help w/ the quarter
Old Sep 27, 2003 | 10:07 PM
sihatchyvtec's Avatar
Default help w/ the quarter
i have 92 si w/ gsr eng.. and i run shitty 15.2's i had 14 inch delsols i launched at liek 3500 and juss spun em .. and then i ran 15.2 a month later w/ 15 inch swirlies.. i drop the clutch 2..wat could be my problems.. i try launching at 4gs and stil no 14's i have cai and exhaust and i had chipped p28.. now i have gsr obd1 ecu.>I also have kyb agx.. wat should i adjust them 2 when running? 1-4 .. 4 being stiffest..
Modified by sihatchyvtec at 3:25 PM 9/30/2003
Old Sep 27, 2003 | 11:14 PM
ConeS's Avatar
Default Re: help w/ the quarter (sihatchyvtec)
What kinda tires you running?
Its ok to launch at higher rpms. I have a simular aet-up and launch around 5700 rpm with bridgestone potenzas.
You have to find a very remote location and practice your launches. Dont do launch after launch though get it some time to cool down in between.
Generally its the finesse between the clutch and gas. You want to give enough clutch to get it to grab, quickly but smoothly let the clutch out as traction can afford.
Practice.
Once I learned this with my car I went against a pal with the exact setup as mine and took him off the line huge.
Old Sep 28, 2003 | 05:19 AM
nsxmatt's Avatar
What kind of 60ft did you get? Unless your running a stock VX on slicks your gonna spin off the line. The key is control spinning the tires. Even on drag radials I spin through 1st until the very end of the gear put it's still pulling and keeping the revs up.
Old Sep 28, 2003 | 01:19 PM
Default Re: help w/ the quarter (ConeS)
i used stock michelin xgtv4 that came w/ my swirlies.. so would feathering the clutch be better than juss dropping it? what do u think i should be runnign?
Old Sep 28, 2003 | 03:10 PM
STHPERFORMANCE's Avatar
I'd say pick up a set of BF-g radials and play with air pressure and practice launching and you'll see easy 14's..
Also, i was always told to Never feather the clutch, you will fry it like that.....
Old Sep 29, 2003 | 08:48 PM
ConeS's Avatar
Default Re: help w/ the quarter (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, thats what i dont get. why launch at 5 grand and ride it out with the clutch when one the clutch grabs, you can regulate with the gas pedal.</TD></TR></TABLE>
With my car the earlier I can get to vtec the faster Im gonna go. If I ease it off the line its takes a while for the engine to get going compared to launching at a higher rpm.
itr jdm swap.
PePpeRedDc5
Apr 20, 2005 06:36 AM
CarbonfiberR
Aug 15, 2002 11:17 AM
memphiss13
Jul 3, 2002 10:18 AM
mattL
Jan 13, 2002 01:53 PM
R-Rated
Dec 11, 2001 10:38 PM
