Injector sizing?
Old Mar 17, 2005 | 09:09 PM
RI_TM's Avatar
Default Injector sizing?
Posted this in Forced induction forum but just wanted to see if i can get any response in here...
Opinions on what size injectors to be running on my set-up...
LS/Vtec
B18 bottom block
Eagle Rods
Weisco Pistons(11.5 comp./81.5 bore)
GSR Head
Skunk2 manifold
REV valve springs and retainers
Blox stage 2 cams
JDM 4-1 headers
Single fogger 80-90
I have a set of RC 550 brand new and just found out that it'll be to big. I don't have engine management to control the injectors except for just a VAFCII.
Suggestions are open...
Thanks, ahead of time.
Old Mar 17, 2005 | 10:27 PM
JL's Avatar
JL
Default Re: Injector sizing? (RI_TM)
http://www.rceng.com/technical.htm
might help. i've been looking into injector sizing myself.
Old Mar 18, 2005 | 09:07 AM
xtrac1's Avatar
rookn00b
The factory injectors are rated at about 240cc/min. Using the VAFC will allow you to run a 270, 310 or 370cc injector without compromising the idle or low RPM drivability. Highly recommend tuning the VAFC on the dyno. The 370cc injector should supply enough fuel to maintain a safe air/fuel ratio and at the same time you'll have a small reserve of fuel left over (just in case you switch to lager cams, etc..). If you're running a dry nitrous system, you might need a 440cc injector with better ECU control.
Old Mar 18, 2005 | 09:48 AM
RI_TM's Avatar
Default Re: Injector sizing? (suprfast)
i'm still trying to get everything together. My combo's aren't coming together yet....
i'll let you guys know if i need any help. Thanks by the way.
Old Mar 21, 2005 | 02:39 PM
slugzed's Avatar
ditch the vafc and go with crome or uberdata...if u got money..get hondata...
bpoweredeg6
Mar 22, 2011 01:27 PM
RI_TM
Mar 17, 2005 09:12 PM
DcWest
Feb 1, 2005 07:10 AM
Turbo-JC
Jul 17, 2003 11:12 AM
FAST94GSR
Nov 18, 2001 01:40 PM
