July FS Thread
Up for sale is a B Series authentic Full Race Twin Scroll Top Mount. Uses dual 44mm gates. Ceramic coated, used but in great condition. Price is $900 obo. Will Ship
F/S Used Arias 81mm bore B-series 9.0.1 compression turbo pistons and Eagle Rods all in great condition with plenty of life on them left. Might recommend new rings for someone who wants to make decent power on them. These pistons and rods came out of my running car which made around 600whp. 400.00 obo....
Located in Little Rock, Arkansas. Can ship TODAY, and are out of the car now. Precision 1600's with an FJO box. I would prefer not to split these up, asking $400. Sorry for not taking the injectors out of the car before pictures, but here is them in the car:
Precision 6766 jb t4 turbo with 1.32 exhaust housing for sale. Only 3 total passes on this turbo. Very mint. Made great power with this turbo.
$950
2 pauter x-beam rods for b18c1/c5. Perfect condition. Only 3 passes on these. Asking 150 each
203-479-2274 if interested
$950
90mm je pistons designed for 106 stroke k-series k24 block using a 6.05 length rod. pistons have shirts coated by calico. $950 shipped
Means of contact: PM please, or post here
Price: varies on part NO TRADES!!!! EVERYTHING IS OR BEST OFFER, PM ME A REASONABLE PRICE. I would like to sell all of this stuff ASAP but will not take a stupid lowball offer.
5bolt-3"vband adapter, can come with 3" flange and clamp also if needed-$75 for everything
b20 crank pulley, great for supercharged setups-$75
ebay 44mm 4bolt wastegate with flanges and everything-$50
Brand new Bosch 1600cc injectors, plug and play for honda, high impedence, I bought from Evans-tuning-$400
96-97 spec 4.4FD ITR trans, perfect condition-$1000
JDM ITR B18C bottom end with stock b16 head on it-$1100
ITR P73 intake manifold with sensors and TB, 60mm standard bseries tb-$150
Professional Products/AEBS b16/itr head polished intake manifold with polished oem fuel rail-$150
RLZ B-series valvesprings/retainers, made by ferrea from what i understand, with ferrea locks-$275
brand new GATES RACING gsr/itr timing belt, never mounted or anything-$80
home-made catchcan setup, needs new hoses, vents from back of block, u could also run it from the valvecover and have it return into the block-$50
OEM HONDA obd2 b16 distributor with MSD cap, rotor button and blaster SS coil, and NGK plug wires with 10 hrs of run time on them-$225
Means of contact: PM/EMAIL
Price: $10k
1994 Honda Civic SI
214k on chassis
Under 1k on engine and setup
-Car was tuned by Joe @ Tempest Racing
-600whp on race gas @ 23psi 10.30 @ 140 mph
-500whp on pump gas @ 17psi
Engine & Trans
-H22 swap
-Bottom end built by Justice Race Engines; Darton sleeves, CP 9.5-1 pistons, Eagle rods, new bearings, new oil pump, new water pump, and new timing belt
-Skunk2 valve springs and titanium retainers
-JDM Type S camshafts
-Ported Stock intake manifold
-Precision 1000cc Injectors
-GM 3bar Map sensor
-Hondata S300 w/ boost
-Hasport Billet swap mounts
-H22 LSD Transmission
-Competition Clutch Twin Disc
-Driveshaft Shop 2.9 axles
Turbo Kit
-Custom in house "mini ram" Manifold
-Precision SC61 T4 turbo
-Turbosmart Deltagate 48mm wastegate w/ stainless dump tube
-Turbosmart Stealth BOV
-Custom 3" Stainless Vband downpipe
-Custom 3" intercooler w/ vibrant core
-Custom 3" aluminum intercooler piping w/ tbolt clamps
-AEM electronic boost controller w/ push to lock lines
-AN oil feed and return lines
Brakes & Suspension
-Powerslot front rotors
-Hawk pads Front and rear
-Stainless steel braided brake lines
-Tokico HP series struts
-Ground control coilovers
-Energy suspension poly control arm bushings front and rear
Car
-Custom 3" catback w/ Vibrant stealth muffler
-Falken Hanabi 15" bronze wheels
-BFG drag radials
-USDM Type R front seats
-Momo Steering wheel
-VIS carbon fiber hood
-JDM amber turn signals
-Pioneer head unit
-Pioneer speakers
-Boost gauge
Pictures:
Price: $10k
1994 Honda Civic SI
214k on chassis
Engine & Trans
-H22 swap
-GM 3bar Map sensor
Turbo Kit
Brakes & Suspension
Car
-BFG drag radials
-Pioneer head unit
-Pioneer speakers
-Boost gauge
Pictures:
AEM injector driver $100
4" bell mouth $50
Toda B cams $600
Pro Drive Spool $300
Gator stage 3 axles with hubs $700
Love Fab manifold brand new $550
water box 16x12x10 with -16 fittings $250
Power FC with commander $600
MSD Pro coil $50
OBD1 to OBD 2 harness $40
Earls 19 row oil cooler $130
MSD 2 Step $40
RCI seat belts blue $95 for both
Password JDM LS intake Gasket New $25
Sparco 2" seat belt blue $60
4" bell mouth $50
Toda B cams $600
MSD Pro coil $50
MSD 2 Step $40
I bought this T4 top mount i was going to use on my ef and it did not clear...it was made for a eg/dc or will also work with an ek...i just got it back from getting JETHOT coated and so now im stuck with a ramhorn manifold...im asking $600 for the top mount and the Turbosmart 48mm waste gate and dump...
next im selling a turbo for a friend that would work perfect with this manifold it is a Garrett GTX4294 dual ball bearing with billet wheel and 1.25 A/R was used for a couple dyno pulls and a few passes down the track...then got a rebuild, turbo has zero miles since rebuild..asking $1800 (killer deal for what its worth)
let me know guys im located in Chicago and shipping is not included in the price thanks
ERICK
ERICK
FS: 4 Gallon RCI Fuel Cell w/ foam $110 Shipped in lower 48
Parachute Mount for 92-95 Civic Sedan & Coupe $100 Shipped in lower 48
Does not include parachute. Just the mount, and filler panel.
Thanks
Jordan@JordanTuned.com
Thanks
Black 13 x 7.5 Lenso Drag rims 4x100 with "24.5 x 8" Mickey Thompson slicks used on the track only never used on street surfaces. No wheel spacers are needed Plenty of meat left on them. If serious text 516-234-5988 pick up locally in NYC/Long Island/Norwalk CT area Price $600 or best reasonable cash offer
Pic of them on my car @ Englishtown...
got a cnc staging brake and tilton brake master cylinder for sale. The staging brake was just used for mock up looking to get 160 obo for it and the master cyinder is used it comes with a mounting plate 120 obo i can ship if needed and i also take paypal any questions pm or email jokerman1416@yahoo.com thanks
Selling some quality parts everything is barely used and has just a few passes on them. Changing my setup slightly, otherwise I wouldn't sell at all.
Exedy Twin Disc-Sold
Ferrea T1 Cams/Roller Rocker assembly- Absolutely sick Cams and rollers....still not sure I want to sell em - $1,800
Precision Billet 6765 T4, V-band, JB, H cover Single Scroll-SOLD
GSR Trans with Liberty Faceplated Gears (Dog Engagement) With handcuff and Richmond Spool (can sell all together or seperate) $1,800 Complete/Assembled Gear stack alone $1,400
86mm DARTON SLEEVED BLOCK.
THE BLOCK IS IN MINT CONDITION AND FRESH OUT THE MACHINE SHOP AND READY TO GO. MACHINE WORK DONE BY EVOLUTION RACING ENGINES.
ASKING $750 LOOKING TO MOVE THIS FAST. I REALLY DONT WANT TO SELL THIS BUT I NEED TO IN ORDER TO COMPLETE MY CAR.
LOCATED IN JAMAICA NY 11434
631 960 5216
631 960 5216
If interested text (857) 719-7186 for quicker response.
ACT B-series Xtreme Pressure Plate(Less than 50 miles)-$200+paypal fees. I'll pay for shipping
Part number- H025X
ACT B-series Prolite Flywheel(same thing, less than 50 miles)-$185+paypal fees. I'll pay for shipping.
Part number- H025X
Up for sale is my 2.7L k24 long block built by 4Piston Racing. This motor has only been ran in the garage and on the dyno. Never been raced. Complete valve cover to pan.
The motor has the following :
-4Piston Pro 163 CNC head
-4Piston billet K600 single lobe cams
-Ferrea aluminum rockers
-4Piston valve springs
-4Piston valves
-ERL sleeved block
-Billet 106mm crank
-GRP Aluminum rods (4Piston spec)
-Wiseco pistons (4Piston spec) 16.5:1 CR
-ERL s2k oil pump
More detailed build specs and dyno numbers can be given to buyer.
$10,500 OBO
Also for sale is my Albins 4 speed helical dog box.
Trans has the following:
-Albins helical cut dog engagement 4 speed gear set, final drive, shift forks
1st gear : 2.55
2nd gear : 1.72
3rd gear : 1.32
4th gear : 1.08
Final Drive : 5.23
-MFactory LSD differential
-New OEM bearings thru out
This transmission was assembled by a certified Honda technician. Again this transmission has not seen track time. Only been on the dyno.
$6500 OBO
I am willing to separate the head and block. Also willing to sell just the gear set with out diff and case.
-4Piston valves
-ERL sleeved block
-Billet 106mm crank
-ERL s2k oil pump
$10,500 OBO
1st gear : 2.55
2nd gear : 1.72
3rd gear : 1.32
4th gear : 1.08
Final Drive : 5.23
$6500 OBO
selling for a friend AEBS sleeved b18c5(integra type R block same as GSR) block is 84mm and needs to be cleand up to 84.5 to be ran block is bare no crank,matching caps.call or text him questions. mateen 586 260 7765 asking $$$700 for quick sale.
