Need some help picking slick size
Old May 18, 2005 | 08:32 AM
getnasty's Avatar
Default Need some help picking slick size
Alright guys a little info.
crx with sohc pushing around 225 to 400 whp. the reason I say up to 400 is because the block is going out in a few weeks to get sleeved. so what size slicks should I get? im ordering 13x8 lensos today and have no idea what size slick to order. I will be ordering these from M&H tires. so thanks for the help
Old May 18, 2005 | 08:57 AM
getnasty's Avatar
Default Re: Need some help picking slick size (bottle fed)
also am I going to need to buy tubes also?
Old May 18, 2005 | 01:02 PM
getnasty's Avatar
BUMP
Old May 18, 2005 | 01:06 PM
Turbo-charged's Avatar
check out the SPFWD thread. nobody knows what size slicks to buy any more.
to help a little bit if you dont care about competing.....
ive had best luck with mickey thompson 24.5x9x13
runner up is 25x8.7x13 M&H.
both tires are now illegal on my car in the spfwd class for nhra
Old May 18, 2005 | 01:20 PM
getnasty's Avatar
Default Re: Need some help picking slick size (Turbo-charged)
its all good Im not running in any class lol.. just a street car it wont be fast enought to compete
Old May 18, 2005 | 06:59 PM
getnasty's Avatar
UP
Old May 18, 2005 | 07:33 PM
DaveF's Avatar
you might want to take into consideration, the GEARING in your trans, to "aide" you in choosing a properly sized slick. your "usable" powerband, would also be a good thing to know, when choosing a slick size
here is the gear speed calculator, i know that it doesnt have a d series trans in it. but you can change the gear ratios for each individual gear. hopefully this will help
http://autocrossing.com/cgi-bin/gearcalc.cgi
Old May 18, 2005 | 08:21 PM
getnasty's Avatar
Default Re: Need some help picking slick size (Dturbocivic)
thanks.. I will be using a 91 crx si trans.. anybody have any preferances?
Old May 18, 2005 | 08:23 PM
getnasty's Avatar
I tried it but it still dosent say what size slick.. but thanks for trying
Old May 18, 2005 | 09:41 PM
SlicksMH's Avatar
Old May 19, 2005 | 10:22 AM
getnasty's Avatar
who uses tubes and who dosent?
Old May 19, 2005 | 12:47 PM
getnasty's Avatar
someone told me 8/25-13 and I dont know.. I can see me coming off the 2 step at 6K and breaking the axles. HELP
Old May 19, 2005 | 01:11 PM
SlicksMH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottle fed &raquo;</TD></TR><TR><TD CLASS="quote">someone told me 8/25-13 and I dont know.. I can see me coming off the 2 step at 6K and breaking the axles. HELP</TD></TR></TABLE>
Hi bottle fed;The best thing you can do when you get slicks is HIGH AIR PRESSURE. Lets say if you buy like my 8/25-13 I would start @ 15-psi and get the feel of the slicks, you will spin but you will have a less chance of breaking a tranny or a half shaft. Spinning can be a fun thing, you can get use to controling the car and the throttle @ the same time and that my friend is what you call back pedaling down the track and believe me you will need that expertize some day when you pick up HP. When the time comes and you are ready to rock, drop down the air pressure 1-psi @ a time untill you feel the car start to hook up. Stop right their and start playing and have fun.
GOOD LUCK in 2005 bottle fed be safe.
John@M&H-Hashims
CHRIS S
Sep 10, 2009 09:32 AM
gsrt
Sep 19, 2006 08:57 PM
megotvtec
Aug 16, 2004 05:43 PM
slwburn
Jun 19, 2003 02:59 AM
CM-R
Jun 10, 2003 09:03 PM
