Is this normal piston wear?
Old Nov 21, 2009 | 04:17 PM
85mmek9's Avatar
Default Is this normal piston wear?
Tearing apart the motor and getting ready for next year, this was my first season and I noticed the pistons having crazy wear! Its like this on most the piston skirts but not all, is this normal, or is somthing poss to loose, wrong etc....
Old Nov 21, 2009 | 04:22 PM
1quicklaser's Avatar
Default Re: Is this normal piston wear?
Looks like the piston to wall clearances are off.
Old Nov 21, 2009 | 04:24 PM
Beww's Avatar
thats not normal at all
Old Nov 21, 2009 | 04:32 PM
BEAVERTOOTH's Avatar
Looks good to me if your reving to 11 grand
Old Nov 21, 2009 | 04:46 PM
85mmek9's Avatar
shifting at 10-10.2k. Had a couple 3rd to 2nd shifts that went to like 12.5! Are these still usable? Going to change the rings also, number 3 was only 100psi
Old Nov 21, 2009 | 04:50 PM
josh green's Avatar
Looks like the p/w was too tight, or possibly from the miss-shifts.
Old Nov 21, 2009 | 04:53 PM
sewell94's Avatar
You wouldn't want to reuse those.
Old Nov 21, 2009 | 04:56 PM
swapit's Avatar
p/w was to tight and they will make a great paper weight now..get a new set and check the cylinder walls and make sure they are still round top to bottom.should set p/w no tighter then .0045
Old Nov 21, 2009 | 06:05 PM
ShawnR's Avatar
lol i have a set that looks like that wont use that machine shop again
Old Nov 21, 2009 | 06:08 PM
HondaKyle's Avatar
FIND A NEW PLACE! or dont build the motor your self...
Old Nov 21, 2009 | 06:10 PM
Mr. Em1's Avatar
those look very nice, use them again, they will seal up nice!lol get some new slugs my friend and def make sure those cylinders are still in good shape.
Old Nov 21, 2009 | 06:15 PM
RaceProfessor's Avatar
How does the walls look? Any scarring?
Old Nov 21, 2009 | 07:09 PM
k_civic's Avatar
That means a new set of piston :S
Old Nov 21, 2009 | 07:28 PM
TypeRfit's Avatar
RESIDENT
those are trashed. Anyone up for new paper weights?
Old Nov 21, 2009 | 08:56 PM
Flip over and instant ashtray
Old Nov 21, 2009 | 11:47 PM
85mmek9's Avatar
The walls look fine, as i can see, im going to take to the machine shop to make sure etc... only thing I could think of is aebs messed up on the bore size right?
Old Nov 21, 2009 | 11:51 PM
king06's Avatar
I'm guessing that you send them the pistons with the block, if so, yes they did mess up.
Old Nov 22, 2009 | 08:11 AM
dester223's Avatar
Damn,
I see that when P/W clearances are off
or heavy detonation/REALLY bad tune.
Have you changed your wideband sensor lately?
Old Nov 22, 2009 | 08:24 AM
NAH2B's Avatar
wrong forum, please move to FI.....
Old Nov 22, 2009 | 08:41 AM
mar778c's Avatar
Community Builder
Community Influencer
PW clearance is too tight. How much whp is this motor making? Also, what do the tops and the chambers look like?
Old Nov 22, 2009 | 09:18 AM
nonvtecallmotor's Avatar
The block needs to be bored and honed again. I'll bet that it was detonation....
Old Nov 22, 2009 | 09:24 AM
lohatch's Avatar
either the PtoWall was too tight or the tune was off. those are junk
Old Nov 22, 2009 | 04:15 PM
85mmek9's Avatar
There was no detonation and my wb sensor is good, not that old, using an fjo. taking the block to the machine shop and ill let you know the final outcome.
Old Nov 22, 2009 | 04:18 PM
HR-1320's Avatar
nOT LIKELY, tOO TIGHT OR LOST LUBE.
Old Nov 23, 2009 | 02:00 AM
extralargenog's Avatar
p2w was fuxored... Detonation would have shown on top by Pitting of the pistons
