Lower transmission to engine support / mounting bracket's... Really Needed?
Old Jun 5, 2008 | 09:03 AM
White Smoke's Avatar
i my honda
Global Mod
Default Lower transmission to engine support / mounting bracket's... Really Needed?
I figured I would post this here since obviously, you guys put the most stress on your transmissions.
My question is about the B-series lower transmission to engine support / mounting bracket's. These are the brackets that bolt to the BOTTOM of the block in the front (1 bolt) and the rear (2 bolts) as well as the transmission in the front and the rear.
The reason I am considering leaving them off is because I cannot remove the trans with the down pipe installed. In order to remove the brackets I HAVE to remove the DP and this is a PITA with my setup. This is not a DD but it is a street car that I take to the drag strip every now and then.
Thanks for the advise, in advance.
Old Jun 5, 2008 | 09:08 AM
Turbo-charged's Avatar
Default Re: Lower transmission to engine support / mounting bracket's... Really Needed? (White Smoke)
if you use ALL of the bolts, you should be OK. i dont use one of the 2 bracets because of the downpipe (i dont remember if its the front or the rear one)
id say 99% of people dont use any. hell it seems a lot of people only bolt the trans on with 2 bolts lol
Old Jun 5, 2008 | 09:11 AM
i my honda
Global Mod
Default FV-QR
Thanks for the input Joe!
Old Jun 5, 2008 | 09:34 AM
swapit's Avatar
Default Re: FV-QR (White Smoke)
if my problems keep going im putting zeus fastners on mine...lol
i dont use the rear one but i do have the fron one on.
Old Jun 5, 2008 | 09:51 AM
Default Re: FV-QR (swapit)
yea....there for a while i wanted to use a magnetic switch to hold on the trans and the axles lol
flip the switch and the trans falls off
Old Jun 5, 2008 | 10:10 AM
1992Si's Avatar
It may be my old age but I like the idea of having the bottom mounts.
I had solid mounts made last year. There were basically 1/4 steel plate welded with in a "L" shape for the tranny side and attached to the traction bar mount up front.
Use the OEM drivers side bracket and replace the pin with a bolt and a straight 1/4" plate going forward.
If you can weld you can make them for next to nothing. That engine and tranny won't move and the shift linkage always stays in good alignment.
Old Jun 5, 2008 | 10:11 AM
Default Re: (1992Si)
he isnt talking about the engine mounts...he is talking about the support braces that hold the engine and transmission to each other.
i thought the same thing at first....had to read it a second time.
Old Jun 5, 2008 | 10:31 AM
vtekthis's Avatar
Default Re: (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">he isnt talking about the engine mounts...he is talking about the support braces that hold the engine and transmission to each other.
i thought the same thing at first....had to read it a second time.</TD></TR></TABLE>
theres brackets there?
Old Jun 5, 2008 | 10:39 AM
ExospeedAMcrx's Avatar
They make good door stops.
Old Jun 5, 2008 | 10:48 AM
1992Si's Avatar
Nevermind...
Old Jun 5, 2008 | 11:12 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">i thought the same thing at first....had to read it a second time.</TD></TR></TABLE>
That's why I noted they bolt to the bottom in caps, to try and defer from this. Sorry for any confusion... I knew people were going to think about the torque mounts at first. Thanks for the reply guys.
Old Jun 5, 2008 | 11:39 AM
Turbocivic94's Avatar
I never use them...
HotCheetos
10
Dec 11, 2010 09:07 PM
velonorton1974
Oct 21, 2009 04:21 PM
CrazycakesEM2
Honda Civic (2001 - 2005)
Jan 30, 2008 11:01 PM
Del Sol Man
72
Jun 21, 2006 08:13 AM
Integra_Nguyen
Aug 10, 2002 06:58 PM
