need help with drag car stuff
Old Feb 3, 2006 | 12:37 AM
bracket 4 life's Avatar
Default need help with drag car stuff
looking for some help in a setup that will produce lo 9's.
now motor stuff I am not worried about its chassis and little stuff that I am worried about.
I need help with a air to water intercooler setup
suspension set up and slick sizing,
also tranny questions I know that the h22 tranny will not even come close to holding up but what about a xtrac or hardcore b-series tranny.
kinda on a budget but want to do it right the first time and not have to keep redoing stuff
Thanks for all your time and information
Old Feb 3, 2006 | 05:06 AM
SpeedDreamz.com's Avatar
Default Re: need help with drag car stuff (infamousCW-hatch)
you cant put xtrac and budget in the same sentence. You will need about 850+whp and 26:+ slicks.
Old Feb 3, 2006 | 07:24 AM
.dave's Avatar
i HAS questions ?
What class are you trying to run in/are you looking to run in some racing series? Look at the rule book for the class and build the car around its restrictions.
Any class where you can run the X-trac you're going to need better than low 9-second times. I'd be surprised if someone doesn't hit that in Turbo Street this year.
Old Feb 3, 2006 | 10:41 AM
Default Re: need help with drag car stuff (daveG)
not really looking into a class just want to build a fast fun drag car and then when the money is there to be competitive I will jump into that
Old Feb 3, 2006 | 04:11 PM
bump, maybe this explenation will help I am just trying to assemble a set up that would be possible to run low times, the long block will be a h22, the tranny will be a b series and the chassis is a 1992 civic hatch that is what I have so far. kinda need to hear what kinda specs and other stuff along those lines
Old Feb 7, 2006 | 11:10 PM
kpowerdhatch's Avatar
can't be on a budget and run 9's.
Old Feb 8, 2006 | 12:35 AM
well by budget I mean under 60,000 but more in the range of 30-40k not saying I am going to half *** it, i want everything safe as possible and then go fast as hell. but I just want to go a route that I can make sure it is all right. starting off laskey racing will be getting the motor. I will be piecing together a turbo kit with a gt42r and tuninig with hondata until more money comes in for aem ems. will be putting a full chromoly 10pt cage with parachute. still want to retain as many stock panals as possible. no fiberglass or lexan. will only cut the bumper for intercooler. fenders will be cut to clear slicks. also fuel tank will be removed for a 5qt that will be in the engine bay. I just want a clean mean fast track car, that is consistant, cause I love to bracket race for some reason.
Old Feb 8, 2006 | 03:51 AM
monEmakindave's Avatar
buy my car in sig... save time and money. just a plug.
but honestly depends what series your running. NOPI, NHRA you can't compete its gonna be tough. but if your out to have fun you can run low 9's reliably with less than 800 hp.
spfwd drive cars are makin in the range of 550-700 hp run high-mid nines no wheelie bars and at least 2400 lbs.
def attainable. I believe some weight changes will help this year with weight reductions to level off the field but hard to run against big budget teams, no matter how light you can get.
Old Feb 8, 2006 | 11:06 AM
Default Re: need help with drag car stuff (dabullet)
i 100% agree about the budget of the baller teams it sucks. but yea i just want to have fun and bracket race alot and do some local competitions
Old Feb 8, 2006 | 06:55 PM
Boner_Ben's Avatar
Buy Jason Hunts crx for 15k and have money to spare!
Old Feb 8, 2006 | 07:09 PM
91' LS-VTEC's Avatar
Default Re: (Boner_Ben)
I thought I read some where on here, that H2B plates are not leagal for drag?
Old Feb 8, 2006 | 08:53 PM
I want jason's car so bad but the is not there up front and if it was I would of picked that up right away
RS'R'
Jan 3, 2007 05:44 PM
BTC5
Jan 22, 2005 01:38 PM
Aquafina
Aug 5, 2003 12:49 PM
