MoTec Question??
Old Jun 20, 2005 | 06:05 PM
boostedh22a's Avatar
Default MoTec Question??
What wideband sensors are compatible with MoTec. I have a M400 ECU, and already have a Bosch wideband O2, so if I dont have to buy a new that would be great!
Any info would be appreciated....thanks
Old Jun 20, 2005 | 06:34 PM
B20TDC2's Avatar
Default Re: MoTec Question?? (boostedh22a)
pm tony1 he could help you with anything motec
Old Jun 20, 2005 | 07:15 PM
Bottle's Avatar
if i am not mistake a bosch lsu 4.0 sensor with the m400
Old Jun 20, 2005 | 10:25 PM
SEFIxCivic's Avatar
you need to wideband option enabled on the motec. the other option is to run a plm or other wideband configured to give the same output as the plm.
Old Jun 20, 2005 | 10:45 PM
tony1's Avatar
Default Re: (Bottle)
LSU 4.0, LSU 4.2, or NTK. And you will need the wideband option enabled regardless of which sensor you use.
Old Jun 20, 2005 | 11:16 PM
thanks for the info, and yes, the wideband option is enabled. Is there any calibration??
Old Jun 20, 2005 | 11:21 PM
tony1's Avatar
Default Re: (boostedh22a)
yes, which sensor do you have? If you have the bosch then you can do a free air calibration, go to the "wide band lambda setup" and "free air calibration". Make sure you have the sensor type setup for the sensor you are using.
Old Jun 21, 2005 | 03:39 AM
Bosch LSU4.2 5-wire
Old Jun 21, 2005 | 09:02 AM
SEFIxCivic's Avatar
oh one thing i noticed with the LSU 4.2 sensor is that althought its listed on the sensor list, you got to tell the motec to run it as an LSU 4.0
That was the only way to get it to start reading.
Not sure if this is the right way to do it but it worked for a couple cars.
Old Jun 21, 2005 | 02:37 PM
The options I have listed are as follows
1. LSU 4.0 (normal)
2. NTK (normal)
3. LSU 4.0 (fast heat)
4. NTK (fast heat)
5. LSU 4.2 (normal)
6. LSU 4.2 (fast heat)
Old Jun 21, 2005 | 03:23 PM
SEFIxCivic's Avatar
on a 2 cars im running an lsu 4.2 but when i choose option 5 the wideband never becomes active, but when i choose option 1 for lsu 4.0 it works even though the sensor is really a lsu 4.2
Old Jun 21, 2005 | 04:54 PM
Suprdave's Avatar
Default Re: (SEFIxCivic)
Isn't the difference between the LSU 4 and 4.2 basically the plug?
Old Jun 21, 2005 | 05:02 PM
SEFIxCivic's Avatar
Default Re: (Suprdave)
not sure, i cut off the plug and run my own.
Old Jun 21, 2005 | 05:36 PM
Suprdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEFIxCivic &raquo;</TD></TR><TR><TD CLASS="quote">not sure, i cut off the plug and run my own.</TD></TR></TABLE>
So do I
Old Jun 21, 2005 | 08:44 PM
thanks for the info guys
Old Jul 3, 2005 | 04:02 PM
one more question, I have found wiring schematics for the M800 and the M880 ECU. Mine is a M400, is the wiring the same on all ECU's for the LSU widebands???
Old Jul 3, 2005 | 07:32 PM
tony1's Avatar
Yes, the M400 wiring is the same as the 800 and 880.
Old Jul 3, 2005 | 07:45 PM
BoogieDownBrown's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, the M400 wiring is the same as the 800 and 880.</TD></TR></TABLE>
THE TRUE "KING MOTEC"
Old Jul 3, 2005 | 08:55 PM
antiJDM's Avatar
Default Re: (BoogieDownBrown)
i'm pretty new to aftermarket EMS's but putting aside heaters and what not, shouldn't the ecu just be looking for a voltage range?.........0-5v?
Old Jul 4, 2005 | 05:24 AM
tony1's Avatar
Default Re: (antiJDM)
A wideband sensor by itself doesn't put out a 5v signal, you have to have a driver/processor for the sensor, which the motec does itself internally.
Old Jul 4, 2005 | 12:15 PM
vaporboy12's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">A wideband sensor by itself doesn't put out a 5v signal, you have to have a driver/processor for the sensor, which the motec does itself internally.</TD></TR></TABLE>
motec king
Old Jul 4, 2005 | 07:35 PM
E Town DSM's Avatar
Default Re: (vaporboy12)
Old Jul 5, 2005 | 12:40 PM
motecnate's Avatar
Default Re: (tony1)
Please keep in mind that the LSU 4.0 and 4.2 are not wired the same.
LSU 4.0 CONNECTOR
pin
1. LAM Ip
2. LAM Vs
3. LAM 0V
4. HEATER GND (ECU AUX OUT 1 OR 2)
5. LAM HEATER 12V+
6. NOT CONNECTED
LSU 4.2 CONNECTOR
pin
1. LAM Vs
2. NOT CONNECTED
3. HEATER GND(ECU AUX OUT 1 OR 2)
4. LAM HEATER 12V+
5. LAM 0V
6. LAM Ip
Using the wrong configuration or pinout will result in false lambda value readings.
Nathan
Modified by motecnate at 3:46 PM 7/5/2005
Old Jul 5, 2005 | 03:45 PM
Default Re: (motecnate)
Cool, thanks for the info mang
Old Jul 5, 2005 | 04:15 PM
1fstcorrado's Avatar
Default Re: (E Town DSM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E Town DSM &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
he doesn't need a white interga to pick up chicks thats for sure.....lol
