How often to rebuild?
Old Mar 27, 2004 | 06:33 PM
JDM2ndGen's Avatar
Default When is it time to rebuild?
I asked this in the Allmotor forum ...but i thought it would get better answers in the drag forum ...how often do you pro guys and engine builder rebuild or motor ...when something breaks or goes wrong or after a certain amount of miles/runs ...the reason i ask is because im building a 13.5:1+ comp. 85mm Ls/vtec and my friend was argueing with me that im goin to have to rebuild after every run or after a day at the track and etc ...and i just wanted to get your inputs and also your methods on how you know when its time to rebuild ....any info would be appreciated ...
thanks
Joe
Old Mar 27, 2004 | 06:53 PM
Danger's Avatar
Default Re: When is it time to rebuild? (JDM2ndGen)
im no expert but id say wait until something goes wrong to rebuild it . you could go a while w/o it messing up , but at the same time you could blow it up w/ one miss-shift . why take it apart if its running fine ? i guess it depends on how well its assembled .
Old Mar 27, 2004 | 08:05 PM
poorguy's Avatar
Default Re: When is it time to rebuild? (JonnyDanger)
pro motors are normally freshened up after every race
Old Mar 27, 2004 | 08:13 PM
MackSpeed-616's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2ndGen &raquo;</TD></TR><TR><TD CLASS="quote">I asked this in the Allmotor forum ...but i thought it would get better answers in the drag forum ...how often do you pro guys and engine builder rebuild or motor ...when something breaks or goes wrong or after a certain amount of miles/runs ...the reason i ask is because im building a 13.5:1+ comp. 85mm Ls/vtec and my friend was argueing with me that im goin to have to rebuild after every run or after a day at the track and etc ...and i just wanted to get your inputs and also your methods on how you know when its time to rebuild ....any info would be appreciated ...
thanks
Joe</TD></TR></TABLE>
when you are on a pro level it is an entirely different story. the engines are built with components that are meant to provide extreme performance for a very short period of time. same reason nascar teams change their tires after 70miles but you put 30k on yours.
i ran an 86mm 13.5 piston last year with over 100 passes on it and never rebuilt it once. i took it apart a couple months ago and everything was clean as a whistle. dont listen to "your boy" or anyone else for that matter who have no clue what they are talking about.
Old Mar 28, 2004 | 08:39 AM
JDM2ndGen's Avatar
Default Re: When is it time to rebuild? (MackSpeed-616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackSpeed-616 &raquo;</TD></TR><TR><TD CLASS="quote">
i ran an 86mm 13.5 piston last year with over 100 passes on it and never rebuilt it once. i took it apart a couple months ago and everything was clean as a whistle. dont listen to "your boy" or anyone else for that matter who have no clue what they are talking about.</TD></TR></TABLE>yea i know ...i mean this is no where near a pro drag motor its a weekend drag car ....and thanks for the info ...your motor is about the same as mine in compression and bore so that gives me added confidence that is nothing goes wrong i wont have to rebuild it after every race lol ...if anyone else has anymore info or something to say keep it coming ...
Old Mar 28, 2004 | 08:47 AM
SpeedDreamz.com's Avatar
Just like Mack said. Just keep a check on the compression and that is a good way to check the internal condition.
98vtec
Apr 12, 2008 02:52 PM
naSquad_ej8
11
Oct 17, 2005 08:42 PM
ELSpool
Apr 22, 2005 07:23 AM
scca54ita
12
May 18, 2004 08:13 PM
JDM2ndGen
Mar 27, 2004 05:18 PM
