NDRA Hatchacks with fuel cells
Old Apr 17, 2004 | 05:52 AM
SpeedDreamz.com's Avatar
Default NDRA Hatchacks with fuel cells
" In hatchback vehicles in all
classes, a firewall must separate the driver's compartment from the fuel cell."
Give me some pics of you setups or ideas. I have done a search and cant find any pics.
Modified by 30psiCiv at 9:40 AM 4/17/2004
Old Apr 17, 2004 | 07:44 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: NDRA Hatchacks with fuel cells (30psiCiv)
Old Apr 17, 2004 | 07:47 AM
Default Re: NDRA Hatchacks with fuel cells (SIXTYdashONE)
Is that just a flat cover?
Old Apr 17, 2004 | 07:50 AM
HT's Biggest Loser
No, there is a 1.5 inch raise on each side, and a bracket underneath it to suspend the cover, then insulation all around it, including the little swingup door thats kinda hard to see right now
Old Apr 17, 2004 | 11:14 AM
MackSpeed-616's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">No, there is a 1.5 inch raise on each side, and a bracket underneath it to suspend the cover, then insulation all around it, including the little swingup door thats kinda hard to see right now</TD></TR></TABLE>
that is according to NHRA rules, right? I was told that if you are using an aluminun cell the cell itself is all the "firewall" you need to seperate you from it. that is the purpose in using an aluminum cell opposed to a plastic one or one designed to be used with a safety "can"
Old Apr 17, 2004 | 11:34 AM
HT's Biggest Loser
Default Re: NDRA Hatchacks with fuel cells (MackSpeed-616)
Not too sure Gordon, i used it anyways
Old Apr 17, 2004 | 11:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackSpeed-616 &raquo;</TD></TR><TR><TD CLASS="quote">
that is according to NHRA rules, right? I was told that if you are using an aluminun cell the cell itself is all the "firewall" you need to seperate you from it. that is the purpose in using an aluminum cell opposed to a plastic one or one designed to be used with a safety "can"</TD></TR></TABLE>
So you are saying that no cover is needed? That sure would same me some time.
Old Apr 18, 2004 | 06:32 PM
ALLMOTORD16Z6's Avatar
has anyone put a plastic fuel cell in the rear of a hatch with a shield blocking it from the driver.
Old Apr 18, 2004 | 06:37 PM
Default Re: NDRA Hatchacks with fuel cells (ALLMOTORD16Z6)
Yes there is one in the back of our integra.
Old Apr 18, 2004 | 07:37 PM
tony1's Avatar
Probably doesn't matter now, but why did you guys put the cell in the rear anyways? Why not put it up front to help with traction?
Old Apr 18, 2004 | 07:51 PM
Default Re: NDRA Hatchacks with fuel cells (tony1)
Turbo 4 has to have a 5 gallon cell. Where ya gonna put that under the hood? You got one I will buy it.
Old Apr 18, 2004 | 08:13 PM
tony1's Avatar
Ahh didn't realize it had to be so big. I can make you one that fits behind the bumper.
Old Apr 19, 2004 | 05:08 AM
you guys need to stay current with rule updates
"NDRA 1.5/1.6/1.7/1.8 updates
All street/sportsman classes: Fuel cells allowed, 5 gallon minimum is changed to Fuel cells allowed, no fuel cells mounted under the hood of cars, no fuel cell size limit."
so to answer tony's question. there is no size minimum,.. but the cell has to be in the car. i prefer it in the trunk that behind my seat
Old Apr 19, 2004 | 05:14 AM
NOPIDRAGS's Avatar
No fuel cells have to be in the trunk or the hatch area. We are not allowing them in the front of the car.
Old Apr 19, 2004 | 05:16 AM
Default Re: NDRA Hatchacks with fuel cells (sold9secteg)
Will an aluminum cell in the spare tire area need a cover?
Old Apr 19, 2004 | 05:27 AM
NOPIDRAGS's Avatar
Tracy, that all refers back to the NHRA guidelines on fuel cells.
Old Apr 20, 2004 | 05:23 AM
I cant find a clear solution in the NHRA general guidlines. THey show some pics but never anything clear on a rear mounted cell in a hatchback. Does anyone know the answer: Does a rear spare tire well mounted aluminum cell need a cover?
1:5 Fuel Systems
Location: All fuel tanks, lines, pumps, valves, etc. must be outside
of the driver’s compartment and within the confines of the frame
and/or steel body. Cool cans, fuel-distribution blocks, etc. must be
located at least 6 inches forward of the flywheel/bellhousing area
on rear-wheel-drive (RWD) cars, and on opposite side of
flywheel/bellhousing area on front-wheel-drive (FWD) cars. Fuelpressure-
gauge isolators, with steel-braided line, may be mounted
on firewall.
Tanks: When permitted by class regulations, fuel tanks located
outside body and/or frame must be enclosed in a steel tube frame
constructed of minimum 1 1/4-inch O.D. x .065-inch chrome moly
or .118-inch mild-steel tubing. All fuel tanks must be isolated from
the driver’s compartment by a firewall, completely sealed to
prevent any fuel from entering the driver’s compartment. All fuel
tanks must have a pressure cap and be vented outside of car
body. A positive-locking screw-on fuel-tank cap is mandatory on all
cars. Insulated fuel tanks prohibited. When used, fuel cells must
have a metal box protecting the part of the fuel cell that is outside
of body lines or trunk floor, excluding hose-connection area in rear.
Non-metallic fuel cells or tanks must be grounded to frame.
Lines: All non-OEM fuel lines (including gauge and/or datarecorder
lines) must be metallic, steel-braided or NHRA-accepted
“woven or woven-pushlock.” A maximum of 12 inches total (front to
rear) of non-metallic or non-steel-braided hose is permitted for
connection purposes only; individual injector-nozzle fuel lines are
excluded. Fuel lines (except steel-braided lines) in the
flywheel/bellhousing area must be enclosed in a 16-inch length of
steel tubing, 1/8-inch-minimum wall thickness, securely mounted
as a protection against fuel-line rupture. Fuel lines may not be
routed in the driveshaft tunnel. NHRA-accepted woven or wovenpushlock
fuel lines: Aeroquip FC300, FC332; Aeroquip Star Lite
200; AQP Socketless; Dayco Imperial Nylo-seal tubing; Earl’s
Prolite; Gates LOL Plus; Goodridge 710; Russell Twist-Loc 836 and
XRP HS-79. Contact NHRA for updates.
Old Apr 20, 2004 | 05:28 AM
tony1's Avatar
I'm pretty sure it just has to be fully enclosed in an aluminum box.
Old Apr 20, 2004 | 05:29 AM
Ok, but does an aluminum cell qualify as an aluminum box?
Old Apr 20, 2004 | 05:33 AM
tony1's Avatar
no
Old Apr 20, 2004 | 07:50 AM
i am confused as well... i have heard from a few sources that aluminum cell's do not need further "protection"
lets try to get to the bottom of this one.
Old Apr 20, 2004 | 08:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackSpeed-616 &raquo;</TD></TR><TR><TD CLASS="quote">i am confused as well... i have heard from a few sources that aluminum cell's do not need further "protection"
lets try to get to the bottom of this one.</TD></TR></TABLE>
I totally agree. WHo knows the answer?
Old Apr 20, 2004 | 08:19 AM
Just got off the phone with a guy at NHRA. He said "any fuel cell, no matter its material, does require a cover/bulkhead of some sort to prevent fuel spillage from rupture"
There is the answer guys.
SP GARAGE
Nov 1, 2006 05:56 PM
S@nt0s
Mar 26, 2006 06:13 PM
careawholelot
23
May 6, 2005 03:08 PM
WillsH22Accord
Nov 27, 2004 01:36 PM
junbb1
Dec 28, 2003 04:46 PM
