looking for help with lexan.
Old Sep 8, 2003 | 03:46 PM
go2slo96's Avatar
From: im rubberband man, hondred grand in my hand man
Default !
Modified by go2slo96 at 2:31 AM 9/9/2003
Old Sep 8, 2003 | 03:48 PM
hndarcrb18c1's Avatar
Default Re: looking for help with lexan. (go2slo96)
FAL makes a great kit for the Eg chassis...
Old Sep 8, 2003 | 04:04 PM
1 2 NV's Avatar
Default Re: looking for help with lexan. (hndarcrb18c1)
who wants to pay $1000 for a set of windows they could cut and make for around $400? FAL
Old Sep 8, 2003 | 05:16 PM
dmotoguy's Avatar
Default Re: looking for help with lexan. (1 2 NV)
i dont know how you would measure it... its not a rectangle shape... just go with trial and error if you cant trace the stock windshield and just add i think its 1/4-1/2 an inch... it will get the correct bend when you screw it on the car...
Old Sep 9, 2003 | 07:36 AM
92h22a's Avatar
Default Re: ! (go2slo96)
I bought a piece of lexan 4x8 sheet for about $107.00 cut it out with a sawzaw after tracing from my stock windows. Make sure you have a good sander to smooth out any inperfections, I was able to make a front windshield 1 rear and 1 side and bought a small sheet from homedepot to finish the other side cut. Use 1/8 rivet and drill bit and space the rivet every 3 inches. If you can see from the picture the side allmost look stock but the rear has some waves in it.
Old Sep 9, 2003 | 10:13 AM
RenoRacing's Avatar
Default Re: ! (92h22a)
My friends and i have all done our own windows. We've scored lexan from homedepot cause a friends cousin is a manager there so we've got a 4x8 sheet for 38$ and then just bought smaller pieces along the way. It's not hard at all. we usually trace a template onto some thin (1/16") plastic stuff cause you can cut it with scissors and make sure it fits then trace to the 1/8" lexxan and cut away, we've used everything from a die grinder to tin snips and sawzalls. not to bad.
Old Sep 10, 2003 | 10:33 AM
boostedcvc's Avatar
Default Re: ! (RenoRacing)
what else works well is using the stock glass for template to get the size correct and then clamp the lexan down to the stock window and form the lexan to the glass with heat lamps.
2LEM1
Mar 1, 2021 10:01 AM
TurboDSMJ
Honda S2000
Aug 3, 2006 07:08 AM
atckc
Honda Civic (2006 - 2015)
Jul 26, 2006 01:41 PM
RCautoworks
13
Jun 30, 2003 09:51 AM
TORQUE MONSTER
13
Jan 16, 2003 08:27 AM
