need help from the pro's
Old Feb 26, 2006 | 01:39 AM
ISPhuevos's Avatar
Default need help from the pro's
ok i have a 91ef four door i am doing my own enigne harness i am using a ek (cause they wire up straigh through sensor to ecu) and wiring it up to a p28. i wired it up sensor by sensor,now i have a problem with power,ground, start sigal. i need to know were dose the starter signal wired up to ( race car nothing inside i have my own relay dont have main relay) that really what i need cause the car start but then turn off. thanks
Old Feb 26, 2006 | 05:51 AM
DaveF's Avatar
Default Re: need help from the pro's (ISPhuevos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ISPhuevos &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a 91ef four door i am doing my own enigne harness i am using a ek (cause they wire up straigh through sensor to ecu) and wiring it up to a p28. i wired it up sensor by sensor,now i have a problem with power,ground, start sigal. i need to know were dose the starter signal wired up to ( race car nothing inside i have my own relay dont have main relay) that really what i need cause the car start but then turn off. thanks</TD></TR></TABLE>
your start signal wire would be the pigtail that connects to the starter. take that wire and run it to a start button(momentary switch) then run the other side of the momentary switch to the fuse block.
Modified by Dturbocivic at 6:40 PM 2/26/2006
Old Feb 26, 2006 | 06:48 AM
Dragline's Avatar
Default Re: need help from the pro's (Dturbocivic)
Just test your ignition switch outs and find your cranking only 12 volt source, and run it straight to the starter solenoid on the starter
Old Feb 26, 2006 | 06:31 PM
ISPhuevos's Avatar
Default Re: need help from the pro's (Dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dragline &raquo;</TD></TR><TR><TD CLASS="quote">Just test your ignition switch outs and find your cranking only 12 volt source, and run it straight to the starter solenoid on the starter </TD></TR></TABLE>
car start but,its dosent stay on. i have to keeping playing with the gas pedal. if any one can help me if find a diagram, how race car wire up there cars the only thing i found was skunk car with the k completelly different. Thanks your help (everyone)
Old Feb 27, 2006 | 02:24 AM
DaveF's Avatar
car start but,its dosent stay on. i have to keeping playing with the gas pedal. if any one can help me if find a diagram, how race car wire up there cars the only thing i found was skunk car with the k completelly different. Thanks your help (everyone)</TD></TR></TABLE>
are you using the stock column with the factory ign switch???? if so. the factroy switch is labled. ST for start, and i belive its the thick black/ yellow wire.
Old Feb 27, 2006 | 05:40 AM
Dragline's Avatar
Don't you have A service manual, they have wiring diagrams for the entire car.
Old Feb 27, 2006 | 05:01 PM
ISPhuevos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
no i am use my own switches, i got the with nothing in side no interio harness so i am running my fuse,relay,relay and switches (thanks to my job kargens) i do have wiring diagram but dose are made to wire up to factory harness which i dont have
Old Feb 27, 2006 | 07:29 PM
Dragline's Avatar
no i am use my own switches, i got the with nothing in side no interio harness so i am running my fuse,relay,relay and switches (thanks to my job kargens) i do have wiring diagram but dose are made to wire up to factory harness which i dont have </TD></TR></TABLE>
Your useing A P28 so the factory diagrams are what you need to go by.
Old Feb 27, 2006 | 10:49 PM
ISPhuevos's Avatar
QUOTE=Dragline]
Your useing A P28 so the factory diagrams are what you need to go by.[/QUOTE]\
i know just dont know if i need to wiring up every thing (clutch switch, fuel pump has it own relay) little thing like, i know iam just rockie at this. expletive if can build 247hp 2.0L then i can do this it just the little things that are side tracking me
allenlavoie
Mar 31, 2012 05:58 PM
jdm5596
Feb 18, 2008 01:55 PM
vtecpowa92
May 30, 2007 09:12 PM
