I need traction
Old Apr 24, 2005 | 11:08 PM
b20turboteg's Avatar
Default I need traction any help
I have a turbo b20 vtec at 9psi I spin all of first and second and Im running a ls tranny with lsd any help
Old Apr 25, 2005 | 12:16 AM
Kataku2K3's Avatar
Default Re: I need traction any help (b20turboteg)
Slicks? Is this on the street? You have too much power!
Old Apr 25, 2005 | 01:31 AM
GAME OVER 2007's Avatar
slicks will help
Old Apr 25, 2005 | 10:03 AM
its on the streets i ran falkens before but same problem
Old Apr 25, 2005 | 10:23 AM
Kataku2K3's Avatar
Default Re: (b20turboteg)
Turn down your boost or get some decent street slicks (M&H ) then... It's either that or get yourself an extremely nice, probably overkill EMS with traction control (Motec, etc.) or an MSD Digi 7+ programmable ignition. I don't think you realize that if you're only spinning first and second, you're in okay shape. With a decent amount of power (even on low boost), you shouldn't be hooking. Most high compression NA street motors (with less but more instant power) aren't even going to have traction there. Here's a stupid vid I made last year of a few of the SFWD/T4 cars that Scott and I have built. They're ALL NOT running full boost and you can see how fun traction is. Each of these cars on full boost will break the tires loose in 5th at 100mph+ mph if you want. I'm not trying to brag or anything by any means, you just need to see that what you're dealing with "isn't" that big of an issue...
Right Click and Save Target As:
RandomShit.wmv [~38.9mb]
Modified by Kataku2K3 at 1:54 PM 4/25/2005
Old Apr 25, 2005 | 11:42 AM
Thanks for the advice and great vid what do I need to do for my car to runlike those
Old Apr 25, 2005 | 11:51 AM
dxasaurus's Avatar
Give your car 4 extra reverse gears.
The rest is pretty obvious.
Old Apr 25, 2005 | 12:27 PM
Kataku2K3's Avatar
Default Re: (wettevette)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wettevette &raquo;</TD></TR><TR><TD CLASS="quote">Give your car 4 extra reverse gears.
The rest is pretty obvious. </TD></TR></TABLE>
haha, I still don't think you'd have that great of traction with a 2200-2500lbs chassis...
Old Apr 28, 2005 | 10:40 AM
mrv8killer's Avatar
Get some good suspension like some teins
Old Apr 28, 2005 | 10:41 AM
Kataku2K3's Avatar
Default Re: (mrv8killer)
Tein sucks for drag... We've tried all too many times, even with the EDFC. Inexpensive heavy rated springs in the rear with good shocks work just fine.
Old Apr 28, 2005 | 10:53 AM
mrv8killer's Avatar
Any heavy rated spring
f1 vtec
Feb 20, 2010 03:20 PM
EARLdaSQUIRREL
May 5, 2009 05:42 PM
racerjohn
Oct 29, 2006 11:05 PM
HYBRID_H@TCH
Jan 21, 2006 06:07 PM
onlinehost
Nov 6, 2005 02:24 PM
