How to pull an evo
Old May 21, 2012 | 10:00 AM
zongetsu's Avatar
Default How to pull an evo
So im looking to buy a crx, and the plan is to pull an evo (1/4 mile). I know that most evos run 13 stock. My question is the power plant. For this build i am unsure of the power and parts needed. At the moment i have a starting block in a b18A1. The plan is to make this into LS/vtec, however I am still open to options. How much money would you spend and what would you buy to pull an evo? Would you bore the B-series out? Opinions anyone?
Old May 21, 2012 | 10:07 AM
Dc4LsTeG's Avatar
EK9
Default Re: How to pull an evo
Old May 21, 2012 | 10:15 AM
Vagitarian's Avatar
Slash his tires
Old May 21, 2012 | 10:28 AM
beatontheeznutz's Avatar
bore it .020 over. RS machine P30 pistons. Stock rods modified to fit arp rod bolts. Vtec head. Blox Type C Camshafts. Performer X Intake Manifold w/68mm TB. Tune that BITCH.
Old May 21, 2012 | 11:55 AM
93delsold16z6's Avatar
^^^ what he said
Old May 21, 2012 | 11:59 AM
Aliman's Avatar
you need that Naws, 2 of the big ones.
Old May 21, 2012 | 12:51 PM
GElite's Avatar
I wouldnt do an LS/vtec conversion tho, not for the track. No crankshaft oil squirters equals bad news on sunday.........
Old May 21, 2012 | 01:21 PM
porkythegrunt's Avatar
id just buy his evo.
92redhatch's Avatar
^another dummy
Old May 21, 2012 | 01:24 PM
VRD^don's Avatar
put a tow hitch on!!
Old May 21, 2012 | 01:50 PM
nonvtecallmotor's Avatar
Impossible
IBTL
Old May 21, 2012 | 01:59 PM
sportfwddc2's Avatar
convert your crx to awd and swap a 4g63
Old May 21, 2012 | 02:09 PM
2k.civic.si's Avatar
pickup truck and a thick rope or tow cable. can pull an evo easy
Old May 21, 2012 | 02:15 PM
b16hybridsol's Avatar
lolwutermelon
Old May 21, 2012 | 02:24 PM
Project_EK's Avatar
You Sir, have no clue what your talking about!!
Old May 21, 2012 | 03:07 PM
SwappedTURBOegg's Avatar
this is how pull on evo http://www.youtube.com/watch?v=7jaunmYzdTQ
Old May 21, 2012 | 03:18 PM
fungus mungus's Avatar
With a well-built NA B18 or B20/vtec, you should be able to take a STOCK Evo, especially if you run on slicks. If the EVO has any mods at all, all bets are off.
fm
Old May 21, 2012 | 04:05 PM
K20boostedrex's Avatar
Stock b16-b18 with a mild turbo kit tuned on about 10psi would merk a evo for days
Old May 21, 2012 | 05:37 PM
TheMilkMan's Avatar
All you need is one of each of these:
Oh and some duct tape! Drink the beer well you guys tape the turbo to the manifold, then when you race him, if he pulls ahead you can use the bottle as a weapon and throw it down on the ground so he gets flat tires! Boom goes the dynamite! You win!!
-Mick-
Old May 22, 2012 | 05:09 AM
spoolinlude's Avatar
I live under a rock
I thought this was going to be a question about towing.
lolz.
Old May 22, 2012 | 05:15 AM
pearl's Avatar
I would look for trailer hitches that attach to more than the trunk pan and bumper support.
As long as it attaches to something sturdy that isn't rusted out (like the "frame rails") and have a decent clutch I think you should be good.
I've hauled the equivalent of two motors (b18s) in the backs of several different civics, and integras and never had a problem minus some of the seams pulling apart a little in the trunk floor.
Good luck!
Old May 22, 2012 | 07:00 AM
blackeg's Avatar
And harry, I need it by tonight
Old May 22, 2012 | 01:10 PM
11SECEG's Avatar
LMAO
Old May 22, 2012 | 06:20 PM
MR.johnson's Avatar
you are as dumb as the OP.
Old May 22, 2012 | 06:23 PM
EP3Moschini's Avatar
you will never do it without a wing. . . better get a porche wing, the one with a wing on a wing
