Next step?
Old Jul 27, 2003 | 07:37 PM
SadisticRacing's Avatar
Default Next step?
I've been running my 90 CRX with B16a1- I/H/E and 75-shot of NOS in the high 13's. Just bought slicks and was wondering what you guys think my next step should be to get to mid to low 12's? Here's my last timeslip(right Lane#205)!
Modified by SadisticRacing at 9:37 PM 7/28/2003
Modified by SadisticRacing at 9:38 PM 7/28/2003
Old Jul 28, 2003 | 08:43 PM
Default Re: Next step? (SadisticRacing)
Someone here has to have some advice as to how I can hit 12's.
Old Jul 29, 2003 | 12:10 AM
flip1199's Avatar
what size slicks did u get? was that run on slicks? if so then you need to work on your 60ft
Old Jul 29, 2003 | 07:20 AM
AussieK24's Avatar
What header are you running? What size slicks? I dont think slicks will get you all the way to 12's...
Edit: 13.7 to low 12's is a H-U-G-E jump for a B16a
Old Jul 29, 2003 | 07:26 AM
slowcivic's Avatar
New User
In order to get into the Low 12s, your 60' needs to be in the 1.7 to 1.6 sec. Practice launching. Work on your suspension setup. You can do it! Good Luck.
Old Jul 29, 2003 | 12:46 PM
Default Re: Next step? (slowcivic)
That run was on my street tires. The slicks are 24x9x13 Goodyears.
I'm running a DC Sports 4-1 Header and I know that low 12's would be hard but just want to see a 12.?? (.99 would work but looking for a .75 at least)
Old Jul 29, 2003 | 12:51 PM
MaxBoost's Avatar
New User
Those slicks are kinda big, but regardless...
Run open header.
Run a bigger shot.
Use those slicks.
If I were you I'd build up a 1.8+L bottom end for nitrous, and then throw it back into the car and up the shot big time. Also get a better header, and keep throwing mods at the motor and suspension.
Old Jul 29, 2003 | 02:53 PM
flip1199's Avatar
i'd say try some 22 or maybe 23 x8's. I don't think you have the power for those slicks just yet.
Old Jul 29, 2003 | 03:23 PM
Mr Hammond's Avatar
a/k/a Jomo
I'd practice launching. Your 60' times should be WAY down. You are only trapping 98mph. Aint gonna get 12's with that.
Old Jul 29, 2003 | 03:30 PM
Default Re: Next step? (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">I'd practice launching. Your 60' times should be WAY down. You are only trapping 98mph. Aint gonna get 12's with that.</TD></TR></TABLE>
I'm in the right lane, trap is 104.845 and 13.7 on street tires!!
Old Jul 29, 2003 | 08:26 PM
Mr Hammond's Avatar
a/k/a Jomo
Whoops. Well your traps are there for atleast low 13's, get some slicks and pull 1.8's and you are there easy. High 12's should be there after practice.
Old Jul 30, 2003 | 07:08 PM
I'm wondering if I got a V-AFC and had it dyno tuned if that would help maybe hit my goal for this season of 12.75?
Old Jul 30, 2003 | 09:13 PM
blah13's Avatar
Certainly tune it, you will gain a good bit of hp and a smoother powerband. Tuning should be looked at as the #1 priority with any race motor be it drag, auto-x, rally etc. Not only does it maximize the power that can be produced but it has a direct effect on the life of an engine.
Old Jul 30, 2003 | 10:11 PM
accordking's Avatar
your B16 won't be very reliable with stock pistons and big slicks. Don't even mess with a higher dose of N2o.
Old Jul 30, 2003 | 10:13 PM
accordking's Avatar
Default Re: Next step? (accordking)
go with a bigger block like a 1.8 or 2.0. B16's are too weak in stock form.
Old Jul 31, 2003 | 11:42 AM
How does this sound first buy V-AFC and have it tuned, second install the CTR pistons and rods I just bought and third put the CTR cams in. Whould that get me to my goal?
UNDER PRESSURE
Apr 21, 2003 03:25 PM
slowassgsxr750
Mar 11, 2003 11:57 PM
civicqm
Dec 7, 2002 02:37 PM
ActiveAero
Dec 7, 2002 12:43 PM
HX_Guy
Jul 14, 2001 10:37 PM
