mounting a motor tilted?
Old Nov 14, 2005 | 01:47 PM
Hondog's Avatar
Default mounting a motor tilted?
I've been looking a few competetion cars and noticed a few have the motors tilted forward and wondered the reasoning behind this..
The main reason for asking is I want to tube the front of my car and make solid mounts up for the car aswell, but I don't really wanna mount it all up if there is something to be gained from tilting it forward..
I guess it aids the axle angles so you can lower the car further, but what other benefits are there and what needs to be done to the motor if it is tilted? dry sump etc etc??
Thanks for any help i can get...
Old Nov 14, 2005 | 02:11 PM
DaveF's Avatar
Default Re: mounting a motor tilted? (Hondog)
on our cars ....moving the engine got the axles straighter in the car. that was about it.
and its also moved up, about 2 5/8 inchs
Old Nov 14, 2005 | 04:10 PM
JL's Avatar
JL
you mean like that del sol with the completely horizonal mounted b-series? wasn't that from australia? ok maybe not that extreme eh?
Old Nov 16, 2005 | 04:50 PM
EVLTEK's Avatar
That one is actually H series.....they were running dry sump....
I don't think Hondog is talking quite that extreme though
Old Nov 16, 2005 | 05:07 PM
tommyten's Avatar
moving it more forward also keeps more weight over the front wheels.
Old Nov 16, 2005 | 05:14 PM
speedworks's Avatar
Default Re: mounting a motor tilted? (tommyten)
i moved my engine so that the axles were in line with the hube and horizontal when sitting at ride height. this should not abuse the axles quite as bad.
Old Nov 17, 2005 | 09:20 AM
msmotorsports's Avatar
Default Re: mounting a motor tilted? (speedworks)
The only benefit of tilting the motor forward would be to get a better axle alignment on lowered chassis's. There are disadvantages though. On most cases a dry sump will be needed and a vaccum pump for the turbo drain will be needed. Since the motor is tilted forward oil in the pan will also be moved forward and most likely cover the drain hole for the turbo. The oil pickup will possibly fail due to the oil moving forward and possibly allowing air to enter the lines. IMO, its alot of work and money for just alittle more axle alignment.
Old Nov 17, 2005 | 10:19 AM
X-Mazda 3 Racer's Avatar
Default Re: mounting a motor tilted? (msmotorsports)
Another advantage is weight ratio. Putting the bulk of the motor in front of the axle, instead of over it, will act like a leverage point applying more weight to the front of the car, aiding in traction and weight ratios, front to back. I know it made a big difference when we corner scaled my car!
Old Nov 17, 2005 | 12:42 PM
AR Fab's Avatar
Default Re: mounting a motor tilted? (GoldenEagleMfg.com)
lower the cars CG
Old Nov 17, 2005 | 12:50 PM
tony1's Avatar
Default Re: mounting a motor tilted? (AR Fab)
That's a stupid idea, i'd never mount a motor like that.
Old Nov 17, 2005 | 06:16 PM
R@mon's Avatar
Default Re: mounting a motor tilted? (tony1)
also a lower hoodline can be had with a tilted motor.
jellybeanracer
11
Dec 22, 2012 02:29 PM
olddohc
Transmission & Drivetrain
21
Dec 11, 2011 08:38 PM
olddohc
Feb 26, 2011 09:31 AM
CALIdelsolSIR
16
Feb 27, 2006 12:11 PM
