leakin bead
Old Oct 26, 2009 | 01:34 PM
94 ls teg's Avatar
Default leakin bead
I have 25x9x15 slicks and im tryin to mount them on rota slips 7.5x15. Im having trouble getting the bead to seal i have tried cleaning them and no luck. Would i be better running tubes or no tubes?
Old Oct 27, 2009 | 06:05 AM
94 ls teg's Avatar
Default Re: leakin bead
need help
Old Oct 27, 2009 | 03:50 PM
SIXTY-1HATCH's Avatar
well they normally require tubes, but most don't run them. I have my 13" drag wheels for my slicks, and mine leak, but they hold air for the night, just slowly leak out. They are going to be like that unless you put tubes in them. If it's leaking bad, maybe the bead is broke? You can also try a tire place, they have bead sealer you can try. Some sort of goo they throw in there and goes to the leak, almost like that tire slime or what not......
96 GSR-T
May 11, 2010 02:22 AM
CM-R
Aug 31, 2004 11:24 AM
SpeedDreamz.com
Jun 8, 2004 07:37 AM
B18C1CYA
Feb 24, 2004 10:22 PM
SIINSI
May 21, 2002 04:32 PM
