March FS Sticky
Old Mar 1, 2010 | 06:14 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default March FS Sticky
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for
RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 1-1-2010, any edit to these threads, will result in sanctions. if it persists, the stickies will disappear for good.
Old Mar 1, 2010 | 06:19 PM
Mr. Badwrench
Default Re: March FS Sticky
msd 75611 programmable rev limiter box. works with all analog boxes.
http://www.msdignition.com/Products/RPM/Timing_Controls/RPM_Controls/75611_-_Programmable_Launch_Rev_Control.aspx
Too much power can actually be a hindrance when it comes to hooking up a small tire or the prop of a drag boat. For anyone with this “problem” the Programmable Launch Limiter is the answer. This microprocessor controlled Limiter plugs in place of an rpm module in an MSD Ignition or Soft Touch unit. You can then go in and program a launch-based rpm ramp based on rpm and time. This is set in 100 rpm steps down to 0.001-second increments by using MSD’s Pro-Data+ software on a PC or with the optional Hand Held Monitor, PN 7550. There is also an adjustment that sets a delay time before the rpm limit activates. This way, when you launch the rpm limit will kick in exactly when you want it to and ramp up to your race rpm for the rest of the run. This Limiter can be used with most of MSD’s Ignitions or Rev Controls (except the 7AL-3 and 10-Plus) that use the plug-in rpm modules. The Pro-Data+ software is supplied.
the box is 2 years old, plenty of length on the wires. well taken care of. i think we are getting a handle on the car without it.
testing waters, but if interested,
200 shipped.
tepid1's Avatar
$450 Prologger Wideband/Boost datalogger and controller (new)
Wires are terminated to the terminal strip and unit was mounted via velcro.
$50 Flaming River battery cut switch
The best battery cutoff out there. Period.
$750 AFI Intercooler 24x12x3.5 garrett core (basically new)
Setup for wiggins clamps, but regular hose and clamps work too.
$475 (ONE) Weld Racing one piece 15x3.5 skinny - polished (new)
$475 (ONE) Weld Racing one piece 15x3.5 skinny - gold (new)
Old Mar 1, 2010 | 06:33 PM
boosted hybrid's Avatar
Selling a barely used AIR carbon fiber intake manifold for B16a and GSR cylinder heads. Manifold was used on a N/A project a few years ago, had dyno time and about 20 passes on it in total. Its in like new condition. I have owned 2 of these manifolds so far, and by far are the most bad-*** street manifold out there. They retain no heat, and make great power with no midrange loss compared to the edelbrock. Manifold comes with all hardware I used when I last ran it (not included when purchased new), IAT sensor, as well as T1 race development billet idle air control relocation flange. Manifold was port matched to 70mm by Headgames. Price is firm at $1000.00 shipped in the 48 states.
Some more pics of the manifold and dyno graph from the engine it was used on:
http://forums.evans-tuning.com/viewt...hp?f=39&t=3179
Old Mar 1, 2010 | 06:44 PM
85mmek9's Avatar
A very nice set of Billet crower rods for 4g63 that fits 7 bolt dsm's and evo 8, and evo 9's.
These are in excellent shape with ARP rod bolts that were new last year with only 4-5 passes and 1 torque.
$400.00 obo
Up for sale is a Carbonetic Triple carbon disc clutch for 4G63. You really do not get any better then this. It was ran about 5 passes thats it.
$2000.00 OBO
Up for sale is a set of brand new in the box Brian Crower 288 cams.
$300.00 obo
up for sale is a barly used 1.00 hot side for BW turbos. Used for one season
$100.00 obo
Barley used Aeromotive 12304 fuel filter
$50.00
Great condition GSR block, comes with mains and girdle and a block guard also
$200 obo
91turbove's Avatar
brand new garrett t3/67 ho
67mm compressor
standard s cover
4" inlet 2.5" outlet
.70 a/r
T3 footprint
.82 a/r
1900* coating
3" vband welded on
BNIB MSD 96lb/hr(1000cc) injectors
4 fuel pumps 3 BNIB, 1 used and is installed in tank.
-2 walbro 255hp
-TRE performance 255hp(made by walbro, just has lifetime warentee)
-installed one is walbro 255hp
Old Mar 1, 2010 | 08:07 PM
joe95b18coupe's Avatar
92 CIVIC COUPE, LS VTEC, JG PRO SERIES HEAD, JG EDLEBROCK INTAKE W/RPM THROTTLE BODY, 1600 INJECTORS, DFI ENGIE MANAGEMENT W/MSD DIGITAL 6 W/2 STEP, GARRET TURBO, FULL CHROMALLY CERT CAGE TO 8:50, STRANGE REAR SUSP W/SPINDLE MOUNT BOGARTS, 15 IN WELDS ON FRONT, DRIVE SHAFT SHOP AXLES, PRO DRIVE SPOOL, FULL INTERIOR SHEET METAL, FIBERGLASS DOORS, FRT END, DASH AND TRUNK LID, CUSTOM PAINT AND AIR BRUSH, F.A.L LEXAN WINDOWS, WHEELIE BAR AND CHUTE. LOTS TO LIST. SERIOUS INQUIRES PLEASE.
Old Mar 1, 2010 | 08:13 PM
dustin528's Avatar
sorry some of the pics aren't great. I do not have a digital camera so these were taken with my cell phone. Also the room i took the pics in doesn't have the best lighting.
2 b18/ls eagle rods, arp 2000 5/16 rod bolts Good condition --- 80 shipped each
1 b18/ls eagle rod, arp 2000 3/8 rod bolts Brand new! Bought as a replacement rod and was the the wrong one(big bolts) --- 80 shipped
set of gsr cams, not sure what these go for, good condition --- 150 shipped
ctr intake cam, good condition, not much use, bought this new, original wrapping --- 150 shipped
b-series t4 divided topmount manifold, flanged for dual 44 wastegates, Very similar to full-race! I haven't had any problems with this manifold cracking or anything else like that. I do not know what brand it is cause the guy i bought it from didn't know either. My motor dropped two valves and pieces went through the turbo and ruined it. I will not need this for a while and could use the money to build a completely new engine and rebuild the turbo. --- 950 shipped
Crower stage 2 turbo cams, BNIB, I've had these for a long time and just never got to use them. Now i need the money much more to completely rebuild my engine since it dropped two valves. --- 450 shipped
b18c/gsr block, bare, freshly bored/honed to 83mm, golden eagle blockguard, Had some pistons i was going to throw in this for an all motor build and never got around to it. Ready to throw your rotating assembly in and go! --- 400 obo I will have to check on shipping.
Old Mar 1, 2010 | 09:16 PM
Blueberry1320's Avatar
i got a set of type r cams with sk2 cam gears 300$..
(347)219-2026 txt me for pics. or questions
Old Mar 2, 2010 | 03:12 AM
TheWickedOne's Avatar
$100.00 Shipped
Aeromotive Pro Series filter -12an in/out with 100 Micron Stainless Element.
Old Mar 2, 2010 | 03:48 AM
DaveF's Avatar
updated 1-25-10
***asking 10,000***
(this does not include suspension/wheels/drivetrain / NO extras, besides whats listed below)
will entertain trades for "street car" type vehicles. let me know what you have
__________________________________________________ ________
1992 honda civic si racecar chassis
* 10pt chromoly cage with parachute mount/wheelie bar hookups_ just certified this year_
* Custom aluminum dash, door panels and interior panels
* chromoly wheelie bar with wheeleze wheels
* stroud window net
* omp race seat
* FAL lexan windows (race kit) * Lexan sunroof *
* MB Products fiberglass doors with chromoly frames and lexan window with stainless allenhead bolts/nylock nuts
* G-Force seatbelts, brand new last year (2007)
* Tube front end with midplate & solid timing belt side mount
* clearanced for 28" tires
* Acura sundance gold pearl paintjob
* entire chassis was sand/bead/media blasted before paint
* Carbon fiber front nose
* spare tire well is cut out, with flat aluminum panel covering
* CNC master cyl / cnc staging brake with line lock
* OMP steering wheel with quick release/line lock button
__________________________________________________ _______________
************* fully unlocked Motec M48
, with Data cable and a brand new flying lead harness. (this is a motec harness)
2200.00
__________________________________________________ ________________________
**********also have a milspec harness
, built by me, with tefzel wire/raychem dr-25, deutsch connectors etc. 1200.00
this is the harness before i added in the extra 4 injectors (it now has 12injectors )
__________________________________________________ ______________________________
Front mount B series T4(split housing) turbo manifold
- 304 stainless, tig welded by Jm Fabrications
- will not come with wastegate flanges, unless you also purchase my wastegates
- has extra mount for support
- 800.00 + shipping
Garrett Gt4202R Turbo
- 74mm
-1.10 a/r exhuast housing
- ball bearing
-water cooled
- includes inlet restricter flange
- includes compressor and turbine discharge flange and v band clamps
- does not include air fitting
1500.00 + shipping
JM-Fabrications / Spearco water to air intercooler
* 4-inch v band inlet and outlet
* -12AN water outlet fittings
* -12AN drain
550.00 Shipped
All associated lines/fittings
* 12an fittings on tank & intercooler
* 3/4 shut off valve on tank for drain
* hose is 3/4 inch
85.00 shipped
Hydraflow clamps 225.00 each
* fits 4inch tube
* i have 4 clamps
* OMC coils (coil on plug) with bracket
- fits b series vtec heads
225.00 + shipping
*obd2b to obd2a jumper harness
150.00
______________________________________________ -
* B16 block with crank. block has some messed up holes where driver side mount bolts on, can be fixed. 75.00 + shipping
* Billet Aluminum shock tops from Strange Engineering50 shipped
* Str sparkplug cover 75 shipped
* Greddy TVVC Boost Controller 200.00 the most bad *** manual boost controller ever !
* eibach front and rear sway bar kit with endlinks etc, i belive its everything for installation. 250.00
Oil Catch can
80 shipped
* fits 1-3/8 filter
* -12 an male bung
* 1/4npt drain/plug
10 inch tall coil springs
* fits 2.5inch shock
* 350lb rate
50 shipped
Old Mar 2, 2010 | 05:58 AM
MiamiVR6T's Avatar
Brand New in Box GT4094r
SOLD
Old Mar 2, 2010 | 06:27 AM
grand champ's Avatar
All parts in Central CANADA, all prices are obo + shipping and in CAD funds, buyer also pays paypal fee. Send me a pm if your interested or would like to see some pictures.
$200 - Custom B-Series Front Mount Manifold, T3 turbo flange, 38mm Wastegate flange. Built completely from Schedule 10, T304 stainless. Mig welded, so welds don’t look as nice as they could. Comes with 3” side exit stainless down pipe, flanged to fit 4bolt t3 turbo. (has 3 o2 sensor bungs)
$400 – Spearco liquid to air intercooler, Rated for 450hp, (I made 480 before IAT's started to raise) 2 ½” inlet + outlet, ½” NPT holes for water
$150 – Custom built Steel Wheels, 4x100, I think they are 13x8 with 5"bs but i will need to double check. (these will not fit overtop of Integra Brakes)
$200 – Garrett T3/T4 turbo, 60 trim, stage 3 wheel.. Good for about 425-450hp. This is all I know, if you want more info I can take measurements for you. NEEDS REBUILD!!
$100 – OEM B16 fuel rail with B+M adjustable regulator
$400 – Complete b16a bottom end. 100% complete running bottom end. Head was taken for ls-vtec, has approx 70,000km. Ran VERY strong before being removed. Came from JDM RHD OBD-0 Civic hatch.
$200 – B16 bottom end, Includes Block, Main caps/bolts, Rods, Pistons. Was an oil burner.
$50 - B16 Block, with main caps and crank (bored to 81.5mm and needs to be re-done so probably sleeves)
$200 - Eagle H-Beam B16 rods, used one season
$100ea – LS Cylinder head, I have 2 complete LS heads including cams and valve covers. Condition un-known - they were take off's for ls-vtec
$75ea – B16a Stock Cams, 1 set with oem gears, one without.
$50ea – Random strut Bars, 2x front, 1x rear should fit all integra and civic??
$250 – Richmond Spool – (with bearings for LS/b16 trans) For GSR trans, p/n – 80-1005-1
Here you can see the manifold, downpipe, turbo, and intercooler
Strut bars, 2x front upper, 1x rear upper, 1x front lower
GSR spool: (will not come with the speedo gear or a ring gear. the bearings are newer and will be included)
2x LS head (wraped up), 1x B16 bottom end (this is the oil burner)
B16a rods eagle h beams
Old Mar 2, 2010 | 07:01 AM
SpeedSceneScott's Avatar
Default PRICE REDUCED, racecar roller with three K motors.
THIS CAR IS SUPER LIGHT!
CRX drag car, 1991 with three K motors, tranny and tons of parts.
(motors are stock, one is complete and running, two are disassembled complete missing one head) Motor and trans and clutch is in the car.
Fiberglass one piece front clip, doors, and rear hatch.
Almost all new and way too many to list. Car has NHRA certified chro-moly cage.
New paint, New Lexan, 2 brand new clutches including one high doller full race version, Fresh trans with spool, fuel cell, Hasport mounts, axles, more more more.
All welding and fab work done and painted. Fuel cell mounts, battery mount, interior tin work, everything fabbed and painted.
Not running, needs wiring and header and ECU.
http://s976.photobucket.com/albums/ae248/scottlucky/
$4300.00
NOW ONLY $3900
Call 714 342-6485
Located in Orange county, not far from Disneyland.
Old Mar 2, 2010 | 08:26 AM
ssc_thomas's Avatar
Precision Turbo 6776H PT series
Turbo is BRAND NEW never used.
Quick Specs:
Compressor Wheel: 67mm
Compressor Outlet: 3"
Compressor Inlet: 4"
Exhaust A/R: .81
Turbine Inlet: T4
Turbine Outlet: 3.5" V-Band
Journal Bearing
Rated @ 750-800HP
Price: $825 FIRM PayPal Preferred
Price does not include shipping. PM me for a quick quote
Will ship anywhere. If buyer is out of the lower 48 buyer pays actual shipping
AEM Injector Driver Box Brand New AEM PN# 30-2710
Price $200 OBO Shipped to the lower 48
Last edited by ssc_thomas; Mar 30, 2010 at 08:48 AM. Reason: updated sold parts price drop
Old Mar 2, 2010 | 11:02 AM
Adriano's Avatar
I have the following for sale:
Competition Clutch twin disk for sale. Came out of my sfwd car that used to make ~680whp. It's in very good condition, no issues at all. Asking $650
Spinwerks 13 rims. Asking $375
I aslo have a perfectly working 99-00 OEM dist. Comes with nkg OEM wires. Asking $175
Adriano
201-638-6183
Old Mar 2, 2010 | 01:41 PM
Innes's Avatar
Contact Information
Email -- James@IPGParts.com
Phone -- 407-324-4684
or PM
-- 1995 Integra GSR Rolling Drag Chassis -- $7800
9 sec Roll Cage (not certified but done correctly so should pass with flying colors)
fresh red paint job, updated 98+ integra front and rear
carbon roof (stock one cut out and a carbon roof fitted into place)
carbon hood
carbon trunk
JoJo 3 Piece Front end
simpson chute
golden eagle diffuser
battery cutoff switch
battery relocated to the rear
2 kirkey seats with brackets
1 5 point harness
Gforce window net
Custom Traction Bar
Skunk2 Pro-C Coilovers
Skunk2 Rear Lower Control Arms
Skunk2 Front and Rear Camber Kit
PLX Wideband
Autometer Oil Pressure Gauge
OEM Sumped Fuel Tank
Circuit Worx Stage 1 Axles
ARP Extended Wheel Studs
wheels are not included in sale price, being sold seperately
Lot's of Great Parts for Sale !!!!
Contact Information
or PM
-- Gato B16 Intake Manifold with Fuel Rail -- Very nice piece, barely used, accepts bosch injectors and setup for a Mustang Style Throttle Body -- $750
-- Custom Catch Can with 6 Lines, Fittings and Filters -- $450
can include a red valve cover with all the bungs welded into place already for $100 extra
-- Accufab 80mm Throttle Body -- includes TPS as pictured -- $225
-- Garrett Intercooler Core with Custom End Tank and some of the intercooler piping -- was used with the Front Mount Turbo Manifold so may need to be modified to fit your particular application -- 3" piping and clamps included -- $975 with turbosmart bov -- $850 without turbosmart bov
-- Gato Performance Custom Front Mount Turbo Manifold -- this manifold positioned the turbo right in the front bumper -- has a T4 Turbo Flange and a 60mm W/G flange on it -- very nice custom piece, first of its kind, one of a kind -- $800 -- or $900 ceramic coated
-- Turbosmart 60mm Wastegate -- in good, ready to use condition -- $500
-- Fal Slimline fan - Part # FAL 125 specifically for a 1/2 size radiator -- $125
-- Weld 15x9 Magnum Import, 4x100 Lug Pattern, with (1) good MT 26x8.5x15 slick (the 2nd slick has a gouge in it) -- $750 can custom coat these a color you want before we ship for an additional cost if interested
-- (1) Skunk2 Cam Gear Pro Series Cam Gear for B Series -- $100
-- B16 Transmission with a Quaife installed -- $1200
-- B16 Head ported by NRG with Supertech Valve Springs, Retainers and 1mm oversize valves -- $950
-- (2) Skunk2 Pro Series Cam Gears -- $190
-- Edelbrock Victor x for B16, powdercoated black -- $225
-- Ericks Racing 74mm TB -- $190
-- Pwr radiator with electric fan, has -12AN fittings welded onto it, can supply the complete setup with lines and water necks with bungs too for more if interested -- $250
-- Competition clutch twin disc for hydro b series engine -- $800
-- Innovative Solid Engine Mounts, B series into EG/DC -- $250
-- Full Race T4 Top Mount Manifold with 60mm W/G Flange and DP -- $1300
-- Precision 74mm Q Trim Turbo -- $950
-- Tial 60mm Wastegate -- $475
-- Turbosmart 60mm Wastegate -- $500
-- Precision Intercooler Kit with piping for EG, routed for a top mount manifold, 3” -- $850
-- M&W Pro 10 with Crane Coil, Wiring, etc -- $580
-- Hondata S300 with boost by gear and ECU -- $600
-- Gato Front Mount Turbo Manifold (mounts turbo in front bumper ) - $800
pics available upon request, email James@IPGParts.com
Old Mar 2, 2010 | 02:23 PM
DANgerously's Avatar
HKS EVC VI Boost Controller
Retails for over $600
Used for 1k Miles
Everything Included
Asking $400 OBO
Originally Posted by HKSusa.com
The new HKS EVC has improved boost stability for maintaining pressure at high RPMs providing increased top-end power, and a new mapping feature allows boost pressure to be precisely tuned for throttle + RPM (or vehicle speed). The new EVC also offers a selectable kPa or PSI unit of measure, and a unique warning feature where if over boosting occurs, boost pressure can be programmed to drop to a user preset level. The new target boost setting and volume **** with three button user interface makes setup and tuning intuitive and simple. The design of the new EVC features a sleek black case with a clear acrylic faceplate and a positive lit LCD display offering a sophisticated look.
Features
High Boost Capability
250kPa/36PSI
Target Boost
User inputs target boost level, and the EVC automatically adjusts pressure to reach desired level.
Offset Function
If boost exceeds or does not achieve user’s target, boost pressure can be offset to reach desired level.
Map Correction Mode
Boost pressure can be fine tuned for: Throttle Position, RPM, Vehicle Speed, Throttle Position + RPM, or Throttle Position + Vehicle Speed.
Dual Boost Mode Settings
Separate A and B boost levels can be input independently from each other, and selected depending on driving conditions.
Scramble Boost Function
When the scramble boost trigger is depressed a preset boost increase will occur for a predetermined time (0-60seconds).
External Scramble Boost Trigger compatible.
Metric or SAE selectable monitoring
Users can choose during initial setup metric (kPa) or SAE (PSI) boost pressure measurement for monitoring.
Warning Function with Boost Drop Feature
A user preset warning level can be set where visual and audible alerts occur if the warning level is reached. Boost pressure can be preset to drop too a user defined level if pressure reaches warning level.
Analog and Digital Boost Monitoring
Boost pressure can be displayed in both an analog bar graph format and a digital numerical value.
Additional Digital Monitoring
Along with Boost Pressure two additional vehicle vitals can be monitored: Throttle Position, Engine RPM or Vehicle Speed.
Selectable Analog Monitoring
The digital bar graph can be set to monitor: Boost Pressure, Throttle Position, Engine RPM or Vehicle Speed.
After Image Function
Users can set the EVC to display the highest boost pressure reached for 3-seconds after the throttle has been released.
Peak Hold
The EVC will store to memory and keep displayed the maximum boost achieved.
Data Lock
To prevent accidental data changes from occurring, the EVC can be locked with a user defined four digit code.
Positive LCD display with LED Lighting
Black foreground with white background and LED lighting provides excellent visibility during both daytime and nighttime use.
Dimmer Function
Brightness of display can be adjusted for user comfort.
Rear Mounted Wiring harness
For a clean and simple installation the wiring harness connects to the back of the EVC unit.
Asking $400 OBO
Old Mar 2, 2010 | 03:15 PM
DrivenGSX's Avatar
Visit Turbo4.com for most up to date items for sale and more pictures.
Contact: tony@turbo4.com
‘74 Chevy Vega – Tube Chassis race car. This car has gone 9.38 at 144 MPH – only $16,500!
PM me for more information.
4G63 Magnus Race Intake Manifold – Setup for a 2G cylinder head, RWD layout (throttle body on the opposite end when compared to a FWD/AWD intake) and 8 additional injectors (Yes, EIGHT more for 12 total injectors). Also comes with a custom anodized fuel rail for the 8 injectors. Setup for a 90mm Mustang style throttle body (see below, we have one of those for sale also). This manifold would cost over $1300 to have made with only 4 injector bungs and a standard fuel rail. (injectors NOT for sale) $600
Honda CBR Coils for COP setup
– This is a set of 4 Denso coils from T1 for a COP setup. These come with connectors and a length of shielded wire for each coil. Simply setup the opposite end for whatever connector you need for your harness. These are $55 each new plus connectors and wire. These were used for a very short time and I’m asking $100 for the set.
90mm Accufab Throttle Body – This is a 90mm Accufab throttle body with the built in Wiggens/Accufab clamp. This is a 320 dollar throttle body and 200 dollar clamp new. You would need to buy a new ferrule from Accufab for the mating coupler (http://www.accufabracing.com/90mm.htm) $300
Borla XR-1 4″ Muffler – This is a brand new 4″ straight through muffler. It’s still in the box. $150
Thanks for the space,
Tony
Old Mar 2, 2010 | 04:20 PM
10ring's Avatar
Old Mar 2, 2010 | 07:20 PM
<jdm_love>'s Avatar
jdm b16 bare block-40
tial 38mm wastegate with 12psi spring-150
obd1 b-series vtec dizzy-60
pm for details
Old Mar 2, 2010 | 08:51 PM
BILLY_BAD_A$$'s Avatar
Sparco seats $275 each (torino sold)
Avid shift linkage for ef $80
15lb bottle $120
Innovative traction bar for ef(upgraded bushings and front trans mount included with
stiffest insert) $150
N1 replica muffler $50
Stewart Warner blue led digital tach $75
Old Mar 3, 2010 | 05:44 AM
ghostofnyc's Avatar
AC & PS compatibale
Inline pro manifold is high temp coated $350
tial 38mm wastegate 14.5 spring $ 175
3" ac down pipe and 38mm dumptube $250
if seperated if bought together can work out a package deal
Old Mar 3, 2010 | 10:39 AM
Allan DP's Avatar
b16 head full port and polish and assembled by TG cylinder heads, supertech heavy duty springs & retainers oversize valves head will include a port matched edelbrock intake manifold ready for a 75mm throtlebody.This head is race ready !! we used it for one season on rolando's coupe and has recently been checked and new valve seals were installed ,we went 9.50's with this head def a sick head!. $1500
Old Mar 3, 2010 | 11:13 AM
hpc.aeroe.'s Avatar
i have 2 aem ems 30-1040u (obd1 vtec)
1000$ each..
Direct port NOS kit..pretty much brand new never used..lines were bent for a jg edelbrock..comes with bottle warmer..remote bottle opener..400$
