limiting straps??????
Old Oct 1, 2006 | 11:26 PM
pinoyk20's Avatar
Default limiting straps??????
what does it do??? does it help get traction????? how does it work???? pls post pics of your limiting straps set ups........ thanks!!
Old Oct 2, 2006 | 02:14 AM
d15Beta's Avatar
i think, when u have ur rear suspension tuned,
using limiting straps up front prevents the front from lifting, kinda like the car wants to lean on towards the rear, and the front springs tend to help lift the front... due to weight transfer..
i could be totally wrong.. haha lets w8t for those in the know to chime in... hihihi
Old Oct 2, 2006 | 06:26 AM
buck02's Avatar
Default Re: (acid-burn)
they do keep front down
Old Oct 2, 2006 | 11:13 PM
pinoyk20's Avatar
anymore answers pls????? im plann\ing on doin it on my dragcar. is it safe to use?????
Old Oct 3, 2006 | 04:13 AM
d15Beta's Avatar
i think thats about the answer,
in a nutshell it prevents the front from lifting.. due to weight transfer , during acceleration
Old Oct 3, 2006 | 12:10 PM
ykracing's Avatar
yes it works, and yes its safe... not on the street tho...
Old Oct 3, 2006 | 06:06 PM
matkeller's Avatar
Default Re: (ykracing)
I don't use them. When launching or going down the track weight gets transferred back and you can't do much about it. In my opinion strapping the control arm or fork to the body may even lift the wheel. I say let your suspension do the work. May I suggest some OMNI POWER.
Old Oct 3, 2006 | 06:47 PM
Whitfield Inc.'s Avatar
Default Re: limiting straps?????? (pinoyk20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoyk20 &raquo;</TD></TR><TR><TD CLASS="quote">what does it do??? does it help get traction????? how does it work???? pls post pics of your limiting straps set ups........ thanks!!</TD></TR></TABLE>
they limit the height the car can lift or the suspension can lift -
yes if set up correct it can help -
basiclly can limit the travel up of the strut - wich can help traction
if you have a car that does not have a "bolt on" strut this strapping can help you alot
Old Oct 3, 2006 | 08:10 PM
pinoyk20's Avatar
thanks guys!!! can you pls post pics of your strap set ups????? yes mat im already using omnipower drag suspensions but im still having lift from the front.
Old Oct 4, 2006 | 06:34 PM
Default Re: (pinoyk20)
the omni we used on our 10.o eg was great but not perfect - the car will still have upward travel untill you limit it some how. sway bar is another great idea
Old Oct 4, 2006 | 06:42 PM
Mugencrxsir1's Avatar
Default Re: (Whitfield Inc.)
Yeap it's old tech., the domestic guys have been using straps for a long time.
Old Oct 4, 2006 | 06:44 PM
SIXTY's Avatar
they can help alot, in our old 86 crx car the front did not have struts in the front only shocks and torsion bars. Limiting straps helped out the set-up alot.
Old Oct 4, 2006 | 08:41 PM
pinoyk20's Avatar
how does swaybars help????
Old Oct 5, 2006 | 12:19 PM
d15Beta's Avatar
preloading the sway bar i guess...
Old Oct 5, 2006 | 12:23 PM
Big Teggie's Avatar
Short stroke shocks will also do the same thing as straps. What suspension do you have?
Old Oct 5, 2006 | 08:39 PM
pinoyk20's Avatar
what do you mean by pre loADING THE SWAYBAR?????? THANKS!!!
Old Oct 6, 2006 | 01:22 AM
d15Beta's Avatar
Default Re: limiting straps?????? (Big Teggie)
oh yeaH...
i forgot about that hehe
turbo sol
Honda Motorcycles
12
Aug 23, 2005 06:15 AM
og asr
Suspension & Brakes
Aug 13, 2005 06:12 PM
solo-x
Dec 12, 2002 02:29 PM
JinMTVT
Sep 4, 2001 10:11 AM
rioninja
Jul 24, 2001 12:09 PM
