LS head Bench flow
Old Sep 20, 2002 | 09:00 PM
12secB18acivic's Avatar
Default LS head Bench flow chart
I just got a ported ls head that came with a super flow flow chart but i don't know how to read it. it says a stock ls head flow 145 at .50 lift@valve and after the port job the head flows 177 at .50 lift. and this was at 12" cfm of h2o 70 deg temp. so is this a good head?and what does this mean?what time should i expect from this head on a stock LS bottom with the basic bolt ons ( h,i,e) in a 92 civic hb?
[Modified by 2o9, 4:05 AM 9/21/2002]
Old Sep 21, 2002 | 06:04 PM
Patron's Avatar
Default Re: LS head Bench flow chart (2o9)
i too am interesed!
Old Dec 5, 2003 | 04:57 PM
prestonpark's Avatar
Default Re: LS head Bench flow chart (12secB18acivic)
problaly 13.9 in a hatch.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12secB18acivic &raquo;</TD></TR><TR><TD CLASS="quote">I just got a ported ls head that came with a super flow flow chart but i don't know how to read it. it says a stock ls head flow 145 at .50 lift@valve and after the port job the head flows 177 at .50 lift. and this was at 12" cfm of h2o 70 deg temp. so is this a good head?and what does this mean?what time should i expect from this head on a stock LS bottom with the basic bolt ons ( h,i,e) in a 92 civic hb?
[Modified by 2o9, 4:05 AM 9/21/2002]</TD></TR></TABLE>
Old Dec 5, 2003 | 05:30 PM
SpeedDreamz.com's Avatar
Default Re: LS head Bench flow chart (civic2003)
If you already run mid 12's expect to knock off a couple tenths if your motor can utilize the added flow.
Old Dec 5, 2003 | 10:04 PM
civickiller's Avatar
Default Re: LS head Bench flow chart (30psiCiv)
man i didnt know the ls head flows so little, a b16a head flows like 230 stock at .5. i konw because of vtec and everything but damn
Old Dec 6, 2003 | 01:15 AM
sorry guys but i posted this thread months ago and i am not running LS anymore, i have LSvtec now
Old Dec 6, 2003 | 04:55 AM
D-Man's Avatar
Default Re: LS head Bench flow chart (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">man i didnt know the ls head flows so little, a b16a head flows like 230 stock at .5. i konw because of vtec and everything but damn</TD></TR></TABLE>
probably because it was flowed/tested a different way,I bet that B16 head was flowed with 28" where as his LS was at 12" and it was also on a wet bench.
Old Dec 6, 2003 | 08:11 PM
Cyphear's Avatar
Anyone know the difference between B18B, B18C1 and B18C5 flows? I'm pretty curious how my B18B head flows compared to the VTEC heads.
Old Dec 7, 2003 | 04:04 PM
boosted3g's Avatar
Default Re: (Cyphear)
I think Earl at one time went over most of the Honda heads but i am not positive it was him. If i remember correctly the B16a flowed about 265 or so stock. The only ones higher was the itr and the Celica heads. I know there are some European heads (specifically Audi 5V) that flow even more but the test was limited to more popular makes.
vtec killin
Jun 26, 2007 12:06 PM
b20turboic
Nov 20, 2005 07:59 AM
91daLS-V-TEC
Mar 17, 2004 08:04 PM
