Lacking traction?
Old Jul 12, 2007 | 08:31 AM
dropcivic's Avatar
Default Lacking traction?
hmmm, i think i need new suspension or slicks
60' 2.277
330' 6.214
1/8 9.164 @86.16
1000' 11.640
1/4 13.708 @109.68
h22 in an EG with a 125 shot on it. Car spins through first and i have to modulate through second gear. Car is running a set of 225/50/15 bfg drag radials but i am thinking a set of 23x8x13 slicks might be in order with the omni drag setup since the car's *** drops badly on the launch.
Old Jul 12, 2007 | 06:33 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Lacking traction? (dropcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dropcivic &raquo;</TD></TR><TR><TD CLASS="quote">hmmm, i think i need new suspension or slicks
60' 2.277
330' 6.214
1/8 9.164 @86.16
1000' 11.640
1/4 13.708 @109.68
h22 in an EG with a 125 shot on it. Car spins through first and i have to modulate through second gear. Car is running a set of 225/50/15 bfg drag radials but i am thinking a set of 23x8x13 slicks might be in order with the omni drag setup since the car's *** drops badly on the launch.</TD></TR></TABLE>
you looking for an answer?
i think you took care of it yourself.
set some money aside for a quaife also.
Old Jul 12, 2007 | 06:36 PM
Natural Aspirations's Avatar
Don't spray in first.
Old Jul 12, 2007 | 06:49 PM
mike93eh2's Avatar
Default Re: Lacking traction? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
set some money aside for a quaife also.</TD></TR></TABLE>
Old Jul 12, 2007 | 08:32 PM
dropcivic's Avatar
Default Re: Lacking traction? (mike93eh2)
Answer, guidance, calling me a moron for my plans, etc. And i am not spraying in first, just 2nd, 3rd and 4th. I was thinking of a quife but i don't know yet if i am keeping this chais or getting another eg and doing the h2b swap on it. I will see how much i like the h2b in the crx i am working on right now before i do anything to the trans.
Old Jul 14, 2007 | 08:12 PM
GetawayInMoscow's Avatar
What psi are you running on the BFG's?
I cant get my launch down with them either (i run the same size) but I do not spin through second at all.
I run 9 psi in mine, next time I go out I will try 7-8 PSI.
H22 w/ a 125 shot is A LOT of torque for a FWD car, **** thats like small V8 torque I bet!
Old Jul 14, 2007 | 10:39 PM
dropcivic's Avatar
Default Re: Lacking traction? (GetawayInMoscow)
12 psi. The way i was told to figure what psi to run by a bunch of v-8 guys i race with is to do a burn out and look at the mark. Lower the psi till you have a solid mark about the width of the tire. That psi will be your full contact patch. I found 10-12 psi is the best
And i found out i have a hurt engine. Got beat by a bolt on b16 crx at the races off the bottle. I have 35% difference on my compression test on clyinders 2 and 3 from a good cylinders 1 and 4. When i pressurized the 2 and 3 with air, i had a good amount of air blowing through the crankcase. Good by rings or ringlands.
Old Jul 15, 2007 | 12:07 AM
you might have cracked a sleeve...good luck when you pull it
Old Jul 15, 2007 | 03:58 AM
.nate's Avatar
Damn that sucks dude
Old Jul 15, 2007 | 07:01 AM
b20beast978's Avatar
thats rough dude
Old Jul 15, 2007 | 07:53 AM
dropcivic's Avatar
Default Re: (b20beast978)
that why i do this, build something, break it, make it faster.
I think i am gonna need to vist you in a couple weeks nate, after i rebuild the motor. It's gonna need another tune
Old Jul 15, 2007 | 04:23 PM
dropcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">you might have cracked a sleeve...good luck when you pull it </TD></TR></TABLE>
Well i didn't see have any air coming through the coolant system so i really don't think it is a cracked sleeve
Old Jul 15, 2007 | 04:44 PM
93supercoupe's Avatar
stock motor?
Build it and put a bigger shot on it, that should take care of ur traction problems.
See how u like the h2b, then put an LSD in either the H trans or the B, either way, ur going to need it.
Old Jul 15, 2007 | 04:57 PM
dropcivic's Avatar
Default Re: Lacking traction? (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">stock motor?
See how u like the h2b, then put an LSD in either the H trans or the B, either way, ur going to need it. </TD></TR></TABLE>
Nippon type-s pistons with eagle rods. The head is built to rev to 10k and we have some crower stage 2 cams in there now. I was told that the rods will be able to get me higher up in the rpm range so i can start using those cams.
That is the plan with the h2b. If i like it in the rex, which i don't see how i can't(f-u cables!) then i will be hunting down another eg shell to swap into. And yes, an LSD is in the plans.
Old Jul 15, 2007 | 05:04 PM
mike93eh2's Avatar
That is the plan with the h2b. If i like it in the rex, which i don't see how i can't(f-u cables!) then i will be hunting down another eg shell to swap into. And yes, an LSD is in the plans.</TD></TR></TABLE>
put some forged pistons in your plans also..
Old Jul 15, 2007 | 05:13 PM
dropcivic's Avatar
with an h22? I am not resleeving this block since it is an SH block. I might go mahl pistons if i want more compression
Old Jul 15, 2007 | 08:10 PM
Well i didn't see have any air coming through the coolant system so i really don't think it is a cracked sleeve</TD></TR></TABLE>
Neither did I...
strigga
Apr 3, 2016 03:10 PM
integrawow
Apr 15, 2009 03:24 PM
DarkBB4
Nov 22, 2004 11:44 AM
C M S
Apr 27, 2004 11:03 AM
