Thread
cms racing spindle mount 15x4 make offer
franks fiberglass hot rod style 1pc front end-- make offer
P29 pistons and rings 100
**items for sale do not include shipping or pay pal fees**
Old Nov 1, 2011 | 02:54 PM
rip94delsol's Avatar
Exospeed 3 piece Carbon Fiber front end 1100 obo
mark williams front brake setup 850 obo
hard race front upper camber arms 170 obo
Web Killer v tec turbo cams with all hardware including v-tec cap 1800 obo
93 si with 10pt cage with parachute mount, underbelly has been fully cleaned and prepped for paint. 2500 obo
more stuff
aero catch hood pins
tilton brake and clutch master cylinders with brake booster delete
tilton flow control valve
racepak cable to aem and motec
racepak egt setup with weld on bungs and sensors
call or text me 323 246 9570
Old Nov 1, 2011 | 03:23 PM
cteg6's Avatar
2007 16ft open trailer.... Recently put new tool box on it... Dual axle, Electric brakes, 80% thread on tires.. Weighs 1200lbs.. It's inn perfect working Order.. Bought it new..
$1800 firm.. Text for picture.. 203 455 7420
Old Nov 1, 2011 | 04:17 PM
EDLOVA23's Avatar
IF INTERESTED CALL 973)390-2982
4" aluminum exhuast $650
B-series shift linkage with a B16 shifter*
custom catch can sits next to the battery $275
the bracket is welded onto the battery tray*
comes with
battery tray w/ bracket welded to it
all 4 lines and fittings minus the 2 fittins on the actual block
wrinkle blue valve cover $100
Old Nov 1, 2011 | 04:18 PM
GT30EK's Avatar
Full Race Top Mount T4 Divided 850obo Shipped
Elbow add to wastegate for better clearance
Will trade for froward facing t4 divided manifold (like Speedfactory one) plus cash if needed
Old Nov 1, 2011 | 04:28 PM
Mo_Spec's Avatar
For sale : Clutch masters twin disc
$800 obo (would also trade for K-Pro or a K series twin disc)
Still plenty of life left on the discs I believe they are .250 thick when new and these are coming in at .240-.245
I can take more pics and more measurements just let me know.
Old Nov 1, 2011 | 05:18 PM
Joyero III's Avatar
delete
Old Nov 1, 2011 | 05:27 PM
jdm inc's Avatar
gsr quaife pretty much brand new has half a run on it.
750 shipped.
diest b series tranny blanket. 150
stock gsr viscious lsd. 300 OBO
needs new bolts and reassembled.
sls 4" dp 300obo
stock gsr valve springs and retainer -make offer.
Old Nov 1, 2011 | 05:55 PM
rmercado's Avatar
F/S ERL 5 POINT MAIN SUPPORT WITH ARP STUDS KIT..$350 SHIPPED
F/S FULL BLOWN FUEL RAIL WITH -10AN INLET -8AN OUTLET FOR B SERIES $120 SHIPPED
Old Nov 1, 2011 | 06:05 PM
haas480's Avatar
Full-Race B Series Front Mount turbo manifold.
t4 twin scroll w/ dual 44mm waste gate flanges.
$750.
Old Nov 1, 2011 | 06:24 PM
Casey's Avatar
Mini ram b series manifold
38mm 2 bolt wg flange
t3 housing flanged
VERY well made, sch10 pipe it looks like
$375 shipped with a 3" downpipe
<br /><br />
Old Nov 1, 2011 | 07:06 PM
slowboy90's Avatar
Means of Contact (PM? Email? Phone?): 336-345-2666, pm
I have my current race motor forsale
85mm aebs ls block
ls crank
brian crower race rods
wiseco pistons
acl race bearings
oem honda oil pump, new oem water pump
gates kevlar belt
blox cam gears
b16 head ported
supertech valve springs and retainers
gsr cams
cometic gasket
golden eagle head studs
aebs intake manifold
fic 1650cc injectors
3200 obo all you need is a dizzy and tb to make it run car made 710 on 28psi on a t3 s366
also forsale
t3 s366 race cover polished vband exhaust housing
sls t3 divided twin gate top mount
2 44mm tial wastegates
and a tial bov
also have itr pistons on gsr rods with arp rod bolts make offer
fully adjustable shift light make offer
i may have a bare gsr head forsale disassembled
aem 1040
also have a 4 in downpipe for a top mount into dc2 flex with vbands on both ends tig welded stainless
and dss 5.9 axles with hubs and studs for gsr spindles
brian crower 95mm b series crank with rods and 84 or 85mm (cant remember size right off) cp turbo pistons
84 or 85mm aebs sleeved ls block fresh line hone with erl 5 point main girdle
new just installed vis carbon hood and trunk with glass for dc2
18k skunk2 rear drag springs
exospeed 3 piece front for dc2 bnib
text for pics ill update as i go through my parts
http://s1126.photobucket.com/albums/l616/slowboy90/
Old Nov 1, 2011 | 08:54 PM
cloviskilla's Avatar
rywire mil spec harness for b or h or d series. has plugs for obd1 injectors and obd2a or obd2b distributor and obd1 pcm. its for crx or ef chassis. i can be used in any chasis with a lil mods.
300 shipped im paypal certified
txt anytime 5757493103
Old Nov 1, 2011 | 09:15 PM
these are hseries obx itbs almost new, 2 track passes zero street miles. come with new pte 580 injectors,6an lines, earls fuel filter, billet regulator and b@m press gauge,custom vacum canister, lines and honda map sensor. these are a nice itb setup.
asking 600 obo for complete setup.
Old Nov 1, 2011 | 09:55 PM
acrite1999's Avatar
im selling my weldon pump 2035a if anyone is intrested...had it on my race car for about 200 miles and decided to part it out...made 895hp and had alot of fuel left...im letting it go for 580 shipped...i paid 820 so the price is fair..u can reach me at 305 281 6495 if intrested
also selling my k series DSS 5.9 axles out of my race car for 1300 shiped....these axles are the ultimate axles that are un breakable lol....they have about 200 miles on them and are still in very good condition and have alot of life left... if intrested u can reach me at 305 281 6495,,they come with the hubs/arp extended wheel studs and axles....
Old Nov 2, 2011 | 02:44 AM
josh green's Avatar
I am located in GA and will only ship to the continental United States. All other shipping will be at buyers expense. You can contact me at 706 266 7294 for a quicker reply. I don't have internet access while working.
Golden Eagle intake manifold gasket for GSR $20
TurboSmart Supersonic BOV with flange $150
Virgin type R valve cover $100
Golden Eagle LS/vtec kit (all parts minus headgasket) $150
Golden Eagle head studs (torqued once) $100
Type R tranny that has a b16 quaife lsd in it. Note: the factory diff is GSR/TypeR sized. Bought the diff from someone and it wasn't what they said it was, so I had to put in B16 sized FD $1000
Will separate.
Tial MV-R 44mm wastegate all flanges and hardware included, can also include a dump tube. $300
Old Nov 2, 2011 | 07:53 AM
matkeller's Avatar
for sale:
used quaife LSD for a hydro b16/ls, includes bearings and speedo gear, attached as shown in picture. $525 shipped.
circuit worx spool differential for k-series, comes with bearings and speed gear as pictured. $400 shipped.
innovative 3-piece engine mount set for 2006-2011 civic si, these were already installed and used for a few thousand miles, front mount holes had to be opened to fit as shown in pic. $225 shipped.
Old Nov 2, 2011 | 08:07 AM
Will_H's Avatar
F/s MT 24.5 x 9 x13 et drags lots of life left 20passes $200!
F/s m&h 3.5 x 22 x 15 lots of life left! $175! one tire is showing what looks to be a cord pushing through on the side wall. I called M&H and they said it should be fine. They held air fine, i opted to remove them for safety reasons. This is only one tire that has a issue other is perfect!
Hasport B-series Integra mounts no inserts, auto to manual trans mount. $125 for all 3!
Old Nov 2, 2011 | 08:28 AM
mangina's Avatar
15x8 spinwerkes 4"backspace(clear gsr brakes) $420 shipped
Old Nov 2, 2011 | 10:57 AM
illassek9's Avatar
i am the first and only owner of this block...there are NO stripped bolts anywhere on the motor... buyer will be provided with receipt form golden eagle... (786)
236-6751
b20 sleeve block $1700 OBO
Golden eagle 84mm hd sleeves with o ring deck
9:1 arias pistons 84mm
Eagle 2000 big bolt rods
Acl race main barings
Acl race rod barings
Acl thrust washers
Ls crankshaft
Micro polish crankshaft
Golden eagle sandwich plate
OEM timing belt
OEM type r water pump
OEM type r oil pump
Gsr oil pan with -10 for oil return
Golden eagle head studs
when block was new and first put together!
Old Nov 2, 2011 | 11:45 AM
Joyero III's Avatar
Mase Turbo Kit S2000
Turbo Manifold T3
Tial Q BOV
Tial wastegate
Heat shield
Down pipe
Recirculating dump tube into downpipe
Open dump tube
Precision Intercooler
All cuplings and clamps
Oil pan with welded bung
No turbo or oil lines
No Intake charge pipe.
$2500 Shipped
Old Nov 2, 2011 | 01:10 PM
vtec_killer_'s Avatar
All prices are without shipping or paypal fees. Will send pics
please text me with questions.. phone # (909)648-3810
MOTOR::::: Everything is Brand new, Long block had a start-up when built by Bob McCray
H22 900 hp custom built motor
Golden eagle manifold (Brand New) $SOLD
golden eagle fuel rail (Brand New) $100
BoB Mckray ported and polished head
ferrea valves and springs retainers
JE custom 9.5.1 dish pistons
Custom H-beam rods
Darton sleeved block
custom belt pulleys
motor blueprinted and balance by CLU
clevite bearings
Drive oil pump
moroso oil pan
fidanza enlighten flywheel
Scatter shield
brand new starter, alternator
hyper stage 6 clutch
heavy duty pressure plate
$3500 for motor and trans
3 sets of h22 to EG axles (hasport, custom, Driveshop) $175 each or $350 for 3 sets
Lenzo vpd wheels with 24.5 x 9 and skinnies $900
skunk2 pro rear lower control arms. $150
H22 EG Hasport motor mounts- $300
skunk2 70mm throttlebody with 4 bar map sensor (brand New) $300
aeromotive fuel pressure reg $150 brand new still in package
brand new never ran SYNAPSE turbo manifold t3/t4 $700
brand new PRECISION t3/t4 turbo 6765 billet wheel h cover $1000
HONDATA S300 IS SOLD
innovative lm-1 wideband $250
TIAL 44 wastegate $200
1680 cc injectors (bosch) $250 shipped
880 cc precision injectors included $150 shipped
http://i152.photobucket.com/albums/s...isionturbo.jpg
http://i152.photobucket.com/albums/s...sion1turbo.jpg
http://i152.photobucket.com/albums/s...n/4bffeb15.jpg
http://i152.photobucket.com/albums/s...n/0a07ce03.jpg
http://i152.photobucket.com/albums/s...n/IMG_0009.jpg
Old Nov 2, 2011 | 04:01 PM
crazyjetsfan22's Avatar
Parting out whats left of my Friends SFWD car.
Located in Westchester County NY
Phone number to text 914 755-4156
Please state what you are interested in buy when texting.
Please do not waste my time
Full built ITR head $1000
Comes with Skunk 2 Stage one Cams
Adjustable Skunk2 Cam gears
Crower Valve springs, Retianers
Supertech Valves
Brand new seals
Full Race Pro Am Manifold + down Pipe $1500
T4 , Single scroll, 44mm Gate
Down pipe is Vband 3” to 4” with burns muffler
P72 Ecu with S300 SOLD!!!
M&W Pro 10 SOLD!
[b]Competition B series Twin Disk SOLD
Dss 3.9 Axles with hubs SOld!!!!
[b] Valve cover and Breather Box set up SOLD!
Victor X manifold SOLD!
BBK 70mm Throttle body $ 130
Hondata 4 Bar map is sold!
[B] 3 manley Turbo Tought Rods with Je pistons SOLD!!!
ITR shift linkage $150
Comes with skunk 2 dual bend and Hasport Bushings
Old Nov 2, 2011 | 04:57 PM
T76U13ALT's Avatar
Up for sale is a used Tial MVR 44mm wastegate, it comes with both flanges and both clamps but I lost the screws for both of them. I'm asking $270 shipped in the USA.
Springs inside are Grey+Gold+Brown..
i](
)[/i]
