Lexan question
Old May 27, 2004 | 12:18 PM
f@sth@tch89's Avatar
Default Lexan question
What do most people use to create the black lining around the lexan? Some look just like it came from the factory. Would like some tips and advice b4 I start on my lexan.
Old May 27, 2004 | 12:20 PM
Robb's Avatar
Default Re: Lexan question (fasthatch89)
spray paint on the inside.
Old May 27, 2004 | 12:31 PM
Default Re: Lexan question (Robb)
yeah i know its paint, but some cars look dayum near stock.
Modified by fasthatch89 at 1:50 PM 5/27/2004
Old May 27, 2004 | 12:36 PM
Robb's Avatar
yeah those look super nice. Doesnt hurt that those are probably brand new.
Old May 27, 2004 | 12:38 PM
HotRodTeg's Avatar
No rivets clean
Old May 27, 2004 | 12:56 PM
Default Re: Lexan question (CrazyCompression)
how do u put lexan on w/o rivets?
Old May 27, 2004 | 01:28 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Just dont use rivets, use a thing called thread-serts.. Its an insert that goes into the metal of the car and has thread on it, you need a special pop tool to install them, and you can use black tapered hex screws in it. The finished look is perfect!
Old May 27, 2004 | 02:18 PM
skunked's Avatar
Default Re: Lexan question (SIXTYdashONE)
The Fal kits are pretty nice too.
Old May 27, 2004 | 06:46 PM
jdkindle's Avatar
those are brand new, but its speedglass and its supposed to stay like that; its what we are going to use too
plug; I have some normal lexan for a 96+ hatch for sale
Old May 27, 2004 | 08:23 PM
FULLTHROTTLE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">Just dont use rivets, use a thing called thread-serts.. Its an insert that goes into the metal of the car and has thread on it, you need a special pop tool to install them, and you can use black tapered hex screws in it. The finished look is perfect!</TD></TR></TABLE>
Plus you can vary how tight you set it. With rivets its too easy to overtighten and warp the lexan making it look crappy.
Old May 27, 2004 | 09:05 PM
V-SPEC 1's Avatar
Ron, So where can i get this so called thread-serts and the pop tool?
Old May 28, 2004 | 12:59 PM
MrParks's Avatar
normally they use a reg flat black spray paint but after they rivet it on the paint splits open and you get a dirty looking black frame ido a quick 800 greit and use model spray paint for rc cars and the paint is flexable and sticks to the plastic and doest lift
Old May 28, 2004 | 01:06 PM
JDMotive's Avatar
Default Re: Lexan question (HARTENG)
Can you use window silicone to put lexan in?It would give it a real clean look also...i ask because a friend does widshields for most of the local dealerships and does a real clean job.I think it should work though,seeing as it holds glass good.
Old May 28, 2004 | 01:27 PM
HT's Biggest Loser
Default Re: Lexan question (boostedb20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb20vtec &raquo;</TD></TR><TR><TD CLASS="quote">
Ron, So where can i get this so called thread-serts and the pop tool?</TD></TR></TABLE>
I sent you PM with some Info Vic...
Old May 28, 2004 | 01:37 PM
X-Mazda 3 Racer's Avatar
Default Re: Lexan question (JDMotive)
One thing to be sure about when painting your windows is to be sure they are clean and try to get your hands on some paint that not only sticks to lexan, but also can handle some flexing without flaking off. Bickel has a good product for this.
https://secure.st-louis.net/je...ories
Scroll a little more than half way down the page. Good stuff.
Old May 28, 2004 | 05:45 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatch89 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i know its paint, but some cars look dayum near stock.
Modified by fasthatch89 at 1:50 PM 5/27/2004</TD></TR></TABLE>
DAYUMM...Savs car is pimp..
Old May 28, 2004 | 05:48 PM
HT's Biggest Loser
Default Re: Lexan question (bruceleeroy)
Hopefully it will stay clean... His hatch was clean many moons ago..
Sav, ill clean it for you if it gets dirty, lol...
Old May 30, 2004 | 10:35 AM
EVOCELICA's Avatar
New User
Polycarbonate paint works best on lexan you can get it at any hobby store, it's mainly used to paint RC car bodies, very durable and flexable doesn't chip.
Old May 30, 2004 | 10:40 AM
NFJohn's Avatar
Default Re: Lexan question (EVOCELICA)
Go to http://www.mcmaster.com and under search, type Rivnut. That is what you want, and they sell the tool also. We usually mask off the windows and scuff the area that is going to be painted.
Old May 31, 2004 | 08:06 AM
EVOCELICA's Avatar
New User
Default Re: Lexan question (NFJohn)
with polycarbonate paint you won't need to scuff just clean the area with warm soapy water and let it dry real good before painting
Old Sep 9, 2004 | 09:55 PM
JBk24crx's Avatar
im almost done building my drag car,so I would also like to now were I can get those thread serts and the special tool.thanks for your help.
Old Sep 9, 2004 | 10:16 PM
V-SPEC 1's Avatar
Default Re: Lexan question (JBLSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NFJohn &raquo;</TD></TR><TR><TD CLASS="quote">Go to http://www.mcmaster.com and under search, type Rivnut. That is what you want, and they sell the tool also. We usually mask off the windows and scuff the area that is going to be painted.</TD></TR></TABLE>
Check this place out. They have what you're looking for.
GoLowDrew
Paint and Body
Nov 17, 2012 02:42 PM
Thrillhouse
Sep 16, 2004 10:18 AM
Cosworth
Aug 26, 2003 01:43 AM
Sucka Free
Jul 16, 2002 08:39 PM
