m factory shift change
Old Jan 15, 2011 | 01:57 PM
hello1320's Avatar
Default m factory shift change
Is is as effective as the long/T1 shifter... in preventing the the fatal 1-2-1... does anyone run both ?
Old Jan 15, 2011 | 02:24 PM
PRO1's Avatar
Default Re: m factory shift change
u mean speed factory? Its called a shift selector and yes they work very well and u can run both
M factory may have one im not sure
Old Jan 15, 2011 | 02:34 PM
hello1320's Avatar
Lol...Mfactory...speed factory. Whatever It takes...
Old Jan 15, 2011 | 02:35 PM
hello1320's Avatar
For what its worth...Honda calls it a shift change assambly
Old Jan 15, 2011 | 06:36 PM
JayWest's Avatar
shift change holder assembly
well worth it in my opinion
Old Jan 15, 2011 | 06:45 PM
JJsMotorsports's Avatar
its a must for dogbox owners, Its much stronger than oem basic one!
Old Jan 15, 2011 | 06:46 PM
SPOOLINmatt's Avatar
its on my list....its a great upgrade, but i wouldn't say its a must.
Old Jan 15, 2011 | 06:51 PM
It will be "when" your stock one cracks............. I would hate to lose a race because of it cracking and not going into gear........ just my .02
Old Jan 15, 2011 | 07:24 PM
PRO1's Avatar
Shift change? LOL either way its a good investment for the money. Hit me up if u need one
Old Jan 15, 2011 | 09:07 PM
hello1320's Avatar
Icon5 Re: m factory shift change
I will. Sending u that head in a week or so to.
Only reason for this thred... by buddie did the 1-2-1. So I was wondering if anyone if the SF shift selector is as affective as the long shifter ( in preventing the 1-2+1 ). If so its a hell of a lot cheaper.
Old Jan 16, 2011 | 05:47 AM
HR-1320's Avatar
It will not help your 1-2-1 issue. Its a stock replacement part that it built stronger thats all.
Old Jan 16, 2011 | 06:23 AM
121 is all in the the way you handle the ****, but i think the SF part would help since it has a stronger return spring combo
Old Jan 16, 2011 | 08:10 AM
locash's Avatar
Actually, it will help prevent the 1-2-1, as it has a stronger spring assembly to help keep the shifter in the 3-4 gate.. We use them on ALL of our transmissions, dogbox or synchro, the SpeedFactory part is a nice piece.. Please dont confuse SpeedFactory with Mfactory.
Old Jan 16, 2011 | 08:11 AM
Antilag's Avatar
Speedfactory has billet shift selector and reenforced some things= sick!
M- Factory has solid shifter bushings which is a nice combo too.
Old Jan 16, 2011 | 08:12 AM
locash's Avatar
Oh, and we use them in conjunction with the T1 Long shifter setup, but if you are using both and dont have the longer of the shift levers, you may want to have SpeedFactory use the stock return spring, or it will take a lot of force to change into the 1-2 gate..
Old Jan 16, 2011 | 08:22 AM
htx_jr.95eg's Avatar
x2 i have T1 Long Shifter with the SpeedFactory setup but with the stiff spring and man it's a work out to get it into 1-2 gate but slowly getting use to it lol...
Old Jan 16, 2011 | 08:34 AM
tony1's Avatar
I run both, I like the springs being stiff.
Old Jan 16, 2011 | 08:37 AM
HR-1320's Avatar
i'm gonna use just the upgrade piece for selector only. I already have a stiffer spring and 1-2-1 my car just as easy. In the heat of the moment when you make that fatal mistake you may be underestimating your strength. But whatever
Old Jan 16, 2011 | 08:43 AM
crazes's Avatar
Moderator
Thats what SHE SAID
hahaha.
sry, to good let it go no offense tony
Old Jan 16, 2011 | 02:49 PM
hello1320's Avatar
There was 2 1-2-1 shifts and 1 2-3-2 shift at IFO today !!!!
Old Jan 16, 2011 | 02:51 PM
hello1320's Avatar
Exactly the info I was looking for....... thanks guys
Old Jan 16, 2011 | 08:25 PM
Garage 808 Hatch's Avatar
I have a new one for sale if you're looking.
Old Jan 16, 2011 | 08:55 PM
bads2k's Avatar
need something for kseries trans too. they seem to slide right back into the other gear sometimes lol. i've tried the hybrid box and they seem a little too stiff going to the next gear so that may be worse I would think.
Old Jan 16, 2011 | 09:05 PM
pgpbubble's Avatar
They do...http://www.icbmotorsport.com/mtinupshlesp.html
Old Jan 16, 2011 | 09:24 PM
JFK78's Avatar
We are also using both the T1 G-Force shifter kit and our SF-Modified SCHA. It takes a fairly high amount of effort to get into the 1/2 gate, but we have no issues with it and like the added pressure kicking it over into the 3/4 position to help insure against a 1-2-1 or 2-3-2 mis-shift.
The stiffness tends to be an issue with the guys that have the shorter or cut down Long shifters. We recommend those running such a setup to get the SCHA with the stock spring.
Those of us running the Long-Long aren't having a problem getting it in. lol
FYI, there are 6 areas of the SCHA that are modified and/or strengthened aside from the upgraded spring, so 7 modifications in total with the spring. This addresses all the areas of SCHA failure that we have seen from many race teams in drag & road-race use with both synchro & dogboxes.
