Jan FS Thread
Selling a Powertrain Control Solutions D200 dash datalogger. Includes mounting bezel for EK Civic and complete wire harness. Everything is in excellent condition and the dash works perfect. Asking $675 shipped.
NOT PARTING OUT...DONT ASK!!
Tried this a while back and got a bunch of flakers. No cheap ebay crap here...all name brand stuff in excellent shape.
So here we go....
Im looking to trade my fully built B series swap for a full K swap. Meaning i want cables, axles, motor, kpro...pretty much everything to drop it in my car. So what i have is this:
BOTTOM END:
B18A1 with golden eagle sleeves opened up to 84mm.
Wiseco 8.5 to 1 pistons
Eagle rods
ARP everything
OEM crank
-10 AN tapped oem oil pan
balanced to 10k rpm
Golden eagle oil filter sandwich plate
Brand new OEM R oil pump
All honda OEM gaskets and fasteners
No leaks no drips
HEAD:
B16 head
Supertech valves
supertech springs
supertech retainers
ARP head studs
Skunk2 Pro1 cams
STR pro series cam gears
Edlebrock Victor X powdercoated black (not spray painted)
Golden Eagle pro series fuel rail (black)
OEM B20 head gasket
Stock LS throttle body
Stripped valve cover with -12AN fittings and baffle
Hondata 4 bar map sensor
OEM distributor
MSD wires
DRIVE TRAIN:
Stock LS transmission, Excellent shape no grinds at all (used synchormesh)
Competition Clutch Twin Disc with 1 dyno session
DSS 3.9 axles, all brand new with hubs and lug studs never installed
Shift Linkage (stock)
dual bend shift **** (stock)
Solid rear mount and urethane filled front mounts
EXTRAS:
AFI ramhorn turbo manifold T3/44mm gate
AFI 3" v-band downpipe
AFI dumptube
Custom catch can with x2 -12an fittings and x1 -8AN fitting for oil return
Any questions or interest, call or text at 509-496-8108
Swapped the hubs for 4x100 hubs
Comp Twin
Catchcan
So here we go....
BOTTOM END:
Eagle rods
ARP everything
OEM crank
balanced to 10k rpm
No leaks no drips
HEAD:
B16 head
Supertech valves
supertech springs
supertech retainers
ARP head studs
Skunk2 Pro1 cams
OEM B20 head gasket
OEM distributor
MSD wires
DRIVE TRAIN:
EXTRAS:
AFI dumptube
Comp Twin
Catchcan
AEM AQ1 logger and harness. Harness was cut short, but is still usable and can be extended. $175.00 shipped.
AEM 4 channel wideband controller, harness and (4) AEM wideband sensors. Used for dyno session, and 2-3 passes at track. Allowed me to dial in each cylinder perfectly. $600.00 shipped.
AEM EGT sensor kit. Out of box, but new. $125.00 shipped.
AEM EMS 4 mini harness. Out of box, but new. $75.00 shipped.
AEM high output inductive coils. $200.00 shipped for (4). Good for 250-300 whp per cylinder, no CDI needed.
Longacre toe adjustment kit. Used twice, good condition. Great tool for making remote suspension changes (track) $175.00 shipped.
Longacre Digital caster/camber kit. Used twice, good condition. Great tool for making remote suspension changes (track) $200.00 shipped.
K series PRB cylinder head. Comes with valve cover (not pictured), cams, valvetrain, rockers, bolts. Missing coolant temp sensor, and misc items such as coolant neck. In good working condition. $650.00 shipped.
Brand new Bogart 15x11 RT-4 spoke style wheels. Polished lip with anodized center. Ultra light dual bead lock option. Mounted on a set of brand new Mickey Thompson 26 x 10.5 slicks. $1750.00. Will dismount and ship wheels separately. $1500.00 shipped on wheels alone (no tires).
RBC intake manifold. Used, good condition. $125.00 shipped.
Misimoto Civic Radiator Hoses Part #MMHOSE-CIV-92BK. Used for mock up. $45.00 shipped.
K20z3 1-4 gear main/countershaft assembly. Changed out OEM 1-4th and counter/main shaft for Albins helical syncro set. Gears/syncros had 38,000 miles on them. $350.00 shipped.
Not looking for trades. Shipping is included in pricing to the 48 states. Any questions PM or email at tech@evans-tuning.com.
I Was planning on using these parts but unfortunately
Went a different route. All parts are in great shape and guarentee work 100%
-itr flywheel in excellent condition with a fresh Resurface
-act heavy duty pressure plate in good shape
-F1 racing 6puck sprung disc (new)
Please bump my thread
I'm asking $260 for everything. 760 792 4966
i have a mint all parts are brand new only 2 seasons thats about 16 events its a quaife gear set with the diff all new bearings and syncros for $5,000 or i can sell u just the gear set call or text (856) 332 5450
Designed for the Civic DOHC VTEC (B16-160bhp) type P20 gearboxes, this 5 speed racing and high performance gearkit has ultra-close ratios to keep the engine revs up and in the power band. The taller first gear is more useable for high-powered cars and allows you to carry more speed. The remaining four gears are spaced tightly to take advantage of a VTEC's high rpm power.
Each gearkit comes with a new Heavy Duty mainshaft, first through fifth gears, and an HD ring and pinion.
Gears are helical cut, with large tooth profiles to endure the higher loads seen in competition, yet the synchromesh engagement ensures everyday driveability for the street.
GEAR RATIOS
gear input output ratio rev drop @ 8000 rpm shift
1 13teeth 32 teeth 2.462 -
2 16 29 1.813 2109 rpm
3 18 27 1.500 1381 rpm
4 20 25 1.250 1333 rpm
5 22 23 1.045 1312 rpm
FINAL DRIVE RATIO
4.750
there are some videos u can watch so u can hear how it works the 11 sec videos the cam is making 375 hp and reving to 9k need to rev it higher or put a bigger tire on it if u want to stay in 4th gear tru the traps
this trans is good for the drag or scca events or just a fun street car
if your looking for A DIRECT PORT NOS KIT i have one for sale and i can sell u the motor that i used in the video a 13to 1 lsv
GEAR RATIOS
FINAL DRIVE RATIO
4.750
*BNIB Aem water meth kit Reg $422 SALE: $300
*(2) Aeromotive 340 Stealth pumps $ 179 SALE: $120 Used for 4.2miles on the dyno or less than 2hrs time. Made 861hp & 545tq and 932/610tq on 36psi
*Fullblown hanger for DC/EG Reg $299 SALE: $220 -10 feed -8 return
*MSD Digital 6 Plus Reg $299 SALE: $220 obo
*MSD HVC2 coil (blue) Reg $180 SALE: $100 SOLD
All parts are pretty much brand new, ill take more pics if any1 wants them. Paypal or meet up if your local... Ill ship the following day from when i recieve payment. Plz add the 3% paypal to your total.
Text me or call me 714-388-7303 I DONT (I repeat ) DONT log into HT often so if you Pm me i might not respond as fast as a text message.
Gforce B Series Dogbox****** SOLD********
PCI Bronze Bushing Kit for EG Front Upper Control Arm-$100
97 Civic Hatch Stock Mirrors and Tail Lights - $50 a pair
C02 Bottle with regulator and roll bar mount- $100
3.5" Aluminum Exhaust with Vibrant Race Muffler All V Bands -$200 pick up only
99-00 Civic Vis Carbon Fiber Hood slight fire damage but still in good working shape
$100 pick up only
All Prices do not include shipping and paypal fees Contact through pm or email Juice2435@aol.com
$100 pick up only
Full-Race T3 ramhorn and matching Full-Race 3"downpipne $950
BWR T3 topmount SOLD
DSS 3.9 axles never used since rebuild. i have hubs for big bearing or small. $900
All parts are brand new and only mocked up on car
Precision 6235 DBB turbocharger Brand new $1100
JDL B series topmount manifold t3/44mm Brand new $650
JDL 750HP Backdoor FMIC $550
Items are the large FMIC and Manifold on Left
Please PM me with any questions or for shipping quotes
Precision Turbo PT6262 Turbocharger BALL BEARING
CEA® (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging Higher efficiency and faster transient response for maximum power and performance
-62mm inducer compressor wheel
-"Ported S" compressor cover 4.0" inlet/2.5" outlet
-V-Band inlet .82 A/R with V-Band discharge
-HP Rating: 705
Turbo is BRAND NEW NEVER RAN. Used only for mock up. Has a small nick in the compressor cover (pictures below)
Asking: $1000.00
-HP Rating: 705
Asking: $1000.00
PCS Dash Logger D200 Pro Kit with extras, $1000 FIRM.
Part Number: DIS-9300
Suggested Retail is $2050.00 for the pro kit.
Here is some info on it:
The D200 Pro Kit is designed for the racer who wants all the components of a solid data acquisition foundation.
Included in the kit:
•D200 6" Touch Screen Dash Logger. Part Num DIS-2022
•8-Channel EGT Module. Part Num EGT-2000
•3-Axis Accelerometer. Part Num ACC-2000
•CAN Master Connection Kit. Part Num CON-5500
•CAN Add-On Connection Kit. Part Num CON-5501
6 sensors, (4 of SNS-1004, 2 of SNS-1003)
4 EGT probes, (can purchase additional probes and have up to 8).
This can do speed, pressure, temperature and EGT measurements. Has six sensors total, 4 EGT probes, and an extra harness for easy swapping from car to car. You can use this for a 4, 6, or 8 cylinder motor, and can add on more EGT probes.
Pm me if interested.
Parting out my turbo race car everything is for sale. The parts are all almost brand new minus the ones i specify, Everything was bought new, used for 3 dyno sessions and 3 events with a total of 7 passes.
PRICE DROP ON ALOT OF STUFF PLUS UPDATED MORE PARTS SOLD
1992 Honda Civic DX, (clean title) Painted recently olive green, most window seals and moldings outside the car and on door and window are brand new bought from dealer, all bushings including trailing arm bushings have been changed to polyurethane, cage was done by Steen Chassis including the seat brackets made for Kirkey Seats ( included ), the cage is by far the cleanest and tightest cage I have ever seen, nice fitting duckbill ( no gaps or height issue) carbon fiber hood included + original hood, Momo wheel. and other goodies. $5000
Simpson Medium Size Helmet $175 (looks brand new just one small ding from hitting my head on roll cage trying to get out of the car)
Simpson Large Jacket $200(used twice, no smells or odors or stains looks brand new smells brand new)
Simpson Large Pants $170
Simpson Neck Brace $30
Simpson Bag $30 ( dicontinued model, made for helmet but i personally kept all my clothing and accessories inside)
Crow Gloves Size Large $30
Weldon DB2015A Fuel Pump Used for a very very short time $450
B Series Vtec engine harness $200 ( harness was modified, i got rid of all the plastic conduit and replaced with some high quality heat shrink. I also eliminated anything that wasnt being used on the harness, my car didnt have a IACV so it does not have a connector for it)
JG B series Intake manifold (modified by Bubba at Do-It Dyno) Also eliminates Idle air control valve $350
RPM Throttle Body 68mm $150
Sraight Line Specialties (SLS) Twin Scroll T4 Manifold $900 ( PRICE DROP ) (downpipe and dump tubes NOT included, but i am included the ARP mounting bolts)
Moroso 5.5Quart Oil Pan w/ Oil pick up $200 ( Price Dropped )
Skunk 2 Rear lower control arm $150.00 ( price drop )
Skunk2 Front Camber Kit $150 ( price drop )
Moroso Oil Catch Can $70 ( price drop )
Greddy Type S Original BOV $100
MSD Digital 6-Plus Ignition Control $180
Cusco Master Cylinder Brace $60
Innovative B series Driver Side Motor Mount $40
Place Racing B series Transmission Motor Mount $40
GSR Distributor w/ MSD Cap $120
B Series Alternator w/ AEM pulley $60
Vibrant Boost Brace (1 aluminum and 1 steel set) I used 1 nipple on the intercooler (aluminum) and 1 on the intercooler pipe (steel) to ensure i would not pop intercooler pipes and have to take the bumper off. $20 each
Any questions call or text Alex (818) 279 5202
charcoal/gunmetal
lenso fronts 13x7.5
xpd skinnies 15x3.5
hardly used
look brand new
wheels only! N0 tires! will not seperate.
$1000 firm
lenso fronts 13x7.5
xpd skinnies 15x3.5
hardly used
look brand new
$1000 firm
Aeromotive A1000 fuel pump with 8an male fittings SOLD
RCI 5 Gallon 2050D plastic fuel cell w/ foam 8an fittings two straps everything pictured $100.00 plus shipping OBO
- Crower I Beam rods for b18a, b18b, b20. Not the cheaper H Beam
Barely used 3-5k mile set in great condition. These rods have been balanced by the machine shop. No damage or spun bearings.
$400 shipped
- New Built B20 Shortblock For Sale
All machine work done by RS Machines
Fresh Block with 0 miles
B20Z Block bore, hone, and decked 85mm
85mm RS Machines pistons ITR Spec
OEM LS rods with ARP Rod Bolts
LS Crank Micropolished STD Size
ACL Race Bearings STD size
Used ITR oil pump less than 5k miles
Used ITR water pump less than 5k miles
mains bearing clearance .0012-.0014
rod bearing clearance .0015-.0017
Piston ring gap
Top ring gap .015
second ring gap .019
$1100 PRICE REDUCED
Please text me at 925.586.seven3seven1
$400 shipped
Piston ring gap
Top ring gap .015
$1100 PRICE REDUCED
706-346-6024
matt.stover@comcast.net
ATI Street Damper: $250
MSD Digital 6: $200
Aeromotive Pro Pump - Flows a shitload
$525
-Precision GT4272R, 1.28 divided T4, 4" outlet
$1675
-Custom Forward Facing Turbo Manifold, Selling for someone else, test fitted on my car to show pictures. Fabricated by Joe Simpson at Tempest Racing.
With 4" SS Downpipe
Flanged for 60mm Tial
$1200
Liberty's Gears 1st generation 3rd gear, countershaft side, 34 teeth, 1.36:1
I no longer need to keep it as a spare
$100 OBO
MSD Digital 6: $200
$525
$1675
With 4" SS Downpipe
$1200
$100 OBO
3 GRP B-series aluminum rods standard LS length rod. 2 are mint other is slightly damaged from the engine letting go. Comes with 3 84MM (GSR)CP pistons with upgraded wrist pins. This combo had 30 passes on it when #4 rod spun a bearing. $250 for everything.
Golden Eagle main girdle comes with matching Ls main caps. Girdle has been clearanced for big rods.SOLD!
ARP Head Stud Kit - LS Vtec Conversion #208-4303 torqued once $80
ARP b-series Main Studs #208-5403 torqued once SOLD
TEXT/CALL 760-936-2053
I am selling a set of brand new never used legit Skunk2 Pro series stage 2 cams for B series motors. I realized that these cams where to high/lift for my stock b18c block. So i went with the PRO 1's. I paid $650 for these cams and im asking $575 OBO Will ship at buyers expense please include paypal fee. Thanks for looking if you have any questions let me know.
pro 2- $$575.00 OR BEST OFFER
Im selling a brand new never installed or used , B Series COP (k Series/ S2000) conversion Harness for the AEM EPM. The harness was made by Joel at Speed Theory Racing and Development in NY. The quality and attention to detail that they put in there work is unmatched.
Price $ 210 OR BEST OFFER
Part is SOLD!!!!
Clutch Masters FCV-2000 Flow Control Valve
Purchased this new, had it on my car for about a week and ended up not needing it, so it is basically brand new. Really helps smooth out clutch engagement on cars with multi-plate clutches, but can be used on any style clutch with no problems.
$80.00 shipped via USPS in the conus
Paypal only.....
PM me or shoot me an email at niner555@hotmail.com
Thanks,
Matt
Paypal only.....
Thanks,
Matt
Forsale:
Jonathan Hedrick
Text me at 336-479-2404
Keizer wheels, 4x100 13x10 front, 15x4 rear, Mickey Thompson tires 24.5x8/26" skinnies-$1000
Kens Custom brake booster delete-$150
Full Blown -10an fuel rail-$135
Magnafuel regulator with blackworks gauge-$220
Ktuned traction bars with B series front mount-$370
Aeromotive fuel sample valve-$75
Jegs alcohol -10an fuel filters x2-$65 each
Billet fuel filter mounts x2-$30 each
30x12x4 cx racing intercooler,3" inlet/outlet-$150
Turbo setup-BRMS forward facing twin scroll manifold, Borg Warner s400 67mm 1.10 ar, 2x purple Tial 44mm wastegates with all springs, stainless steel dumptubes which exit the hood, turbo blanket-$2800
AEBS built b16a2 head and bottom end, sleeved and o-ringed, pauter rods, ross pistons, head is stock port with rev valves and valve train, stock cams-$3500
Don't have a lot of individual pics so I'll post some bay shots. If there's anything in particular anyone wants pics of, I'll take some.
Jonathan Hedrick
IF INTERESTED CALL 973)390-2982
Weld skinnies with tires 23"x5"x15" powder coated black $1,200
Garrett turbo gt42 billet 72mm ind 102 exd 1.44 a/r...made 865 @35psi... in excellent condition no shaft play no smoking and makes great power $2,000
custom catch can sits next to the battery $275
the bracket is welded onto the battery tray*
comes with
battery tray w/ bracket welded to it
all 4 lines and fittings minus the 2 fittins on the actual block
B-series shift linkage with a B16 shifter
comes with
