help with shute
Old Jun 21, 2011 | 05:53 AM
061000rr's Avatar
Default help with chute
will this chute work or could it be changed to work on a fwd civic. its off a pro street car. i got a really good deal on it thats the only reason i bought it.
Old Jun 21, 2011 | 08:47 AM
redboost10's Avatar
Default Re: help with shute
what model is it?
Old Jun 21, 2011 | 09:18 AM
061000rr's Avatar
Originally Posted by redboost10
what model is it?
model num 30855c
Old Jun 21, 2011 | 09:19 AM
redboost10's Avatar
is it a stroud?
you want the smallest possible, stroud super comp (model number 400) or simpson skyjacker
beings it was on a pro street car, im assuming it would be one of the smaller models, but find out before you put it on your car.
Old Jun 21, 2011 | 10:05 AM
061000rr's Avatar
is it a stroud?
yeah its a stroud. i was just wandering about how it mounts to the car. all the ones i have seen appear that the chute bolts right to the chute mount. were this one has the big spring that comes out the bottom. i dont see how it would bolt to like the kens kustom mount
Old Jun 21, 2011 | 10:29 AM
redboost10's Avatar
Make a frame for it with tabs at each corner if that makes sense, similar to what is shown in your 2nd pictire.
and since they have the spring launcher, they do not have to stick out as far as the ones with the pilot chutes. just angle it up a bit. im trying to track down a picture of mine
Old Jun 21, 2011 | 12:27 PM
061000rr's Avatar
yeah i got what your sayin. i thought all chutes had springs. is there a rec distance that your supposed to put it off the back of the car?
Old Jun 21, 2011 | 02:10 PM
redboost10's Avatar
the ones with the small helper chute need to be mounted a little further away from the car than these ones do.
i had this one mounted so the spring tube was about 1" away from the back of the car.
gosu08
Feb 6, 2010 04:50 PM
i getz da chewin
Sep 8, 2009 06:14 AM
88 EF Hatch
Mar 3, 2009 06:21 PM
SCCAsean
Apr 10, 2006 04:38 PM
iwhichisme
Jan 18, 2002 07:05 PM
