Lenso legality question
Old Sep 11, 2002 | 09:59 PM
sparkz's Avatar
Default Lenso legality question
I've seen/heard some people say that Lenso isn't legal for competition use. Now Ive seen tons of pictures from IDRC events and seen a lot of people run this setup. I've been trying to find some pictures of nhra events with people running lensos but don't see any.
So I guess maybe perhaps the they arent legal in the NHRA? But Ive read the rulebook over and over again and it looks like theyre ok for usage, since the lugs will cover over the limit on the length of the stock studs. Does anyone have any hard fact on this?
Old Sep 11, 2002 | 11:13 PM
rice a rona's Avatar
Default Re: Lenso legality question (sparkz)
They are a dangerous wheel. I remember when Rogar S. sheard off his lugs and send a wheel flying down the track. The reason for this is because they are a street type wheel. I knew a couple guys who run in the pro class that if they saw a guy was lining up with a guy who had those on...they would just back up and refuse to race. The only way to run those wheels is to get a special made lug nuts. The reason they had problems is because there was space in between the lug and the wheel where as with a bogart wheel there is no space because the wheel goes on and the space is filled up with the lug nuts. I heard you can get these from them...or maybe you can get some that would work from other places. I think for your safety alone, you need to get the lug nuts that do this or I wouldnt run them. Other then that...I think its all good and they are legal to run.
Old Sep 11, 2002 | 11:33 PM
ExospeedAMcrx's Avatar
Default Re: Lenso legality question (top notch)
but then again, Roger had a 10 sec car.
I believe the Lenso is for just the average weekend racer.
Old Sep 12, 2002 | 05:42 AM
autoEXturbo's Avatar
Default Re: Lenso legality question (exospeedAMcrx)
well hell, i'm bout to put the lensos on my car and it should be high tens. Where can you get the special lugs that you are talking about. I know that there are special studs needed for the lensos so that they will be legal, but where can i find the studs and how much.
Old Sep 12, 2002 | 07:59 AM
earl's Avatar
Default Re: Lenso legality question (autoEXturbo)
I don't know about legality but we sold ours and went to Bogarts just to be sure.
Old Sep 12, 2002 | 11:06 AM
CRXB16aJDM's Avatar
New User
When you do run your slicks, make sure you have metal valve stems. Certain tracks will sh*t on you for it if you have rubber valves stems. For Bogarts the way they drill the valve hole, it may easily cut a rubber valve stem and blow up at the track, it's a safety issue. So get metal when you get slicks on. Just an FYI.
Old Sep 12, 2002 | 01:59 PM
allmotor92civic's Avatar
Default Re: Lenso legality question (CRXB16aJDM)
i use the lensos and run both idrc and nhra. i mean i would like to upgrade to bogarts but would rather use $400 or so on somthing to make the car go faster
Old Sep 12, 2002 | 02:05 PM
KS-R's Avatar
Default Re: Lenso legality question (allmotor92civic)
I'm running Lenso as well, but then again.. I'm only running 12s... But I have upgraded the studs to ARP wheel studs, so I don't know if that help in any way... I haven't taken notice to the gaps between the rim and studs, but I'll be sure to check that when I get into the shop later on.... So.. yeah.. where can I get a set of these special lugs? I noticed the bogart ones have a collar to them that sleeves into the rim.. Are those the kind of lug you're referring to?
Old Sep 13, 2002 | 12:48 PM
b18bturbo's Avatar
Default Re: Lenso legality question (KS-R)
as long as you have the correct extended wheel studs with the correct open end lug nuts your hsould never have a problem.
Old Sep 13, 2002 | 07:56 PM
earl's Avatar
Have you ever looked for DOT approval on Lensos? Not sure they were ever approved for use. Check me on this...
AGENT 99
Apr 14, 2012 06:41 AM
gizzmo222
May 12, 2010 08:15 AM
ricehead
Nov 18, 2009 05:41 PM
Topdawgg
Aug 3, 2007 07:10 PM
TypeRuz
Nov 12, 2003 02:19 PM
