How much of a difference does light wheels make?
Old Oct 1, 2011 | 01:11 PM
AznBlueBoy's Avatar
Default How much of a difference does light wheels make?
So I am a little puzzled by my ET and mph now that I have stock 22lbs wheels on slicks.
I ran 13.1 @ 102mph.
2 years ago, I ran 12.8 @ 105 with some 12lbs wheels on the same sized slicks.
No other changes and the car just got retuned and is driving much better now.
Does 10lbs per wheel make that much of a difference?
Old Oct 1, 2011 | 01:16 PM
hatrickstu's Avatar
Default Re: How much of a difference does light wheels make?
20 lbs of weight off of wheels will make a huge difference
Old Oct 1, 2011 | 01:21 PM
rota92
Guest
Posts: n/a
While they aren't really 'free', lightweight wheels is the free-ist and best way to gain power.
That being said, there are so many things that come into play about your track times that you can't just look at the wheels as changing things around. Track prep, weather, driving, etc. all make a huge difference. Do you remember what your short track looked like on the old pass vs. the recent pass?
Old Oct 1, 2011 | 01:46 PM
AznBlueBoy's Avatar
By short track, do you mean my 60ft time?
It was 1.7 60ft and the 13.1 pass was also a 1.7 60ft.
I did manage a 1.698 60ft on my 3rd pass but I miss shifted which would have gotten me back to the 12's but I shouldn't need that. I did 3 passes and all 3 were 102mph even with a miss shift. I'd say track prep was great considering the 1.6 60ft on a 2850lbs all motor prelude.
Old Oct 1, 2011 | 01:49 PM
AznBlueBoy's Avatar
Would you say a huge enough difference to slow me down 3mph and .3 at the end of 1/4 mile?
Old Oct 3, 2011 | 07:38 AM
m3tech95's Avatar
i think it has more to do with your driving than the 10lbs difference... u should record all your track passes outside & in cabin it helps you see what slight differences u probably have done... it helped me realize i shifted 100 rpm sooner on one pass to the next pass, left the hole staying in 1st gear a 1/3 second longer than another pass....track prep has alot to do with it...could be something as simple as a vacuum/IC piping leak robbing small power (if turbo)
Old Oct 3, 2011 | 12:18 PM
AznBlueBoy's Avatar
it's NA.
I shift when the shift light comes on.
mph was the same on all 3 passes.
Old Oct 3, 2011 | 04:33 PM
m3tech95's Avatar
^ In that case then yes... that weight savings helps... all motor cars can always improve ET with weight reduction. stuff like running on less than 1/4 tank of gas, taking out passenger seat, no spare in the car, i would have to know what your race weight was for both passes that would let you know alot also.
Old Oct 3, 2011 | 05:24 PM
AznBlueBoy's Avatar
I ran without the hood, less then 1/4 tank of gas, passenger seat out, no spare.
I'm going to remove all the sound deadning from the car soon too with the dry ice method and also remove ABS.
Car was 2800lbs with me in it and was the same 2 years ago.
laydee_mini
10
Feb 14, 2015 09:59 AM
trevek10
Jan 3, 2010 08:29 AM
rob_d16y8
Jun 15, 2005 01:24 PM
BOOSTED AUTOMATIC SOHC
Mar 25, 2005 08:55 PM
Type Goch
Jul 9, 2001 02:11 PM
