MoTec Connection
Old Aug 12, 2005 | 08:20 AM
boostedh22a's Avatar
Default MoTec Connection
How do you connect to the MoTec computer if your laptop only has USB. I've tried a USB to DB9 to Parallel convertor and it doesn't work. Has anyone had this problem???? My laptop has no COM ports and no Printer ports.
Old Aug 12, 2005 | 10:22 AM
X-Mazda 3 Racer's Avatar
Default Re: MoTec Connection (boostedh22a)
Call motec. I know they have a solution for that. Either they have the cable for adaption, or they can point you in the right direction. I am pretty sure we use the USB interface cable.
West Coast Motec
5355 Industrial Drive
Huntington Beach, CA
92649
Tel: (714) 897-6804
Fax: (714) 897-8782
Talk to Nate!
Old Aug 12, 2005 | 10:28 AM
SpeedDreamz.com's Avatar
make sure you select the proper port in the motec software also or it wont know where to look for the ecu.
Old Aug 12, 2005 | 10:33 AM
I cant find anywhere in the software to select a port???
Old Aug 12, 2005 | 10:40 AM
doublej's Avatar
A PCMCIA card to serial will work if you/Motec unable to do it in s/w, but is cumbersome.
Old Aug 12, 2005 | 06:26 PM
agturbo's Avatar
try using the current software version 620D, i had this problem the other day when i ws using my buddys laptop which had the usb to serial adapter, http://software.motec.com.au/release/
Old Aug 12, 2005 | 08:39 PM
I have a USB to serial, but the motec requires a Printer Plug??? serial is only 9 pin, the motec connection is like 20pin
Old Aug 13, 2005 | 07:02 AM
tony1's Avatar
Default Re: (boostedh22a)
The M400/600/800 series ecu's ues a parallel port (big printer one), while the M4 and M48 use a serial port. Unfortunately I don't know the answer to your question though, call Motec and talk to Nate.
Old Aug 13, 2005 | 07:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22a &raquo;</TD></TR><TR><TD CLASS="quote">I cant find anywhere in the software to select a port???</TD></TR></TABLE>
press f5 in the opening menu screen to select the port
Old Aug 13, 2005 | 07:38 PM
tony1's Avatar
Default Re: (SpeedDreamz.com)
The M800 software is totally different. You're thinking of the M4/M48 software.
Old Aug 16, 2005 | 12:13 AM
SEFIxCivic's Avatar
Default Re: (tony1)
im using a pcmcia to parallel card. you can get one that works for sure from motec, or take your chances and get one cheaper from the computer store.
Old Aug 16, 2005 | 02:24 PM
motecnate's Avatar
M4 and M48 ECUsBest Buys has a USB to Serial Adaptor made by I/O gear that works well with most laptops. There are other ones available but they do not work. So far I/O gear has the best one. I believe these go for around 20-30 bucks.
M-Hundreds and ADL
If you are looking to use the M hundreds meaning 400 600 or 800 also including ADL, you need to convert to the lastest ECU manager 2.3 and Dash Manager 3.2. You can download these new files from our Motec website.
We offer a USB to CAN adaptor for that.
Part# M UTC $266.00
Alternatively you can use a PCMCIA to Par Can adaptor.
Part # M PORT ADAPT $203.70
I would use the UTC because the construction of the adaptor is more robust.
ADL2 / SDL (Sports Dash)
These new dashes already works with USB 2.0.
Hope this answers your questions
Nathan Tasukon
Technical Support
Motec Systems USA
http://www.motec.com
Tel. 714-897-6804 ext 135
Old Aug 22, 2005 | 08:16 PM
builthatch's Avatar
MiG-21 superfan
Default Re: MoTec Connection (motecnate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motecnate &raquo;</TD></TR><TR><TD CLASS="quote">M4 and M48 ECUsBest Buys has a USB to Serial Adaptor made by I/O gear that works well with most laptops. There are other ones available but they do not work. So far I/O gear has the best one. I believe these go for around 20-30 bucks. </TD></TR></TABLE>
just make sure it is specifically for PC use and not a PDA. lol...we have wasted alot of time during FC training sessions having the trainee run out to Best Buy because they had the wrong type converter. There are some that also hamper the communication rate between the unit and PC, i think nate has it rite with the IOGear piece, specifically PN# GUC 232a. That one is perfect for 9 pin to USB conversions detailed for the m4/48.
Gsr94black
Dec 18, 2008 10:25 AM
jakscivic
Dec 17, 2006 03:04 PM
getsome1990
Jan 5, 2006 07:25 PM
1sikhatch
Dec 1, 2005 11:20 AM
