NLR ams 1000 setup
Old May 18, 2011 | 06:16 AM
hello1320's Avatar
Default NLR ams 1000 setup
so i put the clutch input on a momentary sw on the steering wheel and the activation sig on a toggle sw.... so the activation sig starts the timer and the data log....and hitting the clutch sw resets the timer..... is this how it goes..
Launch mode...... so if i set up the s300 to make lets say 15 psi on the antilag and set the launch psi at 6 psi... it will leave at 6 psi???? the car has a 14 lb spring.... i dont think this will work??? or should i just set up the antilag to make the psi i want to leave at.
also when i go to setup the first stage it always shoes 0 psi on the boost veiwing graph untin the end of the stage where it then ramps to the target psi..... dont think this will matter cause its not going any lower than 14 psi cause the spring.... what do u think ??
98.4DR.EK.D16
Sep 3, 2012 03:59 PM
Bobby_Budds
Engine Management and Tuning
Apr 28, 2012 02:21 PM
hello1320
May 26, 2011 01:27 PM
mike93boost
Jun 7, 2006 06:26 AM
