need an educated answer. 1/8
Old Jun 10, 2006 | 05:35 AM
DaveF's Avatar
Default need an educated answer. 1/8
ok. whats going on friends and foes
last night we took the hotrod coupe to atco. when we got there they were only allowing 1/8 mile pass's. on our 2nd pass we got a full 1/4 pass.
1st run we got a 5.97 @123 in the 1/8 with a 1.41 60.
on our 2nd pass we went 5.8X @114 with a 1.38 60ft time. (9.7@109 miss 4th)
i know the 60 has alot to do with the et...blah blah blah.... but how the hell could we have possibly lost 10mph in the 1/8 ????????? is it possible that the timers are off ????? the car really didnt seem to be hooking any harder now than before. but Steve was on a pass.
Old Jun 10, 2006 | 05:40 AM
nsxmatt's Avatar
Wouldn't happen to be shifting around the time of the traps would he?
Old Jun 10, 2006 | 05:43 AM
DaveF's Avatar
Default Re: (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Wouldn't happen to be shifting around the time of the traps would he?</TD></TR></TABLE>
its possible, but i was paying more attention to how straight he was keeping the car, as well as how it was hooking/accelerating. i think its in 3rd before or right @ the 1/8 mile mark though. hopefully Steve can chime in later on this afternoon sometime.
Old Jun 10, 2006 | 05:45 AM
tony1's Avatar
Default Re: (dturbocivic)
If you have datalogs from both runs you should easily be able to see what changed.
Old Jun 10, 2006 | 06:00 AM
DaveF's Avatar
Default Re: (tony1)
we arent ontop of the car like we should be..... (no datalogs)
Old Jun 10, 2006 | 08:17 AM
HR-1320's Avatar
Anyone know what a hotrod honda is doing in the 1/8 on a 8.50 pass. Give or take the average. I'm guessing the 5.8 is right about on par. And yeah the lack of data equipment is lame. We have nothing but eyes, ears, and spark plugs.
Old Jun 10, 2006 | 10:14 AM
1 2 NV's Avatar
Default Re: (2.0Coupe)
i calculate 5.4s but turbo cars run differently than AM cars.
Old Jun 10, 2006 | 10:27 AM
ExospeedAMcrx's Avatar
2nd pass seems to be right for the 9.70 run.
If you were doing a 123 on the 1/8, but the ET is slower than the 2nd pass, its possible you had more wheel spin on the 1st pass.
The car just hooked better on the 1/4 mile pass and had a lower mph, but better 1/8 mile times.
daym i just reread that but sure was hard to read. haha. tell me if you guys understood what I just typed.
Old Jun 10, 2006 | 11:27 AM
miller's Avatar
Default Re: (exospeedAMcrx)
what kind of management are you using?
how was your 330' different between the 2 runs?
Old Jun 10, 2006 | 03:57 PM
DaveF's Avatar
Default Re: (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">what kind of management are you using?
how was your 330' different between the 2 runs?</TD></TR></TABLE>
gen 7. DFI w/msd programable 7.
steve will have to answer the rest. i dont remember off the top of my head.
Old Jun 10, 2006 | 07:20 PM
HR-1320's Avatar
Atco's new time slips don't show the 330. On a pass that I did 9.1 at etown my 330 was 3.9 and the 1/8 was 6.0. So on that second pass I'd guess it was a 3.7. I'm convinced it was an 8.8-8.9 pass but can't say for sure. I wouldn't say it had much to do with traction my car doesn't spin much at all in first and after that its a dead hook. Also I have other slips were my 60's are in the high 1.3s and I'm still doing 125mph or so in the 1/8. We were just a little shocked to see a 10 mph diff when I was on my best pass yet. Obviuosly the car doesn't have much power either. We dyno it at 800 or so but the car runs like its putting down 650. As for the engine management we could leave a laptop mounted in the car to data log I believe about 8 diff things but my laptops to nice for that kind of abuse so I'll just wait to get a race pak. My NLR boost controller could be telling me some important boost info if I just hook my map up to the aux port and were in business there. Btw the most mph I've seen at the traps has been 156. We know the cars fat though if we could just lean it out a little on top we'd possibly pick about 10 mph. Oh well were sick of these stock gsr cams so well see how this bitch does with my roller rocker set.
Old Jun 10, 2006 | 07:48 PM
miller's Avatar
its seems as though the car needs more boost in second gear, i may be wrong but just from what you are describing it seems as this might help. your 1/8th mile mph should be higher then 125. i would say atleast 135 or 140mph range.
also with the dfi gen 7 you can datalog a couple things to help your situation.
Old Jun 11, 2006 | 06:35 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">its seems as though the car needs more boost in second gear, i may be wrong but just from what you are describing it seems as this might help. your 1/8th mile mph should be higher then 125. i would say atleast 135 or 140mph range.
also with the dfi gen 7 you can datalog a couple things to help your situation.</TD></TR></TABLE>
i agree with the 1/8 mph. it should be higher. when we were @ etown, we checked out one of stephanie eggum's timeslips and she is way faster in the 1/8 (i belive 135-138) we are hitting 2nd gear with about 30-35 psi, maybe we can adjust the ramp speed on the boost controller so that it will come up quicker. 3rd and 4th are full boost (37-38) (at least that is what it was on the dyno, but i can imagine track and dyno are 2 completly differant loads on the car)
how can we datalog without a labtop being in the car? we dont want to mess up a good labtop(if it happen to go flyin around) i do know that the dfi has some datalogging built into it...... .but we arent that savy with the electronics yet.... have alot of learning to do.
thanks guys
AEM DP
Sep 23, 2012 08:05 PM
OaksRacing
Oct 25, 2007 12:47 PM
Turbo-charged
Mar 10, 2007 06:06 AM
HYBRID_H@TCH
Apr 6, 2006 05:01 AM
MIKES
Aug 26, 2002 03:16 PM
