ITBs vs. TB & IM
Old Dec 15, 2002 | 03:24 PM
teg92's Avatar
Default ITBs vs. TB & IM
All the most powerful all motor engines that we see either on http://www.importreview.com or on the board are all running ITBs. Yet on the other hand, the worlds fastest all motor car is not running ITBs.
Are ITBs better for track racing as opposed to drag racing? Or does Erick's car have more potential if he went with a well tuned ITB setup vs. his 70mm TB and (obviously) very modified P72 IM.
Old Dec 15, 2002 | 08:14 PM
1 2 NV's Avatar
Default Re: ITBs vs. TB & IM (teg92)
i dont have the exact answer but i think u could better spend the money elsewhere rather than on ITBs. do somethin really trick to hte motor for the 2k ur goin to spend on ITBs. the price is outrageous. i know some ppl will flame me but thats ok cause those will b the guys that jump the bandwagons.
Old Dec 15, 2002 | 08:15 PM
teg92's Avatar
Default Re: ITBs vs. TB & IM (hondaatwsu)
Theres no shortcuts on my engine, and I'm not getting a 2k kit, I'm custom fabricating one.
Old Dec 15, 2002 | 09:03 PM
TEAMGENDAI's Avatar
Preference
Old Dec 15, 2002 | 10:32 PM
GokuSSJ4's Avatar
Default Re:
you dont necessary need ITB ,there more for road racing then drag .
Ericks is able to acomplish 10.2 with his TB ,IMO i think thats more then enough for any street driven car and all motor drag car.
Old Dec 16, 2002 | 02:31 PM
Drag_Dc2's Avatar
Default Re: Re: (Spoon1)
When Erick's racing ran the 10.2 was he still using the GSR manifold, or did he switch to the JG-edelbrock piece? I hard norm aubry and a few other cars switched to the JG piece.
Old Dec 16, 2002 | 02:38 PM
teg92's Avatar
Definately, but my question is, why don't we see more street cars making 240-250whp without ITBs? From the threads and plots I've come across, all the 225-230whp+ cars are running ITBs. I'm not trying to **** people off by saying ITBs are the only way to go, I'm trying to understand the capabilities of the two systems.
[Modified by teg92, 6:38 PM 12/16/2002]
Old Dec 16, 2002 | 06:15 PM
genius's Avatar
Default Re: Re: (teg92)
JG intake manifold with a 70mm TB outflowed my ITB's (TWM 50mm)
so this combination should produse same or better peak HP.
Downside of that is lack of throttle response due to the large volume of the IM.
This is why road recers prefer itb's over im/tb, they get good peak and great throttle response.
If i was putting a my motor together again i'd stick with IM/TB....ITB's are a hassle(tunning,drivability and gas milage...too many headaches)
If you can make same power with IM/TB then it's not worth it unless you plan to road race.
Old Dec 16, 2002 | 06:27 PM
teg92's Avatar
Default Re: Re: (genius)
genius, did you dyno both with the TWM ITBs and your jg/70mm combo? I'd imagine the torque and power curves would be very different.
I am going to attempt to drive this thing daily, but then again everyone would think I am nuts because I have no problems driving my nonvtec motor with 404's... I'm now going to run 405a's on the street... I don't mind flat on its face till 3000rpm...
Anyway, I did purchase a set of CBR954RR ITBs I am planning on custom fitting to my head and would really like to see the challenge and see what the fuss is about, but if I can be assured with a JG manifold and 70mm TB I could make just as good power, well its gonna be a tough choice. Its basically gonna cost me the same thing to run this custom ITB setup as it would to get the JG & 70mm TB, so you've got to factor in the coolness factor, originality, and that slim possibility that I could just get this thing to work pretty damn well...
Old Dec 16, 2002 | 06:52 PM
genius's Avatar
never dynoed the two on the same motor.
how big are the cbr itb's?..if smaller then 50mm and you going for drag motor then forget it .
remember those itb's were feeding 1L motor and your motor is 1.8+ i assume
Old Dec 16, 2002 | 06:56 PM
teg92's Avatar
Hmm hard to say that those ITBs aren't giving you much more "area under the curve"...
They CBR ITBs are 43mm... Its not a drag motor, more of a nice trophy motor I can enjoy building, researching, learning, running at the odd drag strip and really enjoy lapping, and also be able to drive it around town...
What do you think of this...
quoted from http://www.jenvey.co.uk
<u>What is the best throttle body diameter?</u>
Factors influencing size are; Power output, RPM, cylinder head design, cylinder capacity, position of the throttle body in the inlet tract and position of the injector.
Choice of bore size is a balanced compromise resulting from the following;
1) A larger bore leads to lower flow resistance, but obeying the laws of diminishing returns.
2) A smaller bore leads to better throttle control and response (never underestimate) and improved fuel mixing.
3) The system should be considered in total - from (at least) trumpet flange to cylinder and proportioned accordingly.
Basic references for BHP per cylinder, assuming ca 120mm from butterfly to valve head and a max of 9,000 rpm are;
Up to 30 - 30mm, up to 33 - 32mm, up to 39 - 35mm, up to 46 - 38mm, up to 51 - 40mm, up to 56 - 42mm , up to 65 - 45mm, up to 74 - 48mm, up to 80 - 50mm, up to 87 - 52mm, up to 93 - 54mm.
These power figures may be increased by up to 10% in a purpose - designed, well proportioned system. As butterfly to valve distance increases, butterfly size will need to increase in proportion to system taper and vice versa. Lower revving engines and those with injectors placed before the butterfly will generally accept a larger body.
For the power I expect to make, 42mm is what these guys recommend +/- 10%...
[Modified by teg92, 10:57 PM 12/16/2002]
Old Dec 16, 2002 | 09:36 PM
GokuSSJ4's Avatar
Default Re: Re: (DragDc2)
Erick is still using the GSR manifold and his on TB .also about making a huge amount of hp with ITB notice that some of those cars are not that easy to run on the street and the ones that are have sometimes some problems on the low end
Old Dec 16, 2002 | 10:06 PM
teg92's Avatar
Are you going with an ITR manifold, P72 manifold or JG manifold? I am assuming you went with a 70mm ER TB?
Old Dec 17, 2002 | 02:08 AM
Drag_Dc2's Avatar
Teg92,
Do you have any pictures of the 929RR ITBS? or have you come across any websites or forums regarding technical information on the fuel injected CBR's???
How are you going to go about injectors, i think i read something about the Fuel injected bikes have something like 4 different settings or positions not exactly sure but they are not the same as our injectors.
Old Dec 17, 2002 | 04:41 AM
KS-R's Avatar
Here's a site with a bit of info on building your own ITBs. I'm basically trying to build the same setup for my motor, but after reading this thread... I might reconsider... If you're wondering.. I'm using a set of ITBs off of a JDM spec Toyota 20valve motor... Can't remember the engine code, but it's out of the corrolla and trueno..
Old Dec 17, 2002 | 06:22 AM
Jeff C's Avatar
Default Re: Re: (KS-R)
Where? Did you forget to post it?
Old Dec 17, 2002 | 06:32 AM
Jeff C's Avatar
Here's pics from liam821 ITB Pics. These are showing the 929RR itb compared to a d series mainfold.
I found this last night...http://www.abdgraphics.com/iansite/ianthrottlebody2.htm. They are for a *cough* Neon *cough*, but it is the same principle.
Old Dec 17, 2002 | 09:17 AM
teg92's Avatar
Yup the 4A-GE has got a nice set, I believe they are 50mm.
Disregarding the typical "unstreetable" characteristics of ITBs, wouldn't ITBs provide much superior throttle response and torque/power curves vs. TB/IM?
[Modified by teg92, 1:18 PM 12/17/2002]
Old Dec 17, 2002 | 10:01 AM
KS-R's Avatar
Default Re: Re: (Jeff C)
Opps... Silly me.. I forgot the link
Here you go;
Old Dec 17, 2002 | 10:59 AM
Jeff C's Avatar
EDIT: You are right I moved my post too.
[Modified by Jeff C, 3:56 PM 12/17/2002]
Old Dec 17, 2002 | 11:42 AM
teg92's Avatar
EDIT: I posted my reply to this in my other thread concerning the dynamics of ITBs more... We should allow this thread to discuss the benefits of ITBs vs a traditional setup.
[Modified by teg92, 3:44 PM 12/17/2002]
Old Dec 19, 2002 | 09:44 AM
JCushing's Avatar
a bump to keep the post goin
Old Dec 21, 2002 | 02:14 PM
79 civic's Avatar
Default Re: Re: (JCushing)
sorry Benny
_______
[Modified by 79 civic, 5:40 AM 12/23/2002]
Old Dec 22, 2002 | 06:00 AM
KS-R's Avatar
Default Re: Re: (79 civic)
WHAT? $260? That's cheap, but what kind of manifold? Is he making it from scratch? How is he going to make it to incorporate all the sensors.. Seems like the runners are going to be too long if he has to include all the sensors..
Besides... I don't think all ITBs are the same.. so.. how is he going to build a set to accomodate for all the different brands of ITBs?
Old Dec 22, 2002 | 08:36 PM
Benny Hinn's Avatar
79 civic
please delete your post asap.
call my cellphone
Thanks
