Help with Si tranny...
Old Oct 7, 2004 | 08:43 AM
FULLTHROTTLE's Avatar
Default Help with Si tranny...
I have been having some troubles with my 00 Si tranny int he drag car. Some of you know the car, its a slow, bracket car but I have had this problem that just started one day. I was hoping someone has had similar problems and can help a poor bastard out. When coming off the trailer the car shifts very smoothly and driving around on the street its good too. But after a burnout, launch at the track it will not go into 3rd gear. It grinds sometimes but mostly it just acts as though it is locked out. I have to let the revs fall WAY down for it to finally pop in. The funny part is that after I get to the end of the race adn on the return road it still doesnt want to go in. The dhifter feels really stiff like its hanging up on something. 1-2 is good, 2-3 is really stiff and 3-4 is even stiffer. I have replaced the synchro and shift fork once this year to find uot the problem didnt even budge, no change at all.
Please, if you have had this happen or seen it chime in. Thanks in advance.
Old Oct 7, 2004 | 01:36 PM
E-Town4229's Avatar
Default Re: Help with Si tranny... (FULLTHROTTLE)
ahhhh the dreaded si trans 3rd gear synchro grind! try this it should help.
http://gear-speed.com
-Roger
Old Oct 7, 2004 | 02:13 PM
Default Re: Help with Si tranny... (E-Town4229)
Nope. How does that help. Im looking for some experience, not a new parts list.
Ive already tried new parts, OEM and aftermarket. No dice.
Let me clarify, it doesnt always grind. It mostly feels as though it is not there. And the shifter gets really tight.
Old Oct 7, 2004 | 03:02 PM
Brent L's Avatar
tobi call jj he'll fix it in a heart beeat
Old Oct 7, 2004 | 03:38 PM
smokey2.0's Avatar
Default Re: (Brent L)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brent L &raquo;</TD></TR><TR><TD CLASS="quote">tobi call jj he'll fix it in a heart beeat</TD></TR></TABLE>
i would have to say either a busted pressure plate, or your flywheel bolts are backing out. let us know if you find the problem, good luck
Old Oct 7, 2004 | 03:44 PM
h22 civic's Avatar
Default Re: (smokey2.0)
had simillar prob and the flywheel bolts where backing out
Old Oct 7, 2004 | 03:47 PM
I thought clutch too but when I took out the tranny I checked it and it seemed ok. Also another thing, the shifter remains stiff even after the car is shut off. WHen it cools down its much better but it has been slowly getting worse.
Im thinking it has to be in the shift linkage in the tranny somewhere. Im trying a new clutch as soon as I can afford a good one. I need some sort of slipper, Ive been killing axles (even good ones) with the CM4 that I have.
Old Oct 7, 2004 | 05:32 PM
smokey2.0's Avatar
Default Re: (FULLTHROTTLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FULLTHROTTLE &raquo;</TD></TR><TR><TD CLASS="quote">I thought clutch too but when I took out the tranny I checked it and it seemed ok. Also another thing, the shifter remains stiff even after the car is shut off. WHen it cools down its much better but it has been slowly getting worse.
Im thinking it has to be in the shift linkage in the tranny somewhere. Im trying a new clutch as soon as I can afford a good one. I need some sort of slipper, Ive been killing axles (even good ones) with the CM4 that I have.</TD></TR></TABLE>
do this, take your shift linkage off(where it bolts up to the shifter). check to see if all your spacers, bushings are in place and a little lubricated. also check to see that the shifter is not binding, if you tighten up that bolt it will stiffen up the shifter. also take a look at the shifter bushings, they might be expanding do to the heat from the exhaust pipe(if you're running any)! good luck
Old Oct 7, 2004 | 06:08 PM
I also talked to JJ tonight and he had some very good ideas. I will tear the trans down in the next week and see what I can find. Of coure there will be pics if I find anything interesting.
Good idea on the shifter too, Ill check it to see if its nice and loose when its unhooked from the tranny.
Old Oct 7, 2004 | 07:37 PM
ninesecrx's Avatar
Could very well be the shift selector inside the trans. Sometimes the edges get real beat up too...
Old Oct 7, 2004 | 07:44 PM
Suprdave's Avatar
Default Re: (ninesecrx)
Im thinking pressure plate.
Old Oct 7, 2004 | 10:32 PM
ninesecrx's Avatar
Default Re: (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Im thinking pressure plate.</TD></TR></TABLE>
No because he has problems even when the car is shut off. I think its the selector.
Old Oct 8, 2004 | 08:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">Could very well be the shift selector inside the trans. Sometimes the edges get real beat up too...</TD></TR></TABLE>
Had any luck reshaping them or just replacing?
Old Oct 8, 2004 | 08:57 AM
H2nr's Avatar
are you using Honda MTF? check inside of the car just under were the clutch pedal attaches to the fire wall and see if it is wet. if so replace the clutch master cyl.
Old Oct 8, 2004 | 09:16 AM
Default Re: (H2nr)
LOL, its not the clutch master. And yes I use Honda MTF.
Old Oct 8, 2004 | 09:41 AM
Gearspeed-Performance's Avatar
Was it assembled correctly? Did you check Preload and clearances on shafts? Prematurely worn parts? Internal parts shift under heavy load when there is too much clearance causing inconsistant shifts. You can install all the new parts you want but, if they aren't installed correctly what is the purpose. Just some things to look at. Good Luck and keep us posted
Old Oct 8, 2004 | 11:25 AM
ninesecrx's Avatar
Default Re: (GearSpeedEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GearSpeedEF9 &raquo;</TD></TR><TR><TD CLASS="quote">Was it assembled correctly? Did you check Preload and clearances on shafts? Prematurely worn parts? Internal parts shift under heavy load when there is too much clearance causing inconsistant shifts. You can install all the new parts you want but, if they aren't installed correctly what is the purpose. Just some things to look at. Good Luck and keep us posted </TD></TR></TABLE>
If one shaft goes into a bearing and then into anouther bearing and the other shaft does the same, and gets a clip on it...and they are both a precision fit in the case, how would you clearance them...or set a clearance?
to answer ur question, I have to buy so many tranys cause they break that I usually just put new ones in. I would offer to send ya one, but most of mine are mest up too.
Old Oct 8, 2004 | 11:41 AM
Thanks mike. I think this one will do fine as long as I can get it working again.
GearSpeed: I assembled it like I assemble all of my customer's trannies. By the book. I think I just assumed it was a synchro last time and didnt take the time to inspect everything as well as I should have. That will teach me.
Old Oct 8, 2004 | 04:10 PM
07's Avatar
07
Wierd, never heard of anything like that. Please let us know what you find out
bossman032
19
Nov 21, 2007 01:07 PM
VieTecGSR
Aug 22, 2006 11:34 PM
atljustin06
Aug 1, 2006 04:48 PM
HONDA_TYPE_R
Mar 8, 2006 06:11 AM
anomale
Sep 20, 2005 12:59 PM
