Need help hooking up!!!
Old Oct 9, 2004 | 08:49 AM
snowseeker's Avatar
Default Need help hooking up!!!
Right now I am running a b16 with CTR internals, ported an polished head, exaust, CTR cams, ITB's.
For suspention I have just coil overs for now, the rest is stock, no sway bars. Running on 13" weld drag lites wraped in M&H 20X8 slicks with 16 psi. No traction what so ever out of the hole.
Now, next year I will be running a 2.0 dart block with my b16 head ported and polished even more with either skunk 3 cams or cower roller cams. I have a litened, knife edged, and balanced crank with eagle rods and CP 12.5:1 pistons. 954RR ITB's, header, exaust, and a fogger.
Haven't made up my mind if I want to do hondata or go with a totally diffrent system like AEM and MSD.
what do you guys sugest I run for a suspention setup to get this 1780 pound crx out of the hole on nitrous?
I am going to get traction bars for sure. I really don't want to do the wheelie bars/track bars? out the back of the car.
Are the avid traction bars any good? I notice they only use one bolt to the A arm. Does the full race bar use both bolts?
Old Oct 9, 2004 | 09:31 AM
snowseeker's Avatar
Default Re: Need help hooking up!!! (snowseeker)
Another quick question, what gear are you guys with slicks doing your burnout with? How do you hold you cars back with slicks when doing a burnout? I don't have my E brake anymore but i do have a pair of line locks for the rears. I think the rear of the car is to light because the slicks will drag the rear tires when i do my burnout.
Old Oct 9, 2004 | 12:06 PM
jdmoutlaw's Avatar
Get the fulrace bars, I like those.
2nd gear burnout use your line lock and start in the warter.
Old Oct 10, 2004 | 07:16 AM
snowseeker's Avatar
Default Re: Need help hooking up!!! (jdmoutlaw)
Do the fulrace bars use both of the bolt holes on the A arms?
Old Oct 10, 2004 | 01:23 PM
ms1motorsports's Avatar
Probably need to step up to 24.5" soft compound slicks. 20's seem too small. Should help a little.
Old Oct 10, 2004 | 03:12 PM
The Monkey's Avatar
With the motor and NOS u are going to be runing A MnH 24 on a 13 wheel will be a great idea .
I agree with richie with the sec gear burnount , trust me a 1st to secound burnout KILLS syncros . Richie rebuilt our trans for us .
And also invest in a spool , no jdn diff , no quafe , and deff no phantom CRAP.
Old Oct 10, 2004 | 06:54 PM
snowseeker's Avatar
Default Re: Need help hooking up!!! (The Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Monkey &raquo;</TD></TR><TR><TD CLASS="quote">
The diff. was another delema that I have. I would like to drive the car on the street yet. Does anyone make a good locker for the Y1 tranny? I wouldn't mind running a spool but I hear they pull alot on the street.
Old Oct 10, 2004 | 07:40 PM
SlicksMH's Avatar
For suspention I have just coil overs for now, the rest is stock, no sway bars. Running on 13" weld drag lites wraped in M&H ( 20X8 ) slicks with 16 psi. No traction what so ever out of the hole.
Hi snowseeker; Do you mean 8/22-13 and what is your HP.
John@M&H-Hashims
I am being called to the dinner table, and I will get back with you.
Old Oct 10, 2004 | 07:49 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Here are some pics of the Full-race EF bars, and yes they do use both holes.
Hope this answers your questions man. Best of luck with getting the traction you need
Clayton
Old Oct 10, 2004 | 07:54 PM
snowseeker's Avatar
Default Re: Need help hooking up!!! (SlicksMH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlicksMH &raquo;</TD></TR><TR><TD CLASS="quote">For suspention I have just coil overs for now, the rest is stock, no sway bars. Running on 13" weld drag lites wraped in M&H ( 20X8 ) slicks with 16 psi. No traction what so ever out of the hole.
John@M&H-Hashims
Yes maybe they are the 22's, I haven't looked at them in awhile.
I am not sure what to expect for HP on the new motor yet. I am guessing around 280 - 300 at the crank NA.
I am at the very very top of fourth gear (8400) right now with the 22's at the big end. I was thinking of going with a bigger slick next year just so I can stay away from shifting into 5th.
Old Oct 10, 2004 | 07:56 PM
snowseeker's Avatar
Default Re: Need help hooking up!!! (Clayton)
Those are some nice looking bars. I think you made up my mind on the traction bars.
Old Oct 10, 2004 | 08:18 PM
SlicksMH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">
I am at the very very top of fourth gear (8400) right now with the 22's at the big end. I was thinking of going with a bigger slick next year just so I can stay away from shifting into 5th. </TD></TR></TABLE>
Hi snowseeker; You have the B16-Y1 tranny it has alittle bet long gearing then the reg B16. If you are pushing let say around 240 HP go wiyh the 23's if it's a street car. Full race car you can go with the M&H 8.5/24.5-13 and if you do have the 280-300 on that HP, you just might want to go up to the M&H 8/25-13 or the 8.7/25-13.
Good Luck snowseeker and be SAFE.
John@M&H-Hashims
Old Oct 10, 2004 | 09:04 PM
snowseeker's Avatar
John@M&H-Hashims </TD></TR></TABLE>
Thanks much for the advise! Could you PM with a price on a pair of 24.5/8.5 slicks.
Do you think the bigger slicks with the full-race bars and coil overs are ideal? Would I want the car to sit flat or have the backend up a little higher than the front?
Thanks again!
killah1
Nov 14, 2007 08:06 PM
civic_fan
Feb 18, 2006 09:02 PM
Eaglekper0046
Jul 22, 2005 03:00 AM
JDMlyfestyle
Oct 30, 2003 12:28 AM
