Initial startup with Hondata S300
Old Mar 23, 2006 | 03:50 AM
Mikey3000's Avatar
Default Initial startup with Hondata S300
I opened a new "stockh22" configuration on my laptop, made some adjustments i.e. injector size, map sensor, etc. and saved as "inital startup" so i think i'm ready to go. my question is: Do I install the ECU in the car first, then plug up the laptop or how does that work?
Old Mar 23, 2006 | 04:03 AM
b19coupe's Avatar
Default Re: Initial startup with Hondata S300 (Mikey3000)
Plug in the ECU, turn the key on, and upload the program to the ECU via the USB cable. You will need to update the USB driver on your laptop once the ECU is plugged in and the key is turned on. Open SManager and click on "help" and then "update USB drivers". Follow the prompts.
Old Mar 23, 2006 | 06:22 AM
Mikey3000's Avatar
Default Re: Initial startup with Hondata S300 (b19coupe)
sweet thanks
Rheg6
Engine Management and Tuning
Nov 28, 2011 12:02 PM
Doobie/ej1
Feb 23, 2011 10:32 PM
BUCK_NASTY
Apr 20, 2007 08:55 PM
trick_db
Apr 30, 2006 09:10 AM
dynamicRacing719
Dec 5, 2005 03:44 PM
