how much power needed for 135mph
Old Sep 19, 2007 | 08:41 PM
adubaz7's Avatar
Default how much power needed for 135mph
I am building my 97 ek hatch and I plan to weigh in at about 2500 with driver and I was wondering about how much power I need to aim for to run 135mph in the 1/4
car will be b16 with 60-1 turbo running on 235/60-15 bias plys
lsd and looking for about 1.7-1.8 60ft
1/4 time not so important I just want the car to pull like a **** up top and if she runs 135mph that is fast to me
Old Sep 19, 2007 | 08:44 PM
.RTErnie's Avatar
Default Re: how much power needed for 135mph (adubaz7)
525-575?
Old Sep 19, 2007 | 10:12 PM
servion's Avatar
I did it with 430whp weighing a little bit less.
Old Sep 19, 2007 | 10:24 PM
.RTErnie's Avatar
Default Re: (servion)
on slicks sure....but not on dr's or street tires.
Old Sep 19, 2007 | 10:26 PM
ls1_datsun's Avatar
Default Re: (.RTErnie)
you'll trap higher on drag radials or slicks...usually.
Old Sep 20, 2007 | 01:49 AM
RICE POLICE SIP's Avatar
Default Re: (ls1_datsun)
So far i'm at 121MPH in a full street trim Del Sol B16 w/ only 330HP and a 1.9 60ft... my best so far was a 1.8 but then I miss shifted so I don't know what it would have been in the end... LOL
Old Sep 20, 2007 | 04:20 AM
b18c195's Avatar
Default Re: (RICE POLICE SIP)
500whp
<------ makes 500whp
weight 2480 with driver
Old Sep 20, 2007 | 06:52 PM
adubaz7's Avatar
Default Re: (b18c195)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c195 &raquo;</TD></TR><TR><TD CLASS="quote">500whp
&lt;------ makes 500whp
damn I just watched that video ****** sick burnout that is what I am looking forward too
Old Sep 20, 2007 | 09:19 PM
JDMisGOOD's Avatar
Default Re: (adubaz7)
Should be able to do it with about 525whp.
Old Sep 20, 2007 | 09:54 PM
.RTErnie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls1_datsun &raquo;</TD></TR><TR><TD CLASS="quote">you'll trap higher on drag radials or slicks...usually.</TD></TR></TABLE>
There comes a point when dr's wont trap higher than slicks.
In the majority of the cases...dr's will trap higher. I trapped 121 on street tires, 118 on slicks. 128 on streets 124 on slicks. As you get near 140...it starts to inverse. I think this is because you're spinning the whole track...vs just the short end.
Old Sep 20, 2007 | 10:44 PM
JDMs1eeper's Avatar
11.58 @ 127, BFG's 367whp 2400lbs w/driver
Old Sep 21, 2007 | 04:18 AM
Miss PSI's Avatar
I'm at 127-128mph on my current setup running on 22x8x13 M&Hs. My slicks are dead though and I can feel the car loosing traction down track.
My last dyno I put down 448whp and my weight should be around 2400, but haven't verified.
Old Sep 21, 2007 | 05:30 AM
morgan@synapse motorsport's Avatar
500-525whp and i figure your hatch should be in the 135mph area on those tires.
we trapped 132mph touching the rev limiter in 4th in my buddies hatch. was making 496whp, and on 24.5" slicks.
Old Sep 21, 2007 | 08:30 AM
servion's Avatar
I made 530whp when I ran 10.4@140 in SF trim.... lol
Old Sep 21, 2007 | 08:37 AM
Humble Performance's Avatar
We made 490hp , unstrapped it off the dyno and went to the track and ran 10.80@135 mph. The car still has more in it , the i/c piping popped off twice and we just left it there. This is a 93' Si hatch and it sits right at 2,400lbs w/ driver.
Old Sep 21, 2007 | 10:11 AM
hybrixt's Avatar
Default Re: (Humble Performance)
430-440whp for 135mph.
500-520whp for 140-142mph.
....but that's on a Mustang Dyno like ours.
I would say different power levels depending on your dyno...
-CFT
Old Sep 21, 2007 | 10:31 AM
1FSTHATCH's Avatar
Default Re: (hybrixt)
with 490hp, i trapped 136mph...
Old Sep 21, 2007 | 11:40 AM
servion's Avatar
My 530whp for the 140mph was on a dynojet.
Old Sep 21, 2007 | 12:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrixt &raquo;</TD></TR><TR><TD CLASS="quote">430-440whp for 135mph.
-CFT</TD></TR></TABLE>
don't take this the wrong way but wasnt your 750whp blue coupe trapping 149mph?
Old Sep 23, 2007 | 02:27 AM
Adriano's Avatar
Default Re: (mike@synapse motorsport)
You guys only look at peak number and not power band. Powerband has more effect on ET/MPH than peak numbers.
Adriano
Old Sep 23, 2007 | 04:08 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: (Adriano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano &raquo;</TD></TR><TR><TD CLASS="quote">You guys only look at peak number and not power band. Powerband has more effect on ET/MPH than peak numbers.
Adriano</TD></TR></TABLE>
Not to mention vehicle weight, slick size, and gearing..
gotta love these posts...lol
Old Sep 23, 2007 | 08:01 AM
adubaz7's Avatar
Default Re: (SIXTYdashONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">
gotta love these posts...lol</TD></TR></TABLE>
yea gotta love this post I believe this is just a simple post to me set my hp goal if you are anoid by this post dont click on it, it really is that simple by the way you cut at this post saying weight slick size and tranny are needed to figure this # but if you read the post you would clearly see that plenty of info was given weight is 2500 w driver no slicks but 235-60/15 bias ply tires no mention of transmission but from what I searched I should be ok with a b16 tranny to run 135mph in forth if I rev to about 9300+ wich is what I have planned for the build
Thanks everone else for helping set my goal it sounds like the target # is 550whp and if I make that 135mph should not be a problem
Old Sep 23, 2007 | 10:08 AM
HT's Biggest Loser
Why dont you just build the car, THEN worry about what it traps.. Dont worry about trap speeds, jeez...
I dont understand whats so hard about building a car, running it, and then answering yer own question..
Old Sep 23, 2007 | 10:24 AM
nonvtecallmotor's Avatar
It takes MORE power to run those types of speeds on the 235/60/15 's
It will take almost 575-600whp (dyno jet)@ 2500 to go 135mph. I dont think a 60-1 will make enough power in that car.
Old Sep 23, 2007 | 06:36 PM
Boostfed's Avatar
New User
Default Re: (nonvtecallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor &raquo;</TD></TR><TR><TD CLASS="quote">It takes MORE power to run those types of speeds on the 235/60/15 's
It will take almost 575-600whp (dyno jet)@ 2500 to go 135mph. I dont think a 60-1 will make enough power in that car. </TD></TR></TABLE>
Yeah Rick has been down the track with those tires a couple of times
