need some help with tires.
Old Mar 15, 2007 | 12:39 PM
honda06si's Avatar
Default need some help with tires.
ok i drive an 06 civic si thats turbocharged pushing about 400whp. i cant get taction ever. so ive been in the market for some new tires for awhile now and ive asked this in other forums about which tire is best for drag racing because i go to the track almost once every week and i want to be able to get traction. well alot of people said the falken rt-615's so i was about to order those and someone said those are only good for auto-x. other people said bfg drag radial TA's. but i want to know what you guys think is better. because i was about to order the falkens like 10 min ago. and now someone said not to
Old Mar 15, 2007 | 12:43 PM
ExospeedAMcrx's Avatar
Default Re: need some help with tires. (honda06si)
those tires are not really made for drag racing. you have to either use specific Drag radials or slicks for the track for best results.
In your case, I doubt you will be able to run slicks, due to the rim size you are using. I'm assuming you're at least a 16" rim and if not most likely a 17" rim. The newer Civic and RSX, I know have bigger brakes and cannot use a 15" rim unless you downgrade on the type of calipers you use.
I'm not familiar much with Drag radials over 15", but I believe that Nittos make drag radials in 16" and possibly 17". check those out. thats most likely what will be best in your case.
Old Mar 15, 2007 | 12:53 PM
underpressure02's Avatar
If you want drag radials alot of the guys on our team run the hoosier DR on their turbo rsx's and have good luck with them.
Old Mar 15, 2007 | 01:00 PM
honda06si's Avatar
Default Re: need some help with tires. (underpressure02)
alright yes i have 17' rims. and also please provide a link or somethign.. haha im not lazy its just ive never bought tires before in my life.
Old Mar 15, 2007 | 01:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda06si &raquo;</TD></TR><TR><TD CLASS="quote">alright yes i have 17' rims. and also please provide a link or somethign.. haha im not lazy its just ive never bought tires before in my life.</TD></TR></TABLE>
Sent you a pm
Old Mar 15, 2007 | 01:46 PM
honda06si's Avatar
ok i guess im stuck between the bfgs and the nittos ...someone put their input or experience
Old Mar 16, 2007 | 12:48 PM
BoostedJeff's Avatar
i would hands down go wtih BFGs over Nittos. You will go through drag radials quickly regardless of which ones you get. I went through a set of 225/50/15 BFGs in a month and a half.
Old Mar 16, 2007 | 12:58 PM
Boner_Ben's Avatar
Default Re: need some help with tires. (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">i would hands down go wtih BFGs over Nittos. You will go through drag radials quickly regardless of which ones you get. I went through a set of 225/50/15 BFGs in a month and a half.</TD></TR></TABLE>
I got 10k miles out of my bfg's
Old Mar 16, 2007 | 01:05 PM
Default Re: need some help with tires. (Boner_Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">I got 10k miles out of my bfg's </TD></TR></TABLE>
lol.. you drove like a grandmother unless you were racing!
Old Mar 16, 2007 | 01:22 PM
VisualAutoMotoring's Avatar
If your planning to run BFG drag radials in a 17", the only size available is 225/45/17 and you may run into a clearance issue.
If your interested PM for a price.
Old Mar 16, 2007 | 09:45 PM
dunkd's Avatar
1200 miles on mine no sitting burnouts either, leaving marks in 3rd and 4th gear all day long though!
Old Mar 16, 2007 | 10:26 PM
integrawow's Avatar
I'd say go with a drag slick such as the one that M&H sells.
Jeg's part# is 676-MHR-03 and the specs are 8.0/22.0/13.0. Jeg's sells them for $119.99 ea. I'd say that this will get you a fair amount of traction without adding a whole lot of excessive weight. Just get a 13" diameter wheel and you should be good to go.
Also, ZEX ran this tire on their civic test car. Check out zex.com and take a look under their project vehicles page. The blue civic has this tire, and ran some decent numbers with it.
Good luck with your car!
Old Mar 16, 2007 | 10:47 PM
dunkd's Avatar
Default Re: (integrawow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrawow &raquo;</TD></TR><TR><TD CLASS="quote">I'd say go with a drag slick such as the one that M&H sells.
Good luck with your car!</TD></TR></TABLE>
good luck putting a 13" rim on an '06 si
Old Mar 16, 2007 | 10:53 PM
integrawow's Avatar
I don't own a Civic Si, nor will I ever care to own one. Just get what fits, but try to use an all out drag slick if possible.
Old Mar 17, 2007 | 06:21 AM
well since I assume he is planning on running whichever tires he gets on the street, I wouldn't suggest getting a full slick.
Old Mar 17, 2007 | 11:41 AM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrawow &raquo;</TD></TR><TR><TD CLASS="quote">I don't own a Civic Si, nor will I ever care to own one. Just get what fits, but try to use an all out drag slick if possible.</TD></TR></TABLE>
He is asking for a tire to fit his FG.
dbb95ex
Jan 10, 2014 07:14 PM
accord99power
Jun 5, 2009 08:25 AM
TypeR1558
Jul 9, 2002 08:08 AM
austrian type-R
Aug 5, 2001 07:02 PM
